Is cabin heat "free" if a Prime is in HV mode?
Discussion in 'Gen 5 Prius Main Forum' started by Will B, Mar 24, 2026.
  1. Gokhan
    Gokhan Senior Member
    6,575
    2,621
    Paramount CA
    In the Gen 4 PHEV in HEV mode, you can turn off the heat pump by using the A/C button and keep only the fan running, which will utilize the engine-coolant heater core to warm the cabin. In fact, even with the fan off, you can still feel heat coming from the vents.
    I don’t see why this should be impossible in the Gen 5 PHEV, but then they added refrigerant battery cooling, which could lead many Gen 5 PHEVs to the junkyard once the battery warranty expires, since repairs would be very costly. The Gen 6 RAV4 PHEV already uses engine coolant to cool the battery, so this refrigerant cooling system will remain unique to the Gen 5 Prius PHEV.
    #21 Gokhan, Mar 26, 2026
  2. Trollbait
    12,704
    The current Rav4 plug ins also use refrigerant cooling. Other Toyota EVs might also use it, or use the AC to chill the blown air.
  3. Gokhan
    6,575
    2,621
    Paramount CA
    You mean the outgoing RAV4 PHEV. Well, Toyota is done with it. It will never use it again. When there is a leak, and it leaks easily, it costs $20,000 to fix it.
    In my Gen 4 Prius Prime PHEV, the A/C didn’t even turn on once to cool the cabin for the battery.
  4. Hammersmith
    Hammersmith Senior Member
    2,338
    2,394
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The outgoing RAV4 PHEVs used refrigerant cooling for the HV batt, but the new gen RAV4 PHEV uses water cooling. (RAV4 HEV uses air cooling like always.) The Prius PHEV continues to use refrigerant cooling. It looks like the current BEVs(bZ/RZ) use water cooling. I don't know what the new BEVs(C-HR/Highlander/ES) are going to use, but I'm guessing water.
  5. hill
    8,943
    Don't most EVSls simply use coolant loops? And wouldn't a refrigerant loop be more expensive? If so it's hard to follow the logic.
    BiomedO1 likes this.
  6. BiomedO1
    4,281
    2,253
    Left Coast
    the gen1 nissan leaf used air cooling. that's why their range went down quickly after a few years - batteries overheating.
  7. hill
    8,943
    Irony the very most loyal EV Enthusiasts were completely soured by Nissan's complete failure - to the point where they had to file
    suit - because Nissan 'said' the Gen 1 was good for a ~100 miles when you're lucky to get 75 Mi under great conditions at freeway speed - only to find out a couple years later your battery had lost Maybe 20% plus of its capacity. What a Fiasco that was.
    BiomedO1 and PrimeDan like this.
  8. Trollbait
    12,704
    It costs so much to fix because Toyota didn't allow for leak repair in the design, so the entire battery would need to be replaced.
    Since they didn't want to design for use of a readily available aqueous coolant, the bZ4X uses a dielectric coolant that costs more to replace for regular maintenance.
    And you live in a mild climate, so why mention this? Leaf owners in California weren't seeing the degradation seen by those in Arizona.
    Part of the reason the gen4 PHEV pack took up so much space is because bigger channels for moving air through the battery than if a liquid is used.
    Refrigerant means narrower pipes. Makes it easier to route them. These first showed up in hybrids. I think going back to the OG Insight.
    Then the coolant loops available in the car might be too warm for a battery. Plumbing could also be a factor with the different components being cooled by the system. The Mach-E has a mess of connectors and tubes. Tesla developed the octovalve.
    hill and BiomedO1 like this.
  9. BiomedO1
    4,281
    2,253
    Left Coast
    I did like the little turtle that popped up in the gauge cluster when it went into limp mode; low battery.:rolleyes::LOL::ROFLMAO::whistle::cool::p:D
  10. hill
    8,943
    sounds like someone's never lived in Imperial County, Inyo County (home of world famous Furnace Creek's hot temps) Riverside County, or San Bernardino County California.
    but yea - both States had record number of battery failures. Coastal state of Washington? Their traction packs lasted longer than most others
    Gokhan and BiomedO1 like this.
