Hybrid Battery Status, Invest More Money?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jep4040, Mar 22, 2026 at 9:58 AM.
  1. jep4040
    jep4040 Junior Member
    usa
    Hi everyone,
    My 2005 gen 2 Prius (147,000 miles) needs a lot of work (around $3-4k+) like new struts, shocks, all new brakes, under body coating, etc. Engine itself seems pretty (just changed out spark plugs, clean throttle body and MAF, too.).
    My concern was pumping more money into this if the hybrid battery isnt going to last (especially at its age).
    I've included a video of my hybrid status (i dont really know whats good versus bad - hoping yall have some insight). It shows the battery trends while driving - at some points, i floor the gas and at other points i drive normal.
    Here's the video:
    Thanks guys!
  2. Tombukt2
    13,405
    2,415
    People start talking about undercoating and that means they're in the rust belt? If so we don't . Unless you're all in have four or five cars can move parts quickly have places to store the others inside etc . Fuggedaboutit. played this game 20 yrs in Western mass. good luck . Hybrid batteries like tires they're called consumables. You replaced the batteries in your flashlight
    jep4040 likes this.
  3. Brian1954
    Brian1954 Senior Member
    2,401
    962
    South Central PA, USA
    IMO, the hybrid battery looks very good for it being 21 years old. The voltage difference looked good while you were driving. That being said, the hybrid battery could encounter problems at any time because of its age. It would be a gamble to spend thousands of dollars fixing up the car, especially if you live in the rust belt.
    jep4040 likes this.
  4. bisco
    52,383
    Depends on your financial situation, and diy abilities.
    If you can afford to move on, I would do so, and probably to a non hybrid
    Merkey likes this.
  5. PriusCamper
    PriusCamper Senior Member
    13,051
    5,304
    Pacific Northwest, USA
    Out west we don't have salt on the roads and I had my Subaru undercoated once back in the early 2000's. It made the ride noticeably quieter and I like knowing the car is as clean as possible and that helped!
    jep4040 likes this.
  6. jep4040
    usa
    thank you so much for the response - appreciate it
  7. jep4040
    usa
    why a non-hybrid?
  8. bisco
    52,383
    cheaper and easier to maintain
  9. Tombukt2
    13,405
    2,415
    The four generation twos I've had basically same money to operate as Corollas . At least here anyway.
    Moving Right Along likes this.
  10. bisco
    52,383
    You do your own repairs, that’s important to mention when recommending old hybrids
    PriusCamper likes this.
  11. jep4040
    usa
    Strut & spring replacement? Brake and threads replacement? You're talented if you can do that on your own!
  12. jep4040
    usa
    What do you mean by that
  13. bisco
    52,383
    Not me, tombukt2
    #13 bisco, Mar 23, 2026 at 1:55 PM
    jep4040 likes this.
  14. Tombukt2
    13,405
    2,415
    I mean that after 47 years of driving Toyota's exclusively my4vgen2 Prius have been about same cost as running my 3 Corollas. Almost dollar for a dollar actually all repairs. Very close very similar etc .
