Prime Headlight Pattern
Discussion in 'Prime Main Forum (2017-2022)' started by allfatcatz, Feb 4, 2026.
  1. allfatcatz
    allfatcatz New Member
    Utah
    2020 Prius Prime
    Hey everyone,
    I recently purchased a 2020 Prius Prime CPO from my local Toyota dealer. I noticed when I was driving on the highway that the headlights seem to be projecting to the side. I took some pictures when I got home. I plan on taking it to the dealer for them to look at but I wanted to get a quick sanity check on what the headlight pattern on the Prime is supposed to look like, or if anyone has an idea of what could be causing this.
  2. Boston_Pilot
    Boston_Pilot Junior Member
    Seaside Park, NJ
    2020 Prius Prime
    Howdy, proud owner of a 2022 Prius Prime Limited. My headlights are actually aimed pretty darn well. I’m using my Tesla to compare against. I get flashed all the time, even with the so called “Matrix” headlights. The Prius, I haven’t been flashed at even once, and I’m super happy with the pattern of the headlights. Your pictures don’t look correct, but no expert here….
  3. richard203
    richard203 Member
    278
    61
    SF
    are you on high beam? looks like u in high beam
  4. BiomedO1
    4,161
    2,179
    SacTown, Ca
    FWIW; pictures from the outside of the car really doesn't tell us much; Since the headlamps are supposed to be pointed and optimized for the drivers' viewpoint.
