Noise coming from under the hood intermittently
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jotowers, Mar 4, 2026.
  1. Jotowers
    Jotowers New Member
    Fresno CA
    https://photos.app.goo.gl/P7HVWZVdPFse9o3B7
  2. Jotowers
    Jotowers New Member
    Fresno CA
  3. Jotowers
    Jotowers New Member
    Fresno CA
    The heater works, I see coolant moving as well. This is what it does occasionally https://photos.app.goo.gl/KY2saUddZ4Age5qx9
  4. Jotowers
    Jotowers New Member
    Fresno CA
  5. Jotowers
    Jotowers New Member
    Fresno CA
    2009 w/222k. Coming from the inverter pump or near that area. There is turbulence in the inverter tank and I can feel it vibrate so does this rule out the pump? It only happens once a month or so and will last about 30 seconds to a minute. Please advise tia
    https://photos.app.goo.gl/7CfdKd1HyEFBGif58
  6. PriusCamper
    PriusCamper Senior Member
    13,168
    5,323
    Pacific Northwest, USA
    First see if you can get any air to come out of the air bleeder valve... There's lots of info on here and on Youtube if you need to learn how to do that.
    Jotowers likes this.
  7. Jotowers
    Jotowers New Member
    Fresno CA
    I topped off both coolants since they were both on the low side. I then burped it. Unfortunately the noise is still happening and I feel it's more frequent now that it's summer. Not sure if it's a coincidence. Yesterday when it happened it went on for about 5 mins, off and on. I was able to capture it on video
    https://photos.app.goo.gl/hL4UfRaHNyeTka9T8
  8. pasadena_commut
    pasadena_commut Senior Member
    2,923
    880
    Southern California
    (Note to others - after clicking on the link in post 27 click on the video to cause the video to play in such a manner that you can hear it. When it autoplays there is no sound.)
    That sounds like a 3 way valve to me. A home mechanic can change one but it is a bit of a PITA because things are very tight in that vicinity. Here is the first of a 2 part series showing how to do this replacement:
    If you don't want to tack this yourself find a mechanic who works on the Prius to do it. Rather than a dealer, who will charge more than the mechanic. Wherever and however it is done, use the OEM part.
  9. Jotowers
    Jotowers New Member
    Fresno CA
    I've researched it and I think you're right. The inverter pump was replaced by the previous owner at Toyota dealership (i have the records) in 2021 , 35k miles ago but didn't do the 3 way valve. I'm gonna watch the video and hopefully it's something I can tackle.
    Also since I don't have any check engine lights, is this something I can wait a bit on? Or should I look into immediately doing it?
    #29 Jotowers, Mar 25, 2026
  10. pasadena_commut
    2,923
    880
    Southern California
    You can wait. I think even when it fails the car is still OK to drive, it might not have working heat though. That should not be a problem for another half year. Since you are in California it may be that it won't pass smog with that code set.
    If you do it yourself having a helper can be valuable. Toyota placed this valve as if they intended to make it a PITA to replace.
