The 15 pound carry in car tire changing car jack
Discussion in 'Fred's House of Pancakes' started by Georgina Rudkus, Mar 16, 2026 at 4:00 PM.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,511
    2,494
    Taylors, SC
    Weighs less than 15 pounds, lifts 1.5 tons to 12 inches at the pinch weld allowing 1-1/2 inches of the tire contact surface off the ground. Tested to allow 1-1/2 inches under the pinch weld with the tire fully deflated.
    A special custom pinch weld adapter made of UHMW Spectra cushions and provides a secure no damage contact with the pinch weld.
    jack on scale.jpg jack w adapter.jpg adapter on jack.jpg lifted position 2.jpg
    ColoradoBoo, futurist and bisco like this.
  2. Templeton
    Templeton Active Member
    327
    118
    usa
    2024 Prius Prime
    SE
    Looks good. Got a link to the jack, and to the pinch weld adapter?
  3. Georgina Rudkus
    3,511
    2,494
    Taylors, SC
    It is a custom one off prototype.
    My friend is looking at more and less expensive pinch weld adapters.
    He says that others based on the concept are already available but will allow me to post the link here.
    He is also considering selling the jack with the attached adapter. It is as I said, is a one off prototype.
  4. Templeton
    327
    118
    usa
    2024 Prius Prime
    SE
    Thanks, but just to clarify, the jack is a one off prototype, or the pinch weld adapter is a one off prototype?
    If others based on the concept are already available, can you post the link to those? Thanks.
  5. Georgina Rudkus
    3,511
    2,494
    Taylors, SC
    The pinch weld adapter is a prototype.
    The jack is a standard type, but the adapter is closely machined and adapted to fit the particular manufacturer's jack.
    The jack is the absolutely best as for weight and size for his intended design purpose.
    He's working on a universal adapter to fit most all of the compact trolley jacks to bring the price down.
  6. Templeton
    327
    118
    usa
    2024 Prius Prime
    SE
    Excellent. Can you post the brand/model of the jack?
  7. Georgina Rudkus
    3,511
    2,494
    Taylors, SC
  8. Templeton
    327
    118
    usa
    2024 Prius Prime
    SE
    Thanks.
    Tell your friend that there might be prius drivers that want his pinch weld adapter!
    futurist likes this.
  9. Georgina Rudkus
    3,511
    2,494
    Taylors, SC
    The jack costs $35-40. He's looking at about $30 delivered for the pinch weld adapter. It requires no installation other than removing the swivel cup by prying off the snap ring with snap ring pliers or a large screwdriver.
    Templeton likes this.
  10. Templeton
    327
    118
    usa
    2024 Prius Prime
    SE
    Is there a way to get more info about his adapters and if I can use them on other jacks out there?
  11. Georgina Rudkus
    3,511
    2,494
    Taylors, SC
    He won't post on PriusChat, because he was banned a few years ago when the vendors on the now defunct PriusChat Shop vendors complained that his innovations were better than theirs.
    He says, just search other e commerce sites for "pinch weld adapters."
    He has an extensive line for Bendpak Quickjacks, Rennstands, floor jacks and other jack stands.
    He's also the exclusive provider of Fisker Ocean jack point adapters.
  12. Georgina Rudkus
    3,511
    2,494
    Taylors, SC
    Also check your profile post.
  13. Templeton
    327
    118
    usa
    2024 Prius Prime
    SE
    Thanks, I saw that, and I posted on your profile.
    Does this guy have a website or ebay store or something similar?
  14. ChapmanF
    18,526
    that sounds a lot like the kind of story that could have a second side that would sound different
  15. Mendel Leisk
    41,882
    I'll stick with scissor jack, and a small square of 3/4" plywood, to serve as a stable base if I'm pulled over on a dirt shoulder. Wrestling with a floor jack intended for use on concrete slab, on a dirt shoulder, doesn't seem better. To make it work I think you'd want to also bring a large sheet of similar plywood. Considering the odds of a flat, I'm for being prepared, but not cargo-cult prepared.
    I do wish Toyota picked a better design of scissor jack, but it'll do.
  16. Georgina Rudkus
    3,511
    2,494
    Taylors, SC
    Not so; exactly as stated. He responded to inquiries within the same day and shipped his custom adapters that he made as a hobby within one day. His hobby was his passion, because he made things for his own use and wanted just to pass on his useful ideas to others.
    Those who had experience with the PriusChat Shop made many inquiries about what happened to their order.
    I was there. You were not.
    #16 Georgina Rudkus, Mar 17, 2026 at 1:54 PM
  17. Georgina Rudkus
    3,511
    2,494
    Taylors, SC
    Not an issue. I would sacrifice a tire rather than my safety.
    I'll drive to a safe place, where there is pavement to use the floor jack.
    I did so with the last blowout a few months ago.
    I've used both types of jacks in previous roadside tire changes.
    The mini trolley floor jack is so much easier, safer and convenient.
    The scissors jack and the large piece of plywood would likely take up more space and weigh more than the less than 15 pounds of the trolley jack. You can just grab the trolley jack out of the trunk with the convenient top handle with the other handle holding the tire wrench and the jack's handle.
    #17 Georgina Rudkus, Mar 17, 2026 at 2:01 PM
  18. Mendel Leisk
    41,882
    For the scissor jack, the size of plywood needed for use on loose earth) is maybe 6" square.
    It's an uphill battle Georgina, trying to convince me the scissor jack, which sits in the tool cradle atop the spare and has to come out to access the spare, is more of a handful than a floor jack.
    #18 Mendel Leisk, Mar 17, 2026 at 3:26 PM
    Trollbait likes this.
  19. ChapmanF
    18,526
    So you're saying that the moderator(s) who did the banning, if asked, and the other PC Shop vendors who complained, if asked, would agree that "his innovations were better than theirs" was the entire substance of their complaint(s)?
  20. Georgina Rudkus
    3,511
    2,494
    Taylors, SC
    Exactly
