Which water pump? AISIN WPT 190 or WPT 190-A
Discussion in 'Gen 3 Prius Main Forum' started by ToyotaCoyotta, May 21, 2025.
  1. ToyotaCoyotta
    ToyotaCoyotta Junior Member
    56
    Lithuania
    Hello,
    Planning to change the water pump to avoid head gasket issues
    How do I know which one I can pick to be safe?
    AISIN WPT 190 is 150+
    while
    AISIN WPT 190-A is 250$+
  2. StarCaller
    StarCaller Senior Member
    1,279
    730
    Cedar Crest, NM, USA
    For piece of mind I bought the real TOYOTA one /
    ASRDogman and Brian1954 like this.
  3. Tombukt2
    13,355
    2,405
    I've just replaced the impeller in the two that I had that are now blown up and gone but the pumps are still here laying on the ground not sure what the a is about I don't know if I really care. It's a MAG drive type pump so unless something burns up in the housing usually all that's happened is the skin is peeling off the impeller you get a new impeller strip that one whatever and then it'll spin again or a new one will spin in its place the housing usually doesn't get messed up it's the impeller so replace of it what you'd like I guess we're just trying to keep the water moving that's all not too much heavy science about it.
  4. Mendel Leisk
    41,873
    ToyotaCoyotta likes this.
  5. ToyotaCoyotta
    56
    Lithuania
    Have you bought this Pump before ? can’t find any reviews about this specific item from this seller
  6. Mendel Leisk
    41,873
    No, but it’s the option I’ll likely go with, once we’re “close” to 100k miles. Currently at 104k kms, may never get there.
  7. rjparker
    10,473
    6,567
  8. adrtho4
    adrtho4 Member
    70
    26
    Houston, TX
    So I bought the Aisin WPT 190. It's been running since July last year but I got a code P261C and I thought it was the inverter water pump but folks here tells me that it's the engine water pump.
    I have to really confirm which one it is. Hopefully it's the inverter because from all my research the WPT 190 is a solid pump.
    I'll report back with my findings.
  9. ChapmanF
    18,513
    The code is for the engine water pump circuit.
    A problem with the circuit isn't necessarily in the pump. If there's a problem after putting a brand-new pump in, then the problem with the circuit probably isn't in the pump.
    What was the reason for replacing the pump in July last year?
  10. adrtho4
    adrtho4 Member
    70
    26
    Houston, TX
    I had a headgasket blow that needed to be replaced. Sites and suggestion were to also replace the water pump, clean egr, replace thermostat so I did those as well.
  11. Mendel Leisk
    41,873
    Lots of reports of the 3rd gen water pump failing, around 150k miles. I don't think Toyota's weighed in, but it seems prudent to replace every 100k miles. Thermostats get sluggish, their gaskets fray and harden, so in for a penny?
    adrtho4 likes this.
  12. adrtho4
    adrtho4 Member
    70
    26
    Houston, TX
    Yeah. Got all of that done. I just hope I don’t have to do it again. We’ll see.
