Right amount of coolant??
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by priusrust, Mar 10, 2026 at 1:51 PM.
  1. priusrust
    priusrust Member
    218
    81
    MA
    went to Toyota parts....asked how much anti-freeze coolant my 2016 takes.
    Parts guy looked it up and said 13 quarts ......
    Then looked up cooling system in my owners manual, and it tells me for capacity: 6.2 quarts (gasoline engine) and 1.5 quarts (power control unit).
    I'm confused.....I want to drain coolant and fill up with new coolant. Simple.
    I asked them about discrepancy and they and they honestly were mystified....not slightly off...it's double!
    Help appreciated, thanks!
  2. rjparker
    10,456
    6,560
    Generally you only get half out on a drain and fill.
    priusrust likes this.
  3. Mendel Leisk
    41,860
    I think it's mechanically similar to gen 3, at least for coolant volumes. From my notes when I changed both circuits:
    engine coolant drain: 4.25 liters roughly
    inverter coolant drain: 1.5 liter roughly
  4. a2058
    a2058 Junior Member
    56
    24
    Westchester, NY
    2019 Prius
    XLE AWD-e
    I usually keep two 1 gallon Toyota SLLC on hand when I drain and fill both, then get a little bit left over for topping up…
  5. priusrust
    priusrust Member
    218
    81
    MA
    So my manual (not the dealer) says 6.2 qt (5.9 L) for engine, 1.5 qt (1.4 L) for power control unit (inverter I presume).
    that is .3 shy of two gallons ......I'll do this.
    The dealer insisted, even after I showed him the manual, engine takes 13 qts!!! (3 gallons + 1 qt)
    I have to remember this is the same dealer who did the recall on my gen 2 steering column linkage, and the steering wheel subsequently became detached from steering column when driving!
    Thanks all!
    Merkey and Mendel Leisk like this.
  6. Mendel Leisk
    41,860
    Owner's Manual? Numbers in there would tend to be system capacity I think, not typical drain amount.
    Merkey likes this.
  7. ColoradoBoo
    ColoradoBoo Senior Member
    1,270
    876
    Monument, Colorado USA
    Yep you might get half out when draining. BUT if it ends up being just half why not drive it for about a week and do the same drain and fill service? (That's what I like to do in my Tundra because the only way to drain more coolant is to use the little drain plugs on the block and no way am I brave enough to mess with those things....break one and it's a very expensive lesson!)
    rjparker likes this.
