1. presus
    presus Junior Member
    33
    ny
    2013 Prius v wagon
    hello, i am back fixing this dam car again,
    long story short my heater core busted, tore it all down put it back and it doesnt want to ready. everything else works except ready and the obd.
    i am suspecting it has something to do with this unplugged connector. i have no idea where it goes. thanks.
  2. presus
    33
    ny
    2013 Prius v wagon
    the backside if the mystery connector
  3. presus
    33
    ny
    2013 Prius v wagon
    hopefully doesnt have to do with this lol
  4. Air_Boss
    Air_Boss Senior Member
    4,220
    1,188
    New Yawk
    There is no open mystery jack to which it mates?
  5. rjparker
    10,454
    6,556
    I think there are very few of us that have ever removed the dash.
    Its possible that connector is for a module you don't have.
    Given it is a three wire connector with a given shape, I might spend a couple of hours reviewing the wiring diagram's for that connector and then find where it has a single w/black, a blue and a black wire.
    Short of that, you might want to diagnose the obd2 (dlc3) problem which needs repair anyway and could lead to the issue. Power and ground and the CAN bus would be my focus.
    #5 rjparker, Mar 12, 2026 at 8:23 AM
  6. ChapmanF
    18,497
    ^ This.
    The "Location and Routing" section of the wiring diagram is where you find pictures of the physical wire harness layout in the car and which connectors come off the wire harness where, so by finding the connectors that are shown near where yours is, you can cut down that "couple of hours" by a lot. If you're using the online diagram, you can just click on a connector to go right to the circuit information about it with the wire colors and so on.
    You can find more about doing that in the "Electrical Wiring Diagram" section of this page:
    Toyota Service Information and Where To Find It | PriusChat
    Air_Boss likes this.
  7. presus
    33
    ny
    2013 Prius v wagon
    no, im wondering if its a ground plug
  8. presus
    33
    ny
    2013 Prius v wagon
    i tried, i went on tis and nothing would load
  9. presus
    33
    ny
    2013 Prius v wagon
    it is a 3 wire connector, not 2. and it appears it is a ground. i just want to know where it goes and what its for. blue, black, white black
  10. presus
    33
    ny
    2013 Prius v wagon
    anyone have wiring diagram for dlc
  11. presus
    33
    ny
    2013 Prius v wagon
    anyone know where L93 is?
  12. ChapmanF
    18,497
    Have you got any kind of browser setting or extension that blocks any Javascript or the like?
  13. presus
    33
    ny
    2013 Prius v wagon
  14. rjparker
    10,454
    6,556
    DLC3 is in post 5. A v wagon has a dlc3 ground wire routing that is different from a hatchback.
    You pay $30 for two days TIS access
    TIS
    TIS
    I would still look for the connector and then find one that has the three wires.
    Others have found disconnected wires in the past doing this work. But your connector might not be it if it was an option your car does not have.
    #14 rjparker, Mar 12, 2026 at 2:45 PM
  15. presus
    33
    ny
    2013 Prius v wagon
    you know where connector 3a is ?
  16. presus
    33
    ny
    2013 Prius v wagon
    ok so the dlc is good, has good ground and power, and 60ohms across can. now what, car does not want to ready.
  17. rjparker
    10,454
    6,556
    What codes?
    Did you previously pull the orange hv disconnect?
