EGR cooler nightmare event -- always check a used one for leaks before you install...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cdherman, Mar 23, 2026 at 11:42 AM.
  1. cdherman
    cdherman Junior Member
    34
    Kansas City
    Short story: I took a running, zero issues 2014 Prius burning no oil at 148,000 miles and converted it to a blown headgasket.
    Long story: I replaced my 2011 Prius EGR cooler 4 years ago with a cleaned up, used one. The 2011 Prius is going strong.
    My 2014 Prius is headed to another state so, I decided to clean up the 2011 EGR cooler and swap it into the 2014. I completed the swap and immediately got a check engine light. It ran fine so I drove it , and started to see steam. Took the short connecting pipe off between the EGR valve and intake manifold and found coolant. Took things back apart and found a leak in the 2011 cooler. It did NOT have the leak before I cleaned it, but somehow, between my Draino and piano wire cleaning, I must have exposed or created a leak.
    I cleaned up the 2014 cooler and tested for leak -- no leak. Put things back together, but still consuming coolant and sending out steam from the exhaust.
    So the coolant from the defective EGR cooler must have caused my head gasket to fail.
    Ugh. I converted a perfectly running vehicle to a junker. Guess I will be learning how to replace head gasket.....
  2. Mendel Leisk
    41,900
    Probably the piano wire. You used Draino, not just lye? Draino is a bit of a witch's brew, even has flakes of aluminum in it I think. I would use either Potassium Hydroxide (KOH) or Sodium Hydroxide (NaOH). Of the two, the KOH is likely easier to get (popular for soap making), more water soluble, and more effective.
    More info on KOH versus NaOH
    #2 Mendel Leisk, Mar 23, 2026 at 11:47 AM
  3. cdherman
    34
    Kansas City
    Ironicaly, I cleaned the first one I bought off ebay 4 years ago exactly the same way and it was dirtier by far when it started. The piano wire is quite small and stiff. As for draino, I have been using that to clean gunk of metal parts forever and never had a problem. do not know -- clearly got unlucky on this one.
    As I said, the number one mistake was not testing a used EGR cooler. Readers should never assume a used one is good, even your own EGR cooler that you just cleaned. Cause mine was not leaking and I cleaned it and this is what I got -- blown head gaskets.
  4. ASRDogman
    ASRDogman Senior Member
    7,818
    3,982
    It's likely you poked a hole in the cooling passages with the piano wire.
    You didn't say how many miles on the engine, but it might have just been timing.
    It's not that difficult to replace the head gasket....
    Oven cleaner and pressure washer work fast and easy and safely.
    I am going to try the drain cleaner though. Just to see, and I have a spare cooler.
  5. VelvetFoot
    VelvetFoot Active Member
    1,212
    473
    New York State
    2026 Prius
    Oven cleaner isn't just NaOH anymore though is it?
    Did you use a newer formulation?
  6. CR94
    CR94 Senior Member
    2,749
    1,205
    Northwestern S.C.
    Yeah, leakage of pressurized coolant into the EGR stream via the cooler would soon lead to disaster on two fronts---low coolant and trying to compress liquid.
    I bought (but haven't yet needed to use) a used spare cooler on which one of the coolant pipes was bent. Therefore, I tested it extra carefully for leaks after cleaning it with wire and Oxi-Clean. No leak.
    Music wire is harder and stonger than common sorts of cheap steel wire.
    #6 CR94, Mar 23, 2026 at 9:22 PM
  7. ASRDogman
    7,818
    3,982
    Oven cleaner still works....
    If the cooler leaks, inside, it goes out the exhaust.... It doesn't go into the intake manifold...
  8. ChapmanF
    18,538
    There may be some confusion with gen 4's occasionally leaky Exhaust Heat Recovery System exchanger. If that leaks, the coolant goes out the exhaust.
    If an Exhaust Gas Recirculation cooler leaks, that's gonna go into the intake.
  9. rjparker
    10,504
    6,593
    It seems incredible a piano wire would bore a hole in a stainless steel egr cooler.
    Stainless steel requires low rpm, high pressure drilling and lubrication. Otherwise many types of ss will heat harden.
    Perhaps a drill bit was used first?
  10. Mendel Leisk
    41,900
    Or some seam was stressed, opened up?
  11. cdherman
    34
    Kansas City
    Did not use a drill. Coolant into the EGR cooler most certainly gets to the intake. And from there, into the cylinders and I popped a head gasket. I never ran it long, noticed the steam from the exhaust right away, perhaps after 5 miles. Never overheated because I never ran out of coolant.
    As for the piano wire, I have a selection of sizes and I was using a small gauge. I think this was coincidence. Moral is that even a KNOWN EGR cooler might go bad in the cleaning process. Testing is pretty low tech. Plug the holes with your fingers and blow into one with your mouth (after nice and clean). If you have a significant leak, you'll hear it. That might not detect a very small leak, but a very small leak will also not ruin your head gasket.
    Owning two prius for a combined 27 years total makes me feel pretty confident in terms of maintenance. This was really a let down. The toyota gasket kit is on its way and I think I'll use the Felpro MLS head gasket to boot. Only question is whether to have the heads surfaced. Engine never overheated and was having no problems before the event. Might skip that part.
  12. ASRDogman
    7,818
    3,982
    The exhaust blows through the cooler, to the converter and muffler.
    And the cooler is equal to and slightly lower than where the head meets the block.
    It is why you had white smoke out the tail pipe. Coolant got into the EXHAUST flow.
    Is coolant like a salmon and flows against the exiting exhaust?
    You said you didn't lose much coolant, but if the exhaust was blocked, it created
    extra pressure in the exhaust system which creates back pressure which can blow
    a head gasket.
    If you put the cooler in a bucket of water and put pressure through the coolant pipe, and
    block the other end, you'll see bubbles if there is a leak.
    If it is the cooler you purchased, the previous owner might have used sharp objects to try to
    clear it, thus damaging the coolant piping. It's not really likely a piano wire will damage the
    cooler. It is stainless steal, pretty tuff.
  13. ChapmanF
    18,538
    To be able to say that, you can only be thinking of the Exhaust Heat Recovery System exchanger. (Except the "to the converter" part; the EHRS exchanger comes after both catalytic converters, so "to the resonator and muffler" would fit better.)
    The EGR cooler, which is used for Exhaust Gas Recirculation, carries exhaust gas that is being recirculated from the exhaust manifold to the intake.
  14. rjparker
    10,504
    6,593
  15. Mendel Leisk
    41,900
    If you mean exhaust blows through the EGR cooler, to the catalytic converter, no, that's not the case.
    CR94 likes this.
  16. CR94
    CR94 Senior Member
    2,749
    1,205
    Northwestern S.C.
    I submit that leaked coolant might go either or both ways, depending on where the leak is in the EGR cooler and other details. During normal operation, vapor in the cooled exhaust will condense in the cooler (heat exchanger). Toyota cleverly tilted the cooler to ensure that most of that condensate drains back toward the main exhaust flow. Any leaked coolant joining that condensate wouldn't cause as much damage as it would in the EGR gas entering the intake manifold.
  17. ChapmanF
    18,538
    Good point. Certainly at times the EGR valve is closed, like idle and full throttle, any coolant leakage will follow gravity into the exhaust, while at other times the EGR flow may be high enough to bring it along into the intake.
  18. Mendel Leisk
    41,900
    Two right answers, always disconcerting.
  19. ChapmanF
    18,538
    ... but also a couple earlier posts that genuinely did seem to be mixing up the EGR and the EHRS. "The exhaust blows through the cooler, to the converter and muffler."—one answer, at least, that can be ruled out. :)
