Windows Will Not Close
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TrispokeB, Mar 10, 2026.
  1. TrispokeB
    TrispokeB New Member
    Was driving home today and opened windows halfway. Got home and they wont close!
    Individual door window switches dont work either.
    Driver window switches for all windows dont work, and the driver door lock button doesn’t work, passenger door lock button still works but not window. None of the individual window buttons work either.
    Driver mirror movement buttons still work tho. Child window lock is not pressed. (Maybe that button is what broke?)
    Is this a fuse? Seemed strange that all windows wont work and that driver locking button also wont work. Is the wire connecting the driver window controls and lock control connected? Maybe its loose?
    Figured I would ask before I take the door panel apart.
    Appreciate any help! I have owned my Gen 2 for a long time and am happy to have finally joined the forum :)
  2. TrispokeB
    I found the culprit! Any idea on the easiest and cheapest fix here?? IMG_2422.jpeg IMG_2423.jpeg IMG_2427.jpeg IMG_2426.jpeg
  3. BiomedO1
    4,289
    2,254
    Left Coast
    Junk/scrap yard replacement. Get both console and harness; since it looks like it melted the connector on both ends.
  4. ChapmanF
    18,655
    If the harness is just a small one within the door, yes, getting that harness at a salvage yard and replacing it is easy.
    If that connector is on some harder-to-replace harness (say, comes through into the door from the body, I have not checked this in the wiring diagram), then buying a repair terminal for that one position would be another solid option.
  5. rjparker
    10,619
    6,657
    It appears that connector is part of a rather big harness that would involve connectors under the instrument panel and other connectors in the door.
    Part 82152-47150
    While the harness is easily available, I would be more likely to buy a switch assembly and replace the one mating connector on the harness.
    Switch with cut harness
    https://www.ebay.com/itm/177797303695?fits=Year%3A2004%7CModel%3APrius&_skw=2004+Prius+master+switch&epid=13042884725&itmmeta=01KKETXYW02ZCRP5V3P9QWV407&hash=item2
    Complete Ebay harness
    04-09 Toyota Prius Front Left Driver Side Door Wire Wiring Harness 82152-47150 | eBay
    #5 rjparker, Mar 11, 2026
    BiomedO1 likes this.
  6. BiomedO1
    4,289
    2,254
    Left Coast
    Yep; splice it in; if the harness replacement is too much work.
    You can repin that single wire position in that harness, but I don't know if you have the skill level or fine tools to do that repair. It's delicate work, especially since that connector heated up and the plastic is likely very brittle now.
    PTS likes this.
  7. PTS
    PTS Member
    93
    42
    Austin, Texas
    2013 Prius v wagon
    No need for alligator clip tool
    Basics
    #7 PTS, Mar 12, 2026
  8. pasadena_commut
    pasadena_commut Senior Member
    2,910
    877
    Southern California
    I would also suggest ruling out a short to ground on the far side of that connector. Connectors fry like that for only two reasons (OK, there might be some others I have not considered):
    1. it became loose and there was arcing between the contacts
    2. there is a short in the circuit somewhere and the current through the burned contacts was too high, causing it to heat up and melt nearby plastic onto it, which then burns to a black carbon coating.
    As examples of the latter, a wound component, like some resistors or a motor, can sometimes short between adjacent coils, taking most of the resistance out of the circuit, and so cranking the current way up. This may or may not blow a fuse when it happens.
    Anyway, if such a short exists, after you fix this it will just burn up again. Probably you would rather avoid that!
  9. BiomedO1
    4,289
    2,254
    Left Coast
    Just wire-nut the connections together at varying lengths, so you don't have a big lump in one place. Zip-tie or electrical tape the bundle together and possibly zip-tie it down - so it doesn't rattle, rub, or get tangled in the window mechanism.
    Whenever I see this, it's usually something spilled into/onto the control console and/or something fried on the control board. It's usually a sticky mess when you dig into it.
  10. ChapmanF
    18,655
    If that's an 18-pin connector, I would certainly rather re-pin and make one good wire splice than make a big bundle of 18 half-nice-personed splices, 17 of them fixing things that weren't broke.
    Re-pinning does require a tool, one that pokes into the plastic connector shell to release the pin. The wiring diagram shows the shape and dimensions required. I got by for years just wiggling a small jeweler's screwdriver while cussing until it eventually let the pin go, but later on I took my Dremel tool to a steel cotter pin and ground it to the right shape and dimensions, and that works much better. (y)
    If you do buy a switch with the connector still attached and the wiring lopped off, you can, of course, get the one repair wire you need by releasing it from there. Then you can keep the one with the original color code. (When you buy a repair wire at the dealer, you get whatever color it happens to be.)
    If the re-pinning in that connector shell really doesn't work because of the heat damage, then another option is to swap over the connector shell from the salvage part. That would require 34 more pin-releasing exercises, and making double- and triple-sure the wires all go to the right positions again, but would still avoid a big bunch of unnecessary splices.
    If it seemed necessary to do that, I would definitely take the time to fashion (or buy) the correct pin-release tool; trying to release that many pins using the wrong tool and cussing would be nuts.
    Also, be sure to study the picture in the online wiring diagram that shows how the connector locking works. Besides the individual lance for each pin to be released, there is usually also one overall lock for all pins, which also needs to be released in the way the picture will show.
  11. BiomedO1
    4,289
    2,254
    Left Coast
    There are specific pin extraction tools for every connector under the sun. Just trying to keep it simple. That connector heated up enough to melt the pin; so logic would conclude that the plastic around the pin is going to be brittle. If your not used to that kind of fine, miniature work; its easy to break something or create a short to the next pin over, because you accidentally punched a hole between the pin insulators.
  12. ChapmanF
    18,655
    I didn't know whether it would have been faster to get a set of pin-extraction tools for every connector under the sun and then find which one of those was right for the connector at hand, or just grind a cotter pin to the dimensions Toyota gave me, but what kinda made the decision for me was that I had a cotter pin and my Dremel tool right here.
  13. pasadena_commut
    2,910
    877
    Southern California
    While the damaged plastic housing may make it difficult to release pins in that vicinity, it will probably make it easier to chip apart the housing there and release them destructively (of the case, not the pins).
    This isn't the exact same connector, but the pictures and diagrams in this thread may help understand how these things work:
    De pin help | Toyota Tundra Forum
