Brake Fluid Explained
Discussion in 'Fred's House of Pancakes' started by Georgina Rudkus, Mar 15, 2026.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,513
    2,503
    Taylors, SC
    A really good video on brake fluid.
    52,401
    No wonder you don’t have to change it anymore
  3. futurist
    futurist Member
    56
    111
    United States
    2024 Prius
    That was a good video (y)
    Much more pertinent for motos, whose whole systems are more exposed to the elements than a four-wheeled vehicle, which is already pretty exposed. At least cars have more airflow blocked by bodywork -- and on a typical motorcycle, two distinct and non-linked systems (although today a lot of motos have ABS and/or linked brakes like Hondas, so could be considered a single system. Still directly sprayed with pressurised water every time your wash your bike...
    Anyhow... takeaways from a pro wrenching past:
    • not only is DOT3 least of the 3 glycol-based fluids to absorb water, it's cheap too... which is why unless litigation makes your mfr's lawyers uneasy... your car will have DOT3 as OEM
    • most sportbikes are DOT4, esp if they're race replicas (sport ATVs too, ex. Honda TRX400EX or Yamaha 660 / 700R Raptors). Any others, DOT3. probably upgraded in the past 20y to 5.1 tho... but tbh I haven't cared since selling my last moto in the 2010s :p
    • weren't electronic moisture testers back in my day (late '90s - 2010s), and if so, certainly not for $12. Thinking of getting one for the 5G
    • have not seen a single metric motorcycle use DOT5; it's a pretty unpopular fluid in general ime (think Harleys used it for a while). Not sure what genius decided to name it '5.1' rather than '4.1'... but probably results in a population of shadetrees wondering why their '70s muscle-buckets have dragging brakes and a sticking pedal, from bottles of 5 in it (only good thing about 5, is it won't peel your paint off if spilled)
    • almost as if someone designed 5.1 to be used expressly for non-road-legal racecars, knowing the brakes'll get propa-hot, and svc intervals very short and not missed. DOT3's long svc life before needing swapped, is great for those who buy appliances and just put gas in it for 10+ yrs :p
    • lastly... only swap to 5.1 in your DOT3 / 4 vehicle, if you plan on
      • a) swapping it as often as your moisture sensor says to, which'll be a lot, and
      • b) if you're actually going to get your brakes hot regularly in that interval.
    Maybe you cross the Rockies on a particularly infamous pass with a steep grade the other side, commuting to work :p Sure, get 5.1 in your CX-5 and prepare to get dirty (trusting your brakes that many times to a 20-yo fartcan devotee in the local dealer service dept, makes my skin crawl). Otherwise, just a swap to 4 covers just about any sane situation a diligent driver w/ any sense will encounter, and doesn't shorten the svc interval nearly as much.
    If I didn't need 5.1 dropping down the stair-steps of James Street in Seattle, pounding on my race-prepper SV650 down to get to the ferry terminal 5x a week, humid arsecrack of summer... you won't need it in your RAV4 ;)
  4. ETC(SS)
    7,366
    Another one of Toyota's "lifetime fluids."
    They're aptly named because they want the average owner to experience a lifetime of car payments.
  5. Georgina Rudkus
    3,513
    2,503
    Taylors, SC
    Actually, Toyota recommends 24 months brake fluid exchanges.
    It's a dealer money maker. It does no harm to the car. It, however, lightens the owner's wallet.
    The brake fluid marketers state that the remaining container of brake fluid needs to be discarded once the small amount is used.
    This results in user's buying small containers with repeat purchases giving the sellers with a higher profit margin.
    Brake fluid will not continue to absorb moisture in a tightly capped container except the miniscule amount in the air pocket before capping.
    Brake fluid in a tightly capped container does not degrade with age.
    Water vapor us not absorbed through the walls of the container. If that was so, brake fluid would be sold in glass or metal containers.
  6. BiomedO1
    4,171
    2,185
    SacTown, Ca
    The dealership's service writers may recommend 24/mo brake fluid changes; but the OEM manual only states to "check it".
    Can you post or give us a link to a USA OEM Prius manual the states to change the brake fluid every 24 months? I know other OEM's had stated 24-36 months, in their OEM manuals for change intervals.
    FWIW: I do mine every 3-5 years; but I've bought used cars with 150K+ miles and more than 10 years old; the fluid looks like it's never been changed. I'll see floaters and scaling in the reservoir. IMHO; I don't believe these new electronic ABS systems is going to put up with that kind of abuse.
    Just my 2-cents......
    #6 BiomedO1, Mar 16, 2026
  7. Georgina Rudkus
    3,513
    2,503
    Taylors, SC
    What procedure do they recommend when the say, "Check it?"
    I don't often buy used cars. The last one was back in 1987.
