Burning more oil on highway than around town, why?
Discussion in 'Gen 2 Prius Technical Discussion' started by pasadena_commut, Mar 9, 2026 at 8:33 PM.
  1. pasadena_commut
    pasadena_commut Senior Member
    2,791
    832
    Southern California
    It is my impression that our 2007 burns more oil at highway speeds than around town. Admittedly this may be observational bias, because going 700 miles on a trip on the highway only takes a couple of days, while the way we drive in town, it would be two months. So the same amount of oil burning per mile may seem like a higher rate because of the shortened time frame.
    Anyway, for the sake of discussion, if "my Prius burns more oil on the highway than around town" is actually true, why would that be the case? The only thing that I can think of is that for some reason more oil is pushed through the PCV valve under those operating conditions, where the ICE motor is on and at a higher RPM than in more sedate driving. Some oil definitely follows that path under all conditions, since looking past the throttle plate there is always some oil down at the bottom (not a pool of oil, just signs of oil.)
  2. ChapmanF
    18,491
    What is your average engine RPM in highway driving, compared to around town?
    I've never had a car that didn't burn oil faster at higher RPM.
    I've never thought the PCV circuit had to be the only path or most important path. The cylinder walls are a path. Piston rings can only be so close to perfect.
    BiomedO1 likes this.
  3. BiomedO1
    4,071
    2,136
    SacTown, Ca
    If you know you have issues; you should be checking at every fill-up. That's a good rule that seems to have gotten lost by the computer generation.
    I was helping my friends daughter move to the east coast for her graduate program. The first fill-up; I didn't say anything. The second fill-up I mentioned it; still nothing. On the third fill-up; I insisted. It was 1.5 quarts low, not touching the dip stick. We were only about 1K miles into the trip; so I had to ask - "Is this how you were planning on getting another car?". We had a good laugh over that; because she knows better. Blasting down the highway averaging 80+ mph will do that to an old Lexus engine with 200K+ miles on the clock. It had a 5-6 quart sump.
  4. PriusCamper
    PriusCamper Senior Member
    13,014
    5,289
    Pacific Northwest, USA
    It's interesting how we call it burning oil when there's no leaks on the outside because the loss of oil isn't as straighforward as it just burning, but how it circulates in the engine. Would be great if someone like you or someone else who knows alot could help explain the finer points of this subject.
  5. pasadena_commut
    2,791
    832
    Southern California
    On a Prius unless there is an OBD2 reader plugged in you would never know the RPM. On our 1998 Accord there are spikes to 3K on any acceleration (not foot to the floor, just speeding up normally), cruises at around 2K on the highway, spins only a little lower at 45 or 30 mph, idles at 600 (ish). The average RPM will be higher on the highway because there won't be nearly as many periods of deceleration or sitting still idling, not because the RPM range is much different between the two conditions.
    My son thinks that one reason the Prius would burn more on the highway (per mile) is that the ICE would be on most of the time and the oil would be at an average temperature which is much hotter than when driving around town, especially in any sort of stop and go. Since the oil viscosity falls with increasing temperature, and the thinner the oil, the more that will get by the rings, it will burn more on the highway. I think by the same logic on the highway the lower viscosity oil will more easily form small droplets, and those will hang in the air long enough to be sucked out through the PCV valve. That would be testable if I had an oil catch can. Unfortunately there does not seem to be a CARB approved one, so installing one is likely to result in a failed smog test at the inspection stage.
  6. ChapmanF
    18,491
    I'm not sure much effort is needed to brainstorm modern-tech, hybrid-specific explanations for a phenomenon that's been around since ancient cars: sustained operation at higher RPM burns more oil.
    The speeds one considers to be "highway cruising" make a difference. My Prius doesn't use a lot of oil in my normal highway driving, at or around the PSL. By contrast, one time I got a late start leaving for a friend's funeral in Boston and made that Indiana-to-Boston cruise at, shall we say, a sustained speed that made up the time, and there was noticeable oil gone after that. No surprise there.
