Updating piston rings, what else to do while there?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Wtfdustinwtf, Mar 15, 2026.
  1. Wtfdustinwtf
    Wtfdustinwtf Junior Member
    45
    17
    Carolinas
    2014 burning through oil a lot. I finally decided last second to hoist out the engine put it on a stand tear it down update the rings+ new headgasket +machining. I started this project last second as the funds tools and free time are all here for a short window. I know enough and have enough saved manual excerpts and saved videos to proceed. However I've never tore down and engine before and don't exactly know what else might be worth doing while the engine is out. I have the OEM headgasket kit 10 head bolts and updated rings. Is there any thing else I should get and do? I know nothing about if valves need lapped or springs need any special attention. Any advice tips or general knowledge would be greatly appreciated.
  2. Brian1954
    Brian1954 Senior Member
    2,542
    1,008
    South Central PA, USA
  3. Mendel Leisk
    42,125
    The revised rings require the revised pistons, part nos in attached.
    this 3-part video is quite thorough:
    #3 Mendel Leisk, Mar 15, 2026
    xw20_driver and Wtfdustinwtf like this.
  4. rjparker
    10,818
    6,790
    I would send the head to an automotive machine shop for inspection and repair if needed. Some warn of taking too much surface off if warped due to potential timing issues.
    The number one problem we hear about is the timing chain off by a tooth requiring rework. Follow Toyota's instructions to the letter including the short reverse rotation to release the tensioner.
    Leaks at the timing chain cover happen but if you do yours engine out it should be easier to do right. Unless you have the engine in the car again and then find the timing is off.
    Others fail to reconnect all hoses or connectors.
    Still others spill coolant into the ac connectors causing problems since high voltage to the compressor is shutoff when any ground conduction occurs. Sort of like a built in gfci.
    Allow plenty of time. You are bound to need more tools and parts.
  5. Wtfdustinwtf
    45
    17
    Carolinas
    Thank you for pointing this out! I am ordering them now.
  6. Wtfdustinwtf
    45
    17
    Carolinas
    For clarification your saying that even if the hybrid battery is disconnected, if you spill coolant on the ac compressor it can still causes issues? If some does spill is there a particular procedure to use to prevent damage before the batteries are hooked back up?
  7. rjparker
    10,818
    6,790
    Some people have continuing problems even after attempting to clean it up. Best to carefully protect both the high voltage and control connections, cable ends and especially compressor end. Occasionally the compressor has to be replaced. Its unclear what the failure mechanism is but the compressor has an ecu.
  8. BiomedO1
    4,416
    2,325
    Left Coast
    I'd second having the head sent out to a reputable machine shop. One of the rare occasions I wouldn't use an old-timer with lots of experience. IMHO; Aluminum heads are a different animal that requires a different skill set and modern equipment to be done properly. They will replace valves and guides, if necessary, and valve seals to prevent top end oil leaks.
    Make sure you put everything back in the same place, don't mix up piston bearing and clamps. I'd mark them before taking them apart. Some pistons are directional; I haven't taken one of those apart; so pay attention to the marking stamped on the rods and sometimes inside under the piston.
    I would replace at least the timing chain, tensioner and any plastic guides; there's going to be some stretch to that original chain. Might as well take care of that while your there. Replace the water pump too, while it's out. I understand that they get intermittent as they age. You don't have a temp. gauge, just a dummy lamp.
    That's all I can think of for now... Good Luck...
    #8 BiomedO1, Mar 16, 2026
  9. ChapmanF
    18,848
    The "built-in GFCI" function is monitored by the power management control ECU, for the car's whole high-voltage system, and reported by the code P0AA6. Inside the compressor is a DC to three-phase AC inverter/motor-controller, and the P0AA6 will have a subcode 614 if the ground conduction is on the DC side of that, or 611 if on the AC side. The P0AA6 code has car-wide consequences: the car won't go READY, if the code is present when starting. If the code is detected while driving, the triangle will light up and you can still finish your drive, but not go READY next time.
    That's the kind of consequence that can be temporary if you are able to correct the conduction to ground; clear the code then and you're good to go.
    But it's also possible for coolant getting inside the compressor to have the other usual effects of getting water into electronics, just letting the magic smoke out for good. You might see that in B147x or B1498 codes from the HVAC system, and the air conditioning not working while the rest of the car still does.
  10. Mendel Leisk
    42,125
    In part 2 of the videos in post 3, he mentions for the bottom end, piston arms to crankshaft, a 12-point 14mm and 10mm socket are required (around the 22 minute mark)
  11. Eddie25
    Eddie25 Active Member
    503
    212
    MI
    When I did research for my own head gasket job a few years ago I convinced myself that the updated Toyota gasket used the same coating as the original (just covering more area). After reading some posts from guys in specialty shops that used Fel-Pro for that reason (they finally saw a gen4 failure), I decided to go with the Fel-Pro.
    If you have the Toyota kit already you could confirm this yourself, but if it is indeed the case I would get the Fel-Pro head gasket by itself and use that with all the other parts of the Toyota kit. If I'm wrong about the Toyota HG just ignore me. I would never put a head gasket with Toyota's infamous black coating in my car though.
  12. Mendel Leisk
    42,125
    The infamous EGR system might also be part of the problem.
  13. KevininFl
    KevininFl Junior Member
    62
    Fort Myers Fl.
    I would send the Bearings to Polydyn Performance Coatings in Tx,Or Calico Coatings for CT-11 …
  14. Mendel Leisk
    42,125
    Getting a variety of search results; can you provide a link? Never mind, found it, searching for
    Calico Coatings CT-11
