Replaced LE light gray cloth with Limited black leather
Discussion in 'Gen 5 Prius Accessories and Modifications' started by soft_r, Mar 20, 2026 at 5:20 PM.
  1. soft_r
    soft_r Active Member
    187
    152
    Beverly Hills
    2024 Prius
    4 bolts, 2 clips, very easy. Vacuumed up what little debris and dust there was and wiped down anywhere that looked like it needed it. Couldn't find a listed torque spec so I went with 27ft/lb as per the front seat rail bolt spec. This is a 10 minute job.
    Really wanted the black leather interior but it wasn't happening as far as what dealerships near me were being allotted at the time I was looking to buy so I settled with the light cloth interior. And after my first oil change where the tech smudged oil or something on the rear seat cushion and then cleaning it left this weird water stain, I've been pretty locked into the idea of replacing the cloth seats.
    Picked up a full rear set from a wrecked one off ebay for cheap and they fit just fine.
    Ignore the wire runs, redoing some things in the coming weeks. Replacing with 16awg and running it all left side, away from HV line (not that it's currently picking up interference but might as well run it correctly since I'm replacing it).
  2. VelvetFoot
    VelvetFoot Active Member
    1,192
    466
    New York State
    2026 Prius
    Nice!
    So, you replaced just the rear so far, or the fronts too? You had some seat covers on the front as I recall.
    I just didn't like the oem gray cloth. I put some nice pleather covers, front and back and like them. They clean up well, and that's been my experience in MINI and BMW-their oem pleather is nice too. Wasn't a 10 minute job though.
    There was a little thing I had to figure out to get the middle belt off, as I recall.
    A plus about the covers versus oem, is that the cushions seem thin. The covers MAY add a little body to it, but who knows.
    Anyway, if you don't have the fronts, get looking! :)
  3. soft_r
    187
    152
    Beverly Hills
    2024 Prius
    Fronts I'm leaving as is. I haven't even looked but I'm assuming most coming from wrecks will have the airbags blown. And even if not, with the airbag tech in the seat and everything else I just expect that the cost will be prohibitive. I can just slap some new covers on the fronts and be fine with that.
  4. VelvetFoot
    1,192
    466
    New York State
    2026 Prius
    I didn't think there were airbags in the seats; sensors I thought were under the seat. Of course, seat heat would be nice....here anyway.
    I really like the covers I put on.
    Upholstery/Seat Covers ? | PriusChat
  5. LRO
    LRO Junior Member
    60
    United States
    2024 Prius Prime
    XSE Premium
    I'm not doing any deep dive or commentary here but there are SRS side airbags inside the front and rear passenger seats that run along the outer perimeter of the seats that I believe deploy through breakaway seams in the stitching. So, perhaps, seat covers need to accommodate for that? (rears are not in the seats). Page 30 onward of your 2026 owner's guide describes/shows it and Page 35 has a warning about seat covers. Be safe.
    mingc likes this.
