Strange green fluid in trunk of my 2005 Prius?
Discussion in 'Gen 2 Prius Main Forum' started by Tom E, Mar 22, 2026 at 2:09 AM.
  1. Tom E
    Tom E Junior Member
    Bellevue
    I needed to get into the "trunk" of my Prius this afternoon, and was very surprised to find that there were a couple of quarts of green liquid partially submerging the emergency spare. The liquid is clear and odorless; it looks like green KoolAid. No evidence of where it came from, and no sign of any fluid on the floor in front of the back seat.
    Looking at the layout of the trunk, it seems the only place the liquid might have come from is the hybrid battery. Does the battery contain such a liquid? If so, what would cause this leakage, and what can be done to fix it? If the battery does NOT contain any green liquid, any ideas where else it might have come from?
    Thanks very much for any help!
  2. T.S. Elliot
    T.S. Elliot Junior Member
    74
    22
    Desolation Row
    Check the roof where the end of the black strips are near the hatch. There could be cracks that are letting water in. Seal with silicone and it’s more or less a permanent fix. Battery seems doubtful but who knows. Take the cloth cover off of it and inspect. Should be able to rule it out that way.
  3. Tombukt2
    13,398
    2,412
    Green moldy water . Not batteries
    Brian1954 likes this.
  4. bisco
    52,379
    Guessing it’s been there since you bought the car
  5. Tom E
    Tom E Junior Member
    Bellevue
    Thanks for the replies. The mystery liquid is a very recent appearance; I keep the car very clean both in and out, and had refilled the spare just over a month ago, and the straoge are was completely dry then.
    I checked the weatherstripping around the rear hatch it it is perfect, no tears. I also looked at the tail lights to see if water could have entered there, but they are both tight.
    This is NOT moldy water. It really did look like green KoolAid; perfectly clear green liquid. Not dirty or soapy. No odor. I'm starting to wonder if a friend might be pranking me, but the car is kept locked when not in use so that is not too likely.
    But I really welcome any ideas as to where this liquid came from. None of the liquids in the cooling system are this color, and my windshield washer fluid is blue.
  6. VelvetFoot
    VelvetFoot Active Member
    1,199
    468
    New York State
    2026 Prius
    No odor? That rules out some stuff, no?
  7. PriusCamper
    PriusCamper Senior Member
    13,049
    5,303
    Pacific Northwest, USA
    The spare tire wheel well is the lowest point in the back of the car and because of gravity... It'd be worth considering how many times you and previous owners have put stuff in the back of the car? In a 2005 that's 21 years of shopping for stuff and hauling stuff. Consider that maybe something hauled around in the vehicle that spilled is another possibility?
  8. VelvetFoot
    1,199
    468
    New York State
    2026 Prius
  9. VelvetFoot
    1,199
    468
    New York State
    2026 Prius
    How about a grommet, or something like that popping out.
    Maybe going through the car wash with undercarriage wash option would replicate it?
    Would rust be a factor in Bellevue?
  10. PriusCamper
    13,049
    5,303
    No rust out hear, just lots of mold because we can have near 100% humidity all winter and most of Fall and Spring.
    WHAT FIRST STARTED AS SOME STRANGE GREEN LIQUID IN THE BACK OF AN OLD PRIUS, SUDDENLY BECAME:
  11. VelvetFoot
    1,199
    468
    New York State
    2026 Prius
    Didn’t see the movie. Loved the tune though.
    PriusCamper likes this.
