Cylinders misfire while in park in idle only
Discussion in 'Prius v Technical Discussion' started by robrob, Mar 13, 2026.
  1. robrob
    robrob New Member
    West Central IL
    2012 Prius V 230,000 miles. New head gasket 55,000 miles ago. Just completed 2nd head gasket with new PCV, MAF sensor, cleaned both the EGR cooler and valve, cleaned out the intake and all it's passages, and cleaned the fuel injectors. I was careful with the timing chain install. Paid close attention to NutsaboutBolts and the Car Care Nut videos both the first HG change and this one. When I first started the engine in maintenance mode, it was rough for about 10 secs and smoothed out for about 5 minutes after that. It slowly started to misfire then all hell broke loose. Now it misfires with codes for cylinders 1, 3, and 4. Before the HG change this time the misfires were with 3 and 4 with bright white sweet smelling exhaust.
    It only is rough when in idle and park. Shift to neutral and it smooths out. Give it gas in park and neutral and it stays smooth. It's up on jacks - I put it in drive without gas and it's rough but not nearly as bad. I give it some gas and it smooths out. On top of this now I have a really bad parasitic draw where I can watch the voltage on a digital meter drop pretty quick. I disconnected the battery and it held the charge. There were mice in the car because it sat for several weeks when the weather was near zero or snowing. My kids leaving their left over snacks in it didn't help that. The mice were taken care of promptly but may have chewed some wires.
    I did try the EGR valve troubleshooting step from the Car Care Nut by inserting and securing a metal scraper between the valve and hard pipe flange. Sounded like it was going to solve it for a quick second but then really didn't change at all. Thanks all for your input. I used this forum quite a bit while trying to troubleshoot it. But I may have missed something. Thanks again!
  2. wafwat
    wafwat Junior Member
    28
    Gulfport, MS
    2016 Prius v wagon
    Car Care Nut recently had a video where the crank sensor was causing misfire at idle on a Lexus.
  3. ChapmanF
    18,532
    The only change there is that 'idle' in park isn't always idle. The car can be charging the battery, which means the engine still turns at idle RPM, but under load. Shifting to neutral takes the load off.
    So this boils down to a misfiring-worse-under-load issue.
    Air_Boss and BiomedO1 like this.
  4. rjparker
    10,491
    6,578
    Quite frankly, I would hope this engine is not an excessive oil burner, has not overheated while continuing to drive or does not have a bent rod or warped head.
    Otherwise...
    Hopefully it was an oem or Denso maf. Others almost never work well. I would put the old one on as a test.
    You should focus on the parasitic draw, assuming it is real, since it could also lead to your misfire problem. First thing is to actually measure the parasitic draw. The car has to be off with doors and hatch closed for about ten minutes. Series connect an ampmeter function of a multimeter at the negative battery terminal, remembering the hatch must be closed after hook up. If it is a major draw (maybe greater than 100 ma), isolation with millivolt readings across fuses may be possible.
    The chart below shows how much of your measured parasitic draw is coming from a given fuse.
    If this sounds difficult and you have little experience in this area, get help.
    #4 rjparker, Mar 13, 2026
    BiomedO1 likes this.
  5. BiomedO1
    4,116
    2,159
    SacTown, Ca
    Did you check the block n head for warp? Check and compare piston height for slightly bent rods? You didn't replace the chain or tensioner, because there's undoubtedly some chain stretch @ 200K+ miles. A head gasket job; if done properly - should last more than 50K miles; so something is definitely off.
    Do a compression and leak-down test to see where you are on the engine repair. Chewed wires can cause weak spark; but if that was the case - accelerating the motor wouldn't settle-down the misfire, because your working the coils harder. Faster RPM = more sparks/min.. I'm leaning more towards a load issue, based on what was typed above. Don't get me wrong; the electrical issue still needs to be addressed - the real question is; how much time and money are you willing to spend on it?
    Just my 2-cents....
  6. robrob
    robrob New Member
    West Central IL
    Thanks all for your feedback. The engine has never burned through oil or been overheated. The I did take the head to a reputable machine shop, several local dealerships use them for their work. It was fine so I did not formally check the block thinking the aluminum head would show first ... maybe I'm wrong on that. I just pulled the spark plugs to check for a bent rod, they all matched up. Plugs 2 and 3 had oil in the well, the coils were still dry so the oil wasn't shorting them. Did not appear that oil was leaking from the new rings at the cover. I used an endoscope and found both 2 and 3 cylinders were wet with oil. Will oil be pushed up through the spark plug threads and gaskets if they're not cracked/damaged on either the plugs or threads on the head? Going to get a leak down test kit and check for bad rings. If I have to tear this apart again, I'll inspect all the wire connectors and wiring and tackle the parasitic draw if the engine ends up ok.
  7. robrob
    robrob New Member
    West Central IL
    I replaced the off-brand MAF with a Denso and found the battery was bad, not a parasitic draw. Did a leak down test with a cold engine and each cylinder only lost about 4-5 pounds. The car starts and runs smooth for about 2 minutes then starts to misfire. Again only in idle and park. Give a little gas or put it in neutral and it smoothes out. Front rt wheel is still off. A couple of you have mentioned it being an issue under load. I understand that to a point but wouldn't giving it gas increase the load? Or is the increase in rpm's different than an actual load. I have almost 30 years in aviation maint. both military and civilian. I can troubleshoot turbine engines but this is proving a little different. I appreciate your help.
  8. ChapmanF
    18,532
    Load is the amount of work the engine is being called on to do. Increasing the load (say, by calling for more charging current out of a motor/generator) slows the engine RPM down, all else being equal.
    When the car is sitting there idling, and then the power management control ECU decides the battery needs charging, all else doesn't stay equal. That ECU coordinates with the ECM to give the engine more gas at the same time, so the RPM stays about the same as at idle. Still, you can hear the difference in the exhaust note between that and actual idle.
    When you give the engine more gas without anything applying more load at the same time, the RPM goes up.
  9. vvillovv
    vvillovv Senior Member
    4,329
    1,514
    NY
    A couple of thoughts ... reaching beyond my pay grade some. What are you using for codes? If you're getting codes post um up.
    Did you see the car care nut video posted above by @wafwat bout the ( after market Crankcase sensor ) / misfire / ecm that took him a month or two to figure out while two other dealer shops couldn't ?