    I always buy new at close to the base model and over maintain it, while keeping it for 10-15 years or more,
    Only about 25% if owners religiously even maintain their cars close to that recommended in the owner's manual.
  8. BiomedO1
    4,171
    2,185
    SacTown, Ca
    English is my second language; but I don't know what procedures dealerships use when they "check it". I'm sure there's a written procedure for that, since large scale companies usually has written procedures to prevent lawsuits and is usually the basis for firing someone for not doing their job and/or following such procedures. I do know the difference between "check it" and replace. (ie.. Replace oil & filter every 10K miles.) I'm sure if you didn't do that; you'd VOID your warranty.
    Just saying....
  9. ChapmanF
    18,565
    I just looked through my 2010 Warranty and Maintenance Guide and (unless I missed it) there isn't any instruction in mine to check the brake fluid ever.
    But the question—What procedure do they recommend when the say, "Check it?"—might be on point, given what my Warranty and Maintenance Guide says about engine/inverter coolant (which I've posted about before because it's amusing). My WMG says only to "inspect" Engine/Inverter coolant, and that comes up every 15,000 miles or 18 months.
    Every time it comes up to "inspect" the Engine/Inverter coolant, there's a little raised footnote number, and matches a footnote at the bottom of the page, where it says to refer to the "Explanation of Maintenance Items" at the back of the guide for how to "inspect", and the section at the back goes through draining and refilling the coolant. :)
  10. bisco
    52,401
    The longest I’ve owned a new car without checking or changing the brake fluid is 11 years and 87k.
    No troubles while I had it, but perhaps someone else’s problem down the road?
  11. futurist
    futurist Member
    56
    111
    United States
    2024 Prius
    Not a surprise to me as a former tech... but that's more the rule than the exception, esp as generations pass. Not a diss, just my exp: cars are expressions of lifestyle to younger gens, as long getting hands dirty or learning about cars is kept to bare, pushbutton minimums. Not all, but defo a trend ime. Kudos to all here who aren't in that ballooning global population*.
    Mostly have exp on powersports vehicles vs. cages, as one massively exceeded the other for exp w/ brakes... but leaving brake fluid to moulder that long in any series production vehicle, will probably lead to water pockets somewhere in the system, as the fluid reaches its saturation point. This water will rust / corrode componentry in these pockets wherever they settle, usually low points as water is denser than brake fluid. Doesn't even need to be past the saturation point -- even slightly below it w/ no visible pools, the water content of the fluid can react and corrode, just less than genuine pooled water.
    Have seen brake pistons w/ rings of rust, despite most modern cars (post-EFI, '80s) having brake calipers mounted high and rearward, such that water has a place to pool away from the seals (corner of caliper). Leave that DOT3 too long tho, and this water will touch the pistons and rust -- meaning torn seals once the pads get to a service-limit thickness (also likely when you don't care about your brakes). Then you have a situ where one hard pull will force rust past the seals, shoot old fluid out and get thrown up onto the rotor as a lubricant -- hope this doesn't happen as you're going downhill, because you will fill your shorts. Maybe people were more diligent about their brakes, pre-10-airbags to dull impact of consequences :p
    Also -- hard brake lines are narrow for a reason; it's the least amt of brake fluid necessary to reliably operate properly-maintained brakes, esp in rear -- so when water does stop being absorbed there, it'll do so far quicker than in larger reservoirs of fluid, like the calipers -- thus rusting them internally, threatening catastrophic failure one day... faster in the Rust Belt. (what 'reliably' means, depends on mfr: if you're Porsche, it'll have lots of margin of error baked into the engineering of the brake system. If you're GM or Ford or Mopar, who knows? As those marques have large cadre of exp'd lawyers, enough to justify chiseling safety margins out of suspension and brakes, to save pennies :rolleyes: ).
    I'm of the ilk to maintain my vehicle (as a former tech, no excuse :p ) for both myself and the next guy, as am a devotee to the idea karma's a b****. Maybe your exp doesn't make this cost : benefit worth it, and not criticising that, as cars aren't getting any cheaper. But I sleep much better at night knowing some new parents I'd sold my car to, aren't g onna be balled up over a cliff because I was too lazy to bleed my brakes every few years (usually brake bleed bolts are located where water pools, but only if severely collected -- if any water appears bleeding air from the brakes, you need to swap the fluid, as it's done).
