Cold start hv fan limp mode high idle help
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Steve 72, Mar 9, 2026.
  1. Steve 72
    Steve 72 Junior Member
    Maryland
    starting point is when the engine is cold and I haven’t driven it. Symptoms are as follows high idle Battery fan comes on right away limp mode right away. I have a Dr. Prius app state of charge states it’s between 30 and 60% about 220 V and then it will go to negative bolts alternating I took the hybrid battery apart checked all 14 blocks. No cells are bad. I also replaced the hybrid battery wiring harness that goes onto the one side that’s color-coded. The first code that pops up is a P 3000. The battery fan is clean no dust no obstructions in the filter. I’m at my wet sandwich with this Prius. Any possibility it could be the inverter assembly? I also replaced the inverter cooling pump as that seemed to be a popular reason for the symptoms. Please help I appreciate it
  2. Steve 72
    Maryland
    Bus bars and nuts no corrosion whatsoever. I cleaned it as well thanks
  3. Steve 72
    Maryland
  4. PriusCamper
    PriusCamper Senior Member
    13,417
    5,416
    Pacific Northwest, USA
    Howdy... Did you load test the individual modules when you took the pack apart or just checked the voltages? We can walk you through a load test.
    Also, did you find any corrosion where the pins at the ECU plug into the voltage sensing harness? If so then you'll want to look inside the ECU because there's a pin that connects to the circuit board that can grow corrosion and cause signal noise that leads to a P3000 error code.
    Brian1954 likes this.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,110
    2,011
    NJ-USA
    If you see negative voltage readings, then there is a problem with the voltage sense circuits. If you have replaced the sense harness ( & properly connected all terminals then torqued all the nuts to 48 INCH-pounds ) then that leaves the ecu - as mentioned.