    The lowest ring on the piston is called the oil control ring. It usually has a more complicated construction than the two upper, "compression" rings. It's more like two skinny rings and a kind of waffle spacer. When the piston moves upward, the cylinder below it is crankcase, and gets oil splashed up on those cylinder walls (or even sprayed by dedicated nozzles, in some engines). When the piston moves downward, the cylinder above it is combustion chamber, and whatever oil is left on those walls gets burned. The oil control ring should have squeegee'd most of the oil back down the walls into the crankcase, leaving only a small amount to end up burning. Still, at 3000 RPM the piston is going up and down 50 times every second, in every cylinder.
    The PCV path is, of course, also a path.
    Merkey and BiomedO1 like this.
  7. Mendel Leisk
    41,855
    The engine runs less, and occasionally shuts off completely, around town, versus fulltime running, at higher rpm on the freeway. Sheesh, next question.
  8. BiomedO1
    4,071
    2,136
    SacTown, Ca
    This is all a moot point; if you check your fluid levels at every fill-up. It only takes a minute while the tank is filling. I don't understand the resistance and how someone can blame the OEM for blowing up an engine because it wasn't properly maintained.
    It seems kinda obvious to me; if the engine is running - your burning gas and should check all your fluid levels every fill-up. Assuming you have no fluid leaks hitting the ground. It's better than guessing and develops good routines that will prevent high cost repairs.
    An ounce of prevention is worth a pound of cure....
    Just my 2-cents......
  9. pasadena_commut
    2,791
    832
    Southern California
    I have hard time getting a good dipstick reading on the Prius when the motor has run recently, especially if the oil is fresh. Pulling out the dipstick always drags oil up the tube so the 2nd reading is confounded by contamination from the tube walls. If the motor has been running it must be pulled out and cleaned off once before making a reading, because oil also splashes up all over the reading area. For that reason I usually check the dipstick on the first pull, before starting the car for the day. However, on a really long road trip I would check the oil at the fill up. While it won't be accurate to measure "was .5, now is .4", it will be good enough for "was .8, is now .3", or worse, "no oil on stick".
    Anybody know how long it takes the oil to drain back down the tube so that the 2nd reading would be as good as the first? Normally it is only seconds from pulling out the dipstick until it goes back in, and that isn't enough time. If waiting a minute or two was sufficient, I would do that. If it takes 5 or 10 minutes, probably not.
  10. Mendel Leisk
    41,855
    5 minutes works for me. Pull/wipe the dipstick, check tire pressures, then back to the dipstick check.
    That said, an immediate check has also been working "fairly" good. The face of the dipstick towards front of car tends to be clearer in my experience.
  11. dolj
    dolj Senior Member
    8,547
    4,341
    Wellington, New Zealand
    I was taught by my father, a trade-certified (A-grade) motor mechanic, to always wipe the dipstick. I have always done that and would never do otherwise.
    I’ve found with the Prius that one side of the dipstick always looks consistently better than the other, and if I recall correctly, it’s the side facing the front of the car. Also, you’ll notice there is a curve to the dipstick; I always replace it so that the curve follows the direction of the bend in the dipstick tube.
  12. ChapmanF
    18,491
    I've pretty much always just stopped the car, turned it off, pulled the fuel door and hood releases, gotten out, fiddled with the pump and the credit card and the hose and nozzle, started the fill, walked to the hood, opened it, pulled the dipstick once, wiped it, dipped it and pulled it again, and read it. It hasn't ever seemed especially hard to read. (Well, it is hard right after an oil change, because the new oil is so clear. It gets easier and easier until the next change.) I do find one side easier to read than the other. I still always look at both.
  13. BiomedO1
    4,071
    2,136
    SacTown, Ca
    I've got a rag stuffed in the engine compartment for that purpose. Drive-thru napkins in the door pockets; if the oil is new. Just look for the wet spot with the napkin to get an idea of the oil level. It doesn't have to be perfect - you just need to make sure there's still enough oil in there.
    Listening for a rod knock or watching the oil lamp illuminate is the other option. Unfortunately, either one of those is going to be a costly repair.
    #13 BiomedO1, Mar 10, 2026 at 9:02 PM
