Head Gasket Replacement Shop Recommendations- San Francisco Bay Area
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by davekro, Feb 4, 2026.
  1. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,731
    1,767
    Bay Area
    yeah most likely will have to redo the gasket but I'll do that next time, too lazy right now lol. I'll let it be a little mess till I have time on the next oil change.
    ASRDogman likes this.
  2. davekro
    davekro Active Member
    529
    82
    SF Bay Area, East Bay
    2013 Prius Plug-in
    The 2013 PIP is running great! My wife is sooo happy to have her baby back in good working order. The two recommendations to drive it hard during the one-year warranty period are hard for my wife to go along with. She says she wants to take it easy on it, after the blown head gasket. Maybe she can warm up to the idea in a month of her trouble free driving. ;o)
  3. ASRDogman
    ASRDogman Senior Member
    7,820
    3,983
    Did you find the leak yet? Have you fixed it?
  4. NutzAboutBolts
    1,731
    1,767
    Bay Area
    It’s leaking under the chain tensioner, most likely its timing cover, there was a spot that was leaking there, I guess I needed more fipg. But there’s also a mysterious spot by the camshaft housing on the bottom, but I didn’t see any spot that it could leak to there… can’t tell if the oil some how just get lifted to that spot or not. I’ll recheck in 5k miles and see what I’ll do then.
    I just hate draining the coolant and oil again since I barely got to use it.
  5. davekro
    529
    82
    2013 Prius Plug-in
    From page 783 of the "Lazy Man's Jury-rig Manual" :p... If the suspected general location of the oil seepage is relatively accessible, you could consider rolling or folding either a rag (or even paper towel?) just to hold the seeping oil from dripping on the ground or making the rear of the engine an oily mess, until you have time/ bandwidth to fix the leak. Don't ask me how I know about this. ;o)
    bisco and NutzAboutBolts like this.
  6. Mendel Leisk
    41,901
    Basically Depends for engines.
  7. bisco
    52,390
  8. ASRDogman
    7,820
    3,983
    Think it could be the oil pressure switch????
  9. NutzAboutBolts
    1,731
    1,767
    Bay Area
    Those are the spots. The uv dye is glowing under the chain tensioner, then the oil on bottom of camshaft housing has oil drip, but it’s only at the end, there’s no opening spot for oil to be there, so I assume it could be from the oil from the leak being pushed up by the vehicle momentum.
  10. ASRDogman
    7,820
    3,983
    Take it back to the guy and tell him to fix it! :D:rolleyes::whistle:
    Joele3 and Mendel Leisk like this.
  11. NutzAboutBolts
    1,731
    1,767
    Bay Area
    :ROFLMAO::ROFLMAO::ROFLMAO:
    now I have this issue, will be posting a video of it when I get this fixed on Monday at the dealership. (y)
  12. ASRDogman
    7,820
    3,983
    Oh No!
    See, you replace the head gasket and ruin the hybrid battery!
    Oh the humanities!!! :eek: :rolleyes: :whistle:
  13. Mendel Leisk
    41,901
    What’s the code?
    Brian1954 likes this.
  14. NutzAboutBolts
    1,731
    1,767
    Bay Area
    it’s fixed (y)
    I’m making a video about it ;)
  15. ASRDogman
    7,820
    3,983
    That's great! I hope that is wasn't too hard to fix.
