Replacing spark plugs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by avoice217, Dec 19, 2025.
  1. Mendel Leisk
    41,856
    Purely speculating, I’ve used MAF cleaner, but have not found definitive blessing for its use. Doesn’t help that MAF and MSP are so close, throws off search results. Seems to be a dearth of info.
  2. avoice217
    avoice217 Member
    180
    22
    So just would like to clarify on my end that I have NOT attempted to clean the MAP sensor at all. The only thing I've done is removed it in regards to cleaning the throttle body, but that's it. If anything, I've been doing research and finding MAP sensors for either around $30 or $300. Now naturally the Denso brand in itself is $300, but I just can't seem to understand how a MAP sensor is literally 100x the cost overall of a MAF sensor, especially when they're around the same overall size. I totally understand that they serve different purposes however.
