Cloyes Gear Timing Chain
Discussion in 'Gen 3 Prius Main Forum' started by Jondoe2154, Mar 12, 2026 at 3:16 PM.
  1. Jondoe2154
    Jondoe2154 New Member
    Tuesday
    Anyone on here had any experience with Cloyes? Called Toyota just the chain is over 300 and the whole Cloyes kit(with tensioner and sprockets) is around 200. I have read mixed reviews. I haven't cracked the engine open yet but feel pretty sure based on the codes it threw. Also I'm on a timeline and would like to have the parts in hand and Toyota told me that the chain is non-returnable if it turns out to be something else. At 230k miles, I'm tempted to go with the Cloyes even with the mixed reviews. Thoughts?
  2. PriusCamper
    PriusCamper Senior Member
    13,020
    5,291
    Pacific Northwest, USA
    While back in the day most all vehicles weak link was the timing chain, I've never heard of that on here? You sure it's not ignition coils or plugs or vacuum hose or head gasket? Those are way more common.
    What are your symptoms?
  3. Tombukt2
    13,348
    2,402
    That company used to be a very good company . You must be getting the timing chain and cam gear are not aligning I can't remember the code usualky changing oil staves off code for about 4.5K miles . I've my work car doing this now . It is timing chain stretch. This engines at 530K I can about guarantee it.
  4. Jondoe2154
    Tuesday
    P016 code. felt the misfires. Plugs and coils changed 20k ago when I did the head job.
    Changed cam shaft position sensor, crankshaft position sensor and VVT valve.
    After it felt a little better but still felt like I was running down a gear. No engine reving just felt slow. MPG was down to 35 and then today sounded like it threw it. Good bit of clanking.
  5. Jondoe2154
    Tuesday
    PriusCamper likes this.
  6. Jondoe2154
    Tuesday
    Found it. I jumped time. So weird the woodruff key that holds the sprocket on the crankshaft broke.
  7. PriusCamper
    13,020
    5,291
    Maybe take apart and inspect to ensure its not one tooth off before you spend money on a non-refundable chain?
  8. Jondoe2154
    Tuesday
  9. PriusCamper
    13,020
    5,291
    Congrats! Easier to replace a damaged woodruff key than a damaged slot that it sits in!
  10. Tombukt2
    13,348
    2,402
    Is the slot ok ? If you can getva new one on they're and tighten it up good .
  11. Jondoe2154
    Tuesday
    We’ll have to replace the sprocket as well due to the broken one wear the slot. Hopefully when we fire her up that’s it and there no damaged valve.
  12. Jondoe2154
    Tuesday
    No. I have to replace the back sprocket for the lower crankshaft timing chain. I believe the shaft itself is good though
  13. Tombukt2
    13,348
    2,402
  14. Tombukt2
    13,348
    2,402
    Well you need to check that now while you can . It's an interference design
  15. Jondoe2154
    Tuesday
    Past my current expertise
