Seafoam full can in the tank, now runs bad. Can this be fixed. how?
Discussion in 'Gen 2 Prius Main Forum' started by monoshock, Mar 24, 2026.
  1. monoshock
    monoshock Member
    66
    27
    Rocky Top TN
    Well I've used seafoam for many years with no problems. However I forgot and dumped a whole can in my 2004. Now it runs weird. 210k miles. How can I fix my mistake?
  2. dolj
    dolj Senior Member
    8,635
    4,389
    Wellington, New Zealand
    Define weird.
  3. ChapmanF
    18,993
    That'll fix it?
  4. PriusCamper
    PriusCamper Senior Member
    13,428
    5,421
    Pacific Northwest, USA
    How many gallons was it mixed in with/how full was tank? How many gallons have you added and how many miles since whatever "weird" means started?
    Also when was last time you replaced plugs and cleaned throttle body and MAF sensor?
  5. monoshock
    monoshock Member
    66
    27
    Rocky Top TN
    The tank was full. Around 200 miles is when the problems started, before the car ran great. i connected two different scanners and both show catalytic problems but with no codes. Hope the catalytic isn't clogged from carbon being broken loose from the seafoam. I'll post a picture of the scanner.
  6. pasadena_commut
    pasadena_commut Senior Member
    3,034
    942
    Southern California
    How does a scanner show a catalytic problem but no code???
    bisco and Brian1954 like this.
  7. PriusCamper
    13,428
    5,421
    If you've already driven 200 miles you have plenty of room to add more fuel and dilute the sea foam... And yes the catalytic problems are indicating that you got bad gas that's not combusting normally. Hopefully you put the seafoam in first so it mixed well? Also, maybe you bought a bad tank of gas at same time you put Seafoam in?
  8. Brian1954
    Brian1954 Senior Member
    2,668
    1,066
    South Central PA, USA
    Waiting for the picture.
  9. monoshock
    monoshock Member
    66
    27
    Rocky Top TN
    Here is what the scanner shows but no codes. I ran the car in place for 10 minutes and it runs fine. One thing that it starting doing before I parked it is the ICE would run when setting still and the hybrid battery is full. The car never did that before. I have a Nexcell hybrid battery in it.
  10. dolj
    dolj Senior Member
    8,635
    4,389
    My condolences if it is one of their lithium packs. Do some research on this site so you know what is in your future.
    Code:
    site:https://priuschat.com/ Nexcell Lithium
    #10 dolj, Mar 25, 2026
    xw20_driver and Brian1954 like this.
  11. monoshock
    monoshock Member
    66
    27
    Rocky Top TN
    It been fine for over 5 years now.
  12. Brian1954
    2,668
    1,066
    What brand and model number of scanner are you using?
    Most scanners are not capable of reading all the trouble codes that a Prius can have. Read post #1 and post #37 in this thread, https://priuschat.com/index.php?posts/3246758
  13. dolj
    dolj Senior Member
    8,635
    4,389
    Well you have done better than most. It is most like very quickly coming up to EoL.
    You still haven't stated in what way your car was behaving 'weird', unless you mean this:
    That is quite normal if the battery ECU detects that the voltage is above its 80% threshold. It will run the engine to lower the voltage down to where it is happier with it.
  14. Brian1954
    2,668
    1,066
    You must have an early version of NexPower's lithium hybrid battery.
    Can you use the Dr Prius app to check the hybrid battery data and to check for hybrid battery trouble codes?
    On the dashboard, are any warning lights tuned on?
    EDIT: Based on this thread that you created, https://priuschat.com/index.php?posts/3265366, you ordered the lithium hybrid battery in July of 2022. That makes you battery less than 4 years old.
    #14 Brian1954, Mar 25, 2026
  15. ChapmanF
    18,993
    That's a picture of the readiness display for the various monitors (self-tests). Looks like the only ones showing ready are the continuous ones like misfire and fuel. The ones that depend on tests the car occasionally runs are showing not ready.
    One time you'll always see that is when someone has recently done a code clear. In addition to clearing codes, that also resets all the noncontinuous monitors to not-ready, and they only come back to ready one by one as you drive around for a while and the different self-tests get run.
    (That's one reason not to have too itchy a trigger finger on the code-clear button if there is an inspection coming up soon, because the inspector will send you home if you show up with the self-test monitors not ready.)
    PriusCamper and Brian1954 like this.
  16. pasadena_commut
    3,034
    942
    Southern California
    The cat can take a while to come up to temperature to be "Ready" if the ICE isn't running continuously. Drive it on the highway for 10 minutes and check again. The O2S (O2 Sensor) might also take a while. Ditto for Evap.
  17. ChapmanF
    18,993
    The various self-tests have their own various schedules for when they run.
    EVAP is an extra-special one, because it's not even one that runs while you're driving. It runs five hours after you park and shut the car off (sometimes longer depending on temperatures).
    There are also dependencies between the tests. For example, the catalytic converter self-test cannot be run until after the air-fuel ratio sensor test and the heated oxygen sensor test have run.
    Generally they'll all manage to get back to completed status eventually if you just keep making normal use of the car over a week or so.
    If time is pressing, you can start looking up the "confirmation driving patterns" in the repair manual for the ones that haven't completed yet.
    #17 ChapmanF, Mar 25, 2026
  18. monoshock
    monoshock Member
    66
    27
    Rocky Top TN
    Than you for you advice and suggestions. I think my plan is to syphon as much fuel on of the tank I can and go fill it with 100% no ethanol fuel and see what happens. I'll post the results so if anyone else has this problem. For now I'm driving my other 2005 Prius. (the white one.)
  19. pasadena_commut
    3,034
    942
    Southern California
    I believe the filler has antisiphon features. If you break the filler to bypass that you can probably look forward to evap codes.
    Maybe start with the null hypothesis, that whatever is happening has nothing to do with the seafoam, and proceed from there.
  20. PriusCamper
    13,428
    5,421
    Yeah... That was my first thought too... Pretty sure if you find a way to succeed getting the hose in, you definitely won't find a way to get the hose back out. Just keep topping off your tank and don't worry about it.