    Same justification for rolling all my windows up and down twice, every trip to the store -- salt air corrodes high-exposure, high-load, low-mass cheap ferrous parts in a window lift mechanism rapidly... cycling keeps the whole mechanism lubed w/ OEM grease much longer, preventing corrosion that kills expensive OEM lift motors (and defers longer, the PITA it takes to replace them). Saves me headache, and also the next guy) ;)
    * love how Finland forces everyone to take very stringent car-knowledge and practical driving courses in order to be licenced for the road, from how to handle black ice at speed to how to change tires and owner-serviceable vehicle fluids. Makes for more baked-in enthusiasts, thus the old motorsports adage 'if you want to win, hire a Finn' :D
    #11 futurist, Mar 16, 2026
    Xterra72, bisco and BiomedO1 like this.
  12. BiomedO1
    4,171
    2,185
    SacTown, Ca
    Again; don't know what's written in their procedures manual; but when it states inspect brakes - I'm assuming they are at least eye-balling the entire braking system and topping-off brake fluid - since it's a safety thing. Under inspect all fluids; footnote states "brake fluid level/condition". Heck; they look at and button-down the floor mats.:rolleyes: That was related to the accelerator pedal law suit a few decades back. When I was feeling frisky; I'd unlock the mat to see if they would catch it during my free oil change interval and check if they just check the box without actually looking. They were 50% on that and I'd do a more through walk-thru before leaving the dealership.
    If that car was an old school hydraulic and vacuum system, you wouldn't have issues until the internal rust popped or caused a leak in one or more of your caliper or brake drum piston seal. Been there, done that in my dad's shop; during my high school days. There was actually spring and seal rebuild kits, so we rebuilt them and honed out all the rust. We could've got new ones and always gave the customer the choice. Less than 10% would opt. for a new assembly. It was usually the people with money that opt'ed for a new assembly; partially out of fear of failure. I was basically free slave labor at the time. I did get to eat.:D:LOL::ROFLMAO::whistle:
    I don't believe those old OEM maintenance manuals mandated a brake fluid change interval or everyone simply ignored it. I know my dad never offered that service; unless someone walked in and wanted it done. Let us know if someone has an OEM manual from a 60's-70's car and if there's a mandated brake fluid change interval. To the best of my recollections; I spotted that change interval in an early 90's OEM manual. That was when I could afford to buy a new car.:(
    #12 BiomedO1, Mar 16, 2026
    futurist likes this.
  13. bisco
    52,401
    it was my 2012 plug in Prius. also, our 2013 hycam went 10 years and 78k without a fluid change. I just follow Toyota's maintenance schedule. I don't think that is a disservice to future owners, but I could be wrong.
    I used to do all my own service, but haven't been under a car in 40 years
    futurist and BiomedO1 like this.
  14. BiomedO1
    4,171
    2,185
    SacTown, Ca
    Another thought could be that the OEM has charged the metal composition of those caliper and brake cylinders, so they don't rust internally anymore. A simple coating over the areas where the seals slide over, would do the trick. You notice how rust rots a car body and frame, but the brake system rust isn't as bad on a car that's more than a decade old. Moisture in the brake lines would simply make them spongie; but they would work for the most part.
    This would only leave the issue of contaminants in the fluid, mechanically jamming up the valves and pump motor in an electronic ABS/traction control braking system.
    #14 BiomedO1, Mar 16, 2026
    bisco and futurist like this.
  15. futurist
    futurist Member
    56
    111
    United States
    2024 Prius
    ^ Agree on both points: system component materials change, and ABS being the present weak link.
    Materials: one of the most obvious change by mfrs of non-performance models (and not expressly endorsed by moi) is polymer as a brake piston material (have only seen it in domestics; no idea if JDM or EU OEMs use them too)...
    Polymers have come a long way. Automatic pistols and military small arms are increasingly dependent on polymer frames and furniture, which was unthinkable a mere two generations ago -- The Vietnam-era Colt M16E1 and its derivatives was derided for decades for its early versions' fragility to a military raised on wood stocks... but now everything uses it. My own sidearm has one, and have enjoyed its light weight; comfy and functional shapes very expensive to mill in metal; high capacity to take shock deformation and remain stable enough for high accuracy; and overall durability in flung all over the place in IPSC competition. On motos, thermoplastic tanks have replaced metal ones as in automobiles, given the best place for its fuel weight is below and forward of the seat, inside the frame (for litigation reasons too)... which'd be difficult and limiting to make for series production in sheet metal. As with all polymer products, the ability to make it in far more radical-shaped dies cheaply, is why it's taken over roles formerly held by machined metal.
    Thing about thermoplastics I don't like... is its tendency to 1) weaken w/ high temp, and 2) higher expansion in volume, doing so. Harder to use polymer as a heat sink and expect it to maintain its properties as temp goes up. Can be engineered around to some extent but never as well as the Gucci option of milled stainless or aluminium.
