Battery sensor harness color code diagram
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Steve 72, Mar 14, 2026 at 2:28 PM.
  1. Steve 72
    Steve 72 Junior Member
    Maryland
    Looking for a color code schematic for the battery sensor harness
    14 wire harness
    Thanks
  2. PriusCamper
    PriusCamper Senior Member
    13,018
    5,290
    Pacific Northwest, USA
    I searched for this for a long time and never found it a couple-few years ago... If it was a Honda, I'd have it for you but Toyota is a hassle...
    Acenbay.com spent big on the tooling to make these wiring harnesses so you can ask him if he knows, but I'm fairly certain his wiring color codes are different than OEM wriring codes.
  3. ChapmanF
    18,503
    It's easy to find in the Electrical Wiring Diagram. Toyota Service Information and Where To Find It | PriusChat
    I'm pretty sure it's been screenshotted and attached to PriusChat posts more than once. Try searching for old posts about which end of the battery to count module numbers from (it comes up in some of those discussions).
  4. rjparker
    10,461
    6,564
    #4 rjparker, Mar 14, 2026 at 11:50 PM
