I've seen both sides to this argument, yes put them in, no don't do it (for various reasons) Let me throw my two cents into this debate. I bought my car back in May 2015 and it had 4 miles on it, it was brand spanking new and it is a beauty! I put custom wheels on my car, tinted the windows with limo quality tint and put a $17,000 JL Audio sound system in my car including a twin 10" sub in the luggage compartment. Earlier this month, my drivers side high beam light went out, two days later the low beam, so I started researching what to do about it. I decided to go with LED headlights. So I ordered the following, and I highly recommend Farren termitor LED lights, you can find them on Amazon! Your low beams are H11 and your high beams are 9005 / HB3. TRUST ME these are a game changer!! The install (if you do it yourself) takes about 20-30 minutes and let me tell you, it's a world of difference!! These lights have the flicker error driver built into the base of the unit and there's a 15000rpm fan to keep the LED circuits cool so they last longer. You can't even hear them in the cabin. The light color is 6500k and because of the way the paint on the roads is made, LED lights cause the paint to almost glow and they're infinitely easier to see, even if the paint is faded. The reflectors on the railings are easier to see, and in the rain, it cuts through the rain and fog as if it's not even there...it's easier to see deer, moose, even rabbits that hop across the road! These lights are incredible, and anyone who tells you to not put LED headlights in your car needs to go chew on rocks, pound sand, or jump off the edge of the world!! I highly recommend you swap out those dated halogen bulbs for the lights I linked up above....and for an added bonus, there's a pair of gloves in the box that are safe for handling the bulbs you remove from the headlight assemblies, because if you touch them with your bare hands, you could cause the glass to crack or burn your skin or other nasty things.... Trust me, change your lights to LED and you'll be able to drive safer at night because you'll finally be able to see!!!
Does look that way, doesn't it? I think a good number of members here are already enjoying LED retrofit bulbs, even despite knowing that technically none are street legal in the US. There may be even more members who are waiting sort of eagerly for NHTSA to finish the rulemaking about what will qualify as a street-legal LED retrofit bulb, so they can buy those.
I was pretty anti LED, but I feel like sticking with halogens is basically unilateral disarmament in the headlight brightness war. On cars with projector low beams, LED aftermarket bulbs can still give a sharp cutoff, so I don't think your glare is worse than modern cars with factory LEDs and way less than Joe Bubba who tossed "80,000 lumens" in the reflector low beams and fog lights of his Ram 1500 with leveling kit. I bought new eBay cheap headlights for my 2015 and went right for the Hikari Wings on the low beams and Katana high beams (saving a little vs Hikari). So far I'm happy with them, put the same setup in our pilot. One thing to be mindful of: old projector headlights can be weak for a number of reasons: clouding, grime on the projector lens, and flaking/burning/corrosion of the reflector inside the projector. Corrosion is what was wrong with my 2015, and they were HORRIBLE.
I know its all fun and games with comments like grits and others assuming. I must say I myself use this brand of LEDs Much brighter than my previous LEDs. I have the set that is adjustable from 3500-6500K Sorry no promo code from me grit just an honest comment.
If you put them in and confirm, on a white wall or something, that they have a good sharp cutoff, and you adjust the headlights properly to have the cutoff in the right place, you should not be blinding oncoming drivers.
I like your take on this. Not just Joe Bubba but even brand new SUVs/trucks with laser headlights are just as bad at blinding you.
We've got the stock, from-the-factory LED's. Owner's Manual has info on changing the regular headlight bulbs, and for the LED's it just says something like "see your dealership". Think that means replace them, for just over a grand CDN, apiece... Headlamp for Toyota Prius ZVW30L-AHXEBK, 04.2009 - 12.2011 - Toyota North America Car and Auto Spare Parts - Genuine Online Car Parts Catalogue - Amayama
Right, the OEM LED headlamps are purpose-built assemblies with non-replaceable LEDs in them—of course engineered by Toyota from the ground up to have the right beam distribution and coverage. What a lot of people here are talking about is replacing the halogen low-beam bulb in the OEM halogen projector assembly with an LED retrofit bulb. For that to produce anything like the right beam, the retrofit bulb has to be made very much like the halogen it's replacing, with very bright but very small LED chips no bigger than the halogen filament and located exactly where the halogen filament is. They have gotten pretty good at achieving that. The chief remaining problem is that none of them can be considered street legal in the US, until NHTSA finishes drafting and adopting a rule saying how to test and decide which ones comply. It's not that they haven't been working on such a rule; they have been, since well before the pandemic. I just don't think anything has seen the light of day yet; first the pandemic slowed them down, and more recently I suspect a sizeable fraction of the people working on it may have been DOGEd. Anyway, as far as I know there is no such rule yet, so it's kind of up to you to decide if you've found a set good enough to drive with, and, no matter what set that is, be ready in case a grumpy police officer ever chooses to ding you for them.