    This is where plastic pistons in brake calipers and I don't sync. Versus the same component made with steel or aluminium (where a literal shim-under-bucket-tappet-like design can last the lifetime of the car if maintained properly)... plastic has to be made much thicker (still a bucket shape but 6mm wall thickness vs. 2mm) for simple structural integrity, often needing metal supports anyway... and is also far less wear-resistant vs. esp steel or aluminium alloys... so is cynically contented to last much less-long and cost less than metal components, but long enough to last thru the first owner :rolleyes:
    Add to that, the rapid pulsing nature of ABS operation means polymer pistons get compressed by repeated shock thru non-compressible fluid, onto pads on rotors that warp and also pulse. Polymer cannot resist deformation like metal can... but may not matter to the mfr, if performance degradation and reaching service limits is the second owner's problem.
    ABS: antilock braking's miraculous and has saved my dumbarse younger self's bacon in cars more times than I can count... mostly in winter conditions. But have also driven many vehicles with no ABS enough in batshirt conditions, to see why it's valuable.
    However, ABS esp 4-channel modern ones depend on a thing, to work at full potential: a fluid that can transmit its control thru narrow passages in an ABS solenoid body and pressure pump. This means a lot of complex passages milled in aluminium and through valving... so plenty of places for moisture to hide and stop lubricating / resisting corrosion.
    All ABS systems have fail-safes designed in, so in case of failure your system devolves into dumb brakes. But not changing fluid when its saturated w/ water, will hasten this moment in time... possibly when you need it most to be there :coffee:
  16. bisco
    52,401
    I wonder if regenerative braking helps in any way?
  17. Mendel Leisk
    41,926
    Well, Toyota USA. Toyota Canada recommends to change brake fluid every 3 years or 48k kms, whichever comes first. This was not the case when we bought our 2010, but at least as of 2014 model year they've taken this stance.
    As of gen 3 it's a doable DIY, that doesn't require Techstream. (See attached)
  18. Trollbait
    12,689
    For typical driving on public roads, I think climate is a bigger factor for the fluid's life.
  19. futurist
    futurist Member
    56
    111
    United States
    2024 Prius
    Regen can prevent one from using the brakes hard enough to get into hydraulic braking... but ime, you end up using it anyway -- probably by design -- to avoid rust forming on the surface of the rotor. My 5G's rotors aren't as pristine fresh surface as my previous, ICE-only car... but given I try to use partial (regen) braking as much as possible to harvest battery level coming to stops... they should be much rustier than they are.
    My take is, Toyota spec'd the regen system to easily (and near-seamlessly -- near being emphasis) operate within the range of initial, first-touch hydraulic braking. IOW just on the edge of it, so the rotor surface is maintained -- a crusty rotor doesn't provide much stopping power and contaminates the pad surface. Would be absurd to think Toyota engineers had overlooked this since '98...
    But back to fluid svc... all brake systems cannot be hermetically-sealed, so will absorb moisture directly from ambient air. They must do this, because when pads wear, air must be allowed to enter the fluid reservoir to replace displaced fluid. This air has to bring with it moisture, more or less depending on where you live -- esp if you have to commute in winters that hover in the 30 - 40F range. Remember that moisture level and fluid colour do not necessarily correspond... so even in a Prius, check moisture level in the fluid, to prevent corrosion internal to cylinder / booster, ABS system, lines, and calipers :coffee:
    Bonus GET: am wondering how Toyota designed a hydraulic braking system to use regen for slowing down initially, then hydraulic brakes kicking in, as near-seamlessly as they do (not even mentioning how such a system would know to use hydraulic braking at certain points, to clean rotor surface) My guess would be exactly the way ABS controls both anti-lock and traction-control... but instead bypassing initial brake application until a certain point. Old Prius brakes were criticised early on for their poor brake feel... so the system most modifiable to as many variables as possible -- an electronically-controlled one -- would have to be tailored to do so. The only other way I could see to do this, is with brake piston seals that allow more piston travel without breaking seal. This makes little sense, as all ABS including Toyota HEV systems, have to have a fail-safe defaulting to dumb brakes. Making the hard parts too fundamentally different from ICE brakes, would risk all sorts of nightmare fuel for mfrs :unsure:
    If true... this doubles down on keep your fluid fresh w/ as little water in it as possible, because now you have extra work given to the ABS system, thus the fluid flowing through it, that tiny passages will tolerate even less corrosion in. Just because you luck out selling your ABS-equipped Toyota 80K+ w/o a fluid change, doesn't mean it's not on the verge of endangering someone's life, or at least emptying their wallet to be truly roadworthy. $12 for a moisture sensor, at least gives a non-ambiguous answer to whether to service your brake system ;)
  20. ETC(SS)
    7,366
    I use Mk-1 Mod-0 eyeballs.
    They're more expensive than $12.
    Priceless, actually - but I have two of them.
