Windows Will Not Close
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TrispokeB, Mar 10, 2026 at 10:47 AM.
  1. TrispokeB
    TrispokeB New Member
    Tuesday
    Was driving home today and opened windows halfway. Got home and they wont close!
    Individual door window switches dont work either.
    Driver window switches for all windows dont work, and the driver door lock button doesn’t work, passenger door lock button still works but not window. None of the individual window buttons work either.
    Driver mirror movement buttons still work tho. Child window lock is not pressed. (Maybe that button is what broke?)
    Is this a fuse? Seemed strange that all windows wont work and that driver locking button also wont work. Is the wire connecting the driver window controls and lock control connected? Maybe its loose?
    Figured I would ask before I take the door panel apart.
    Appreciate any help! I have owned my Gen 2 for a long time and am happy to have finally joined the forum :)
  2. TrispokeB
    Tuesday
    I found the culprit! Any idea on the easiest and cheapest fix here?? IMG_2422.jpeg IMG_2423.jpeg IMG_2427.jpeg IMG_2426.jpeg
  3. BiomedO1
    4,071
    2,136
    SacTown, Ca
    Junk/scrap yard replacement. Get both console and harness; since it looks like it melted the connector on both ends.
  4. ChapmanF
    18,491
    If the harness is just a small one within the door, yes, getting that harness at a salvage yard and replacing it is easy.
    If that connector is on some harder-to-replace harness (say, comes through into the door from the body, I have not checked this in the wiring diagram), then buying a repair terminal for that one position would be another solid option.
  5. rjparker
    10,451
    6,554
    ....dup
    #5 rjparker, Mar 11, 2026 at 1:20 PM
  6. rjparker
    10,451
    6,554
    It appears that connector is part of a rather big harness that would involve connectors under the instrument panel and other connectors in the door.
    Part 82152-47150
    While the harness is easily available, I would be more likely to buy a switch assembly and replace the one mating connector on the harness.
    Switch with cut harness
    https://www.ebay.com/itm/177797303695?fits=Year%3A2004%7CModel%3APrius&_skw=2004+Prius+master+switch&epid=13042884725&itmmeta=01KKETXYW02ZCRP5V3P9QWV407&hash=item2
    Complete Ebay harness
    04-09 Toyota Prius Front Left Driver Side Door Wire Wiring Harness 82152-47150 | eBay
    #6 rjparker, Mar 11, 2026 at 1:22 PM
    BiomedO1 likes this.
  7. BiomedO1
    4,071
    2,136
    SacTown, Ca
    Yep; splice it in; if the harness replacement is too much work.
    You can repin that single wire position in that harness, but I don't know if you have the skill level or fine tools to do that repair. It's delicate work, especially since that connector heated up and the plastic is likely very brittle now.
