Anyone know what brand/model of scan-tool this is?
Discussion in 'Gen 2 Prius Main Forum' started by priuslyfe, Mar 9, 2026 at 1:59 PM.
  1. priuslyfe
    priuslyfe Member
    263
    66
    guy in video says 10 years old, he said he paid $3K for it a decade ago but now its much cheaper. He says its made by CORNWELL and is a LOUNGE scanner in the video but I can't find it online and AI says its no longer made. I'm Just wondering if its better than my Autel's APMaxi200 OBD scanner (OR IF THERE IS A CURRENT BRAND/MODEL SUBSTITUTE WITH A SCREEN), and if I can pick up a great cheap scanner thats cheaper/better/equivalent to a Techstream setup (I don't have a laptop computer either).....
    from this video approx 5:00 minutes in....
    UPDATE: Looks like Autel makes a very close substitute that from 2024. however its around $500. Still wondering if there is any equivalent older cheaper substitute for Gen2 prii
    2025 Autel MaxiCheck MX900 Full Bidirectional Scanner Tool Upgraded MK808BT PRO
    2025 Autel MaxiCheck MX900 Full Bidirectional Scanner Tool Upgraded MK808BT PRO | eBay
    #1 priuslyfe, Mar 9, 2026 at 1:59 PM
  2. Tombukt2
    13,338
    2,401
    What is it you're looking to do above the maxi ap200? I own a bunch of scanners . The older units sit. The newer updateable ota type units stay in service . The cheap stuff keeps getting more advanced. Just depends wer you need or want to be. Lounge is probably a bad call on launch. Butnonvsvanner pictured it looks like Xtool logo on bottom of it?
  3. priuslyfe
    priuslyfe Member
    263
    66
    basically this video popped up in my feed and I watched it for any insight. I don't have techstream and wanted to know if there is a one-in-all alternative like pictured in the video.
  4. lexidium
    lexidium Active Member
    301
    143
    manchester
    I have the Launch CReader Elite 2 (The Toyota version) It does practically everything that techstream does and updates are free for life.
    priuslyfe and xw20_driver like this.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,086
    1,997
    NJ-USA
    That scantool is the Launch X-431, it says "pad 2", but Launch has a few dozen (?) sub variants of X-431.
    If you want a "complete" budget scantool that covers all systems with bidirectional controls - good luck wading through all the ad copy.
    priuslyfe likes this.
  6. priuslyfe
    priuslyfe Member
    263
    66
    Thanks for the replies. Autel is pretty great alone but in my opinion it sometimes is pretty obtuse and only gives codes after things start to get really bad. Such is the case regarding my brake actuator CODES popped up way after the problem started which made me me seek out alternative answers unnecessarily.
  7. Tombukt2
    13,338
    2,401
    Yeah but if your brake problem creeped up and you didn't have any codes doesn't matter the brand of scanner. So I'm not sure how it crept up . Felt funny no lights or codes ,?
  8. priuslyfe
    priuslyfe Member
    263
    66
    absolutely correct. creeped up. in fact I made a thread in May 2025 ("crazy brake problem I can't figure out"; basically brakes sometimes miss while driving slowly in reverse). I have driven since May 2025 without any noticeable legitimate/safety issue until the past month.
    @pasadena_commut made the comment below in May 2025, which is almost certainly what the issue was all along ABS/actuator. coincidentally the recent brake actuator issue (now in complete failure/no pressure) also recently started by having more frequent lack of braking ability going in reverse only AT FIRST, then gradually started slipping going forward (that, trust & believe, you WILL NOT forget because it is terrifying)....
    That said, the brakes shouldn't ever do that. It could be that the part of the ABS system which hold pressure has a leak, so after the car has sat for a while the expected stored pressure isn't there, it only comes back after the pump has run for a while.
    #8 priuslyfe, Mar 12, 2026 at 12:17 PM
  9. Tombukt2
    13,338
    2,401
    So you're getting this to happen only in reverse so you driving in reverse just for fun or such . Or this just happens in the few seconds it takes to flip into reverse back up the car two car lengths go to apply brakes and keep going reverse? Or the car slows like a 60 model trunk w no brake booster no power but stopping
