Repair Questions for the group - 2007 Prius
Discussion in 'Gen 2 Prius Main Forum' started by AmandaC, Mar 10, 2026.
Tags:
  1. AmandaC
    AmandaC Junior Member
    17
    Washington DC
    Hi! I'd love the feedback of anyone on the following repairs recommendations the shop gave me today. I've had my 2007 Prius since 2011 so very familiar with its history. This shop was great on a repair last year but this time I received a text with a laundry list of expensive repairs and I had to call and ask them to walk me through each on of these items. I just get very leerily when a place recommends a long list of maintenance/repair items worth thousands of dollars and they didn't seem too thrilled in explaining to me what all of the items were like I was just going to drop $5000 in repairs on a whim. I told them I can only afford what is absolutely necessary to be done today. Which is true.
    I took it to the shop because I went to get my state safety/emissions inspection and the inspector heard my car and said you have an exhaust leak so I drove it to the mechanic right after.
    Exhaust leak where muffler and midpipe connect is what the mechanic has listed and basically saying all of the exhaust components(i didn't take a photo of the list but it was the muffler and like 5+ things need to be replaced - a $1300 repair. I had to agree to this because my safety and emission inspection is due before I can renew my car registration and don't have time to shop around. Is that normal for an exhaust leak? I can update with all of the things replaced when I get it.
    Control arms - it says cracked bushings. They said within a year to take care of this.
    Sway bar links leaking. No explanation for this one - I actually didn't see it on the repair quote - just on the findings after I got off the phone with them.
    Also recommended a transmission fluid flush and some other break fluid flush.
    I don't DIY anything on my except like windshield wipes and I'm going to handle the air filter:).
    Thank You for reading and your thoughts!
  2. PriusCamper
    PriusCamper Senior Member
    13,024
    5,293
    Pacific Northwest, USA
    Auto Mechanics do this with older cars they don't want to work on anymore because a repair estimate costing more than the value of the car usually gets them out of ever having to work on it again.
    To be clear, you took your car to the wrong place... If you have an exhaust leak, go to a muffler shop and have them fix it with a little welding, or maybe simply replace the flange gasket. Your auto repair shop was more interested in price gouging you to replace an entire exhaust system rather than patch the leak.
    As for the other problems, they're all fairly normal for a 19 year old car and no need to spend money on anything other than what safety / emissions inspection requires you to fix.
    Intuitionx2 and T.S. Elliot like this.
  3. BiomedO1
    4,107
    2,150
    SacTown, Ca
    IMHO; I would take it to a muffler shop for a repair; if that's the only thing holding-up the safety inspection. $1300 seems steep and maybe a new exhaust system. The rest of it sounds and smells a bit fishy. Leaky sway bar links - usually bushings??? Did they include a few muffler bearings to top it off too?:(:mad::sleep:
    In my state; you can just pay the registration fee, in order to avoid the late penalty; but won't receive your registration stickers (tags) until the car clears all it hurtles. Sometimes all you need is a few extra weeks or a month to take care of everything - our DMV understands this.
    Good Luck....
  4. bisco
    52,366
    how many miles on her?
  5. highmilesgarage
    highmilesgarage Active Member
    493
    182
    Kansas City
    exactly.. safety inspections has become a milking cow for shops that does the inspection. Just have it inspected and go with what the safety inspection report. I prefer a "safety inspection" shop instead of a dealer or major repair shop.
  6. pasadena_commut
    pasadena_commut Senior Member
    2,814
    840
    Southern California
    I once took a car in to a shop I had not used before for an oil change because the usual shop didn't have an opening and I needed to go on a trip. The new shop did a "complementary inspection" where they found many thousands of dollars of work that needed to be done. On returning from the trip took the list to our usual shop to see how much of it was actually needed. The mechanic's answer - none of it.
    BiomedO1 likes this.
  7. Intuitionx2
    Intuitionx2 New Member
    usa
    Muffler shop.
    Brake fluid needs changing or you risk problems. Every 2-4 years. The fluid naturally absorbs water. This water causes internal damage (rust, etc,) the abs system is very expensive to repair.
    The control arms once the bushings start cracking yes. Those bushings affect tire wear. If your tires are wearing evenly your ok.
  8. highmilesgarage
    493
    182
    Kansas City
    2-4 years is highly exaggerated, I've owned cars that hasn't done any brake fluid changes for more than 10 years and they are fine. ABS units on the Prius/Camry are known to fail for some random reasons. I have a Prius that I've never changed the fluid for more than 6 years, never done a brake job. I've seen cars that has seized calipers because the bracket for the hoses rusted out and compressed the lines (Honda/Ford) and that's not the issue with the brake fluid. Usually surface cracks on the bushings are not really a concern, it's when the bushings separate and causes your control arms to move and cause knocking sounds. Dealers will usually spot this as needing replacement but to be honest I told my friends don't listen to those guys, it's been years and it's still ok. I've seen worst control arm bushing on BMWs/Volvo that needed attention than on the Prius (it ain't a driving machine)
  9. PriusCamper
    13,024
    5,293
    The brake booster pump is more likely to fail when you change the fluid and modern day fluid doesn't absorb water like it did back in the day.
  10. ChapmanF
    18,517
    My first time hearing that. What's it based on?