  11. Gokhan
    6,575
    2,621
    Paramount CA
    Hybrid system Malfunction (Visit Your Dealership) | Page 4 | PriusChat
    Of course the traction battery coolant is different than the engine coolant, called Toyota Genuine Traction Battery Coolant. It probably does not take much coolant, perhaps only a few quarts? I am guessing it also does not require replacement. The engine and inverter use the pink Toyota Super Long Life Coolant in separate coolant circuits, as usual.
    The traction battery coolant not only cools the battery but also heats the battery as needed. There is a heat exchanger that couples to the engine coolant to accomplish that, and the latter has a high-voltage coolant heater.
    Yes, it is not the desert here, but we have hot days over 100 ℉. Just the last couple of weeks, it has been close to that in a heat wave.
  12. Will B
    Will B Active Member
    446
    412
    Denver
    2023 Prius Prime
    XSE Premium
    Wow, thanks for the ton of responses!
    @Paul Gregory : Yes, if I want some comfort I assume the heated seats and steering wheel use less power than cabin heat.
    @Gokhan and @BiomedO1 : Yes too, for AC I do the fancy sequencing to disable the compressor for cooling during mild summer temps--or as you point out foggy windows, though in CO we have local ordinances against humidity so that is rare.
    @PriusCamper : Normally my car is in a garage, so leads a cushy life. We've moved recently so it is being left outside temporarily and I am noticing that the engine kicks in more often, well before a depleted battery. I'm assuming that is due to a cold battery.
    @Paul Gregory : Yea, owning a Prius is the 90% solution, but tinkering is fun for me, not stressful. If I have a passenger, there's heat, this is just me playing.
    @ChapmanF : Those are the conditions I worry about, if the car is being "really smart" and when I'm thinking the heat is free it may not be. The main times I run out of battery power is out-of-town trips on highways, so if in HV mode it is going to be running the gas engine pretty frequently so hoping the engine will be mostly warm while driving.
    @Trollbait and @hill : Thanks, aware of things that force the engine on and they make sense
    @KMO and @BiomedO1 : I do do the AC button sequence and setting to LO to force just outside air in mild summer temps, but I've never seen that light for heating even in EV mode where it would have to be using it.
    @VelvetFoot : That is the generic language that isn't quite answering the question, hence coming here.
    @Paul Gregory : Not quite sure on your comment. I get heat with the engine not running at all if I request it in EV mode. Hopefully you do too. My question is if the car is smart enough to just switch over to engine waste heat once the engine is warm enough.
    PriusCamper likes this.
  13. Paul Gregory
    Paul Gregory Senior Member
    2,251
    596
    Alberta
    2024 Prius Prime
    XSE
    I live in a cold climate. I can't guarantee that my car performs as it does in a warmer one.
  14. Prodigyplace
    12,690
    11,834
    Central Virginia
    Hmmm. How do local ordinances control the weather?? ;)
    How is there precipitation with low humidity?
  15. Quovadis007
    Quovadis007 Junior Member
    COVENTRY
    2024 Prius Prime
    Business Ed. Plus
    The Prius 5 Prime has a 2-circuit heat pump system. (Prius 4 Prime only has 1)
    The heat pump can heat the HV battery separately (from 10°C to -10°C), and from 0°C, additional heating is provided for a few minutes using an electric resistance heater.
    You can choose to heat the interior separately with the heat pump or not.
    In winter, after +/- 5 minutes, the residual heat from the HV battery is automatically released into the interior via the heat pump system.
    If you are satisfied with steering wheel and seat heating for 5 minutes, you receive free residual heat from the HV battery.
    AndersOne and BiomedO1 like this.
  16. Quovadis007
    COVENTRY
    2024 Prius Prime
    Business Ed. Plus
    If you take longer trips, you will indeed get heat from the internal combustion engine in the interior, but also always residual heat from the high-voltage battery.
    The high-voltage battery naturally also operates in hybrid mode, and the heat pump dissipates excess heat into the interior if necessary.
    All Lexus PHEV models (from 2021) have this 2-circuit heat pump system.
    A leaking heat exchanger was only possible in the Prius 4 and Rav4 PHEV (2019-2025).
  17. BiomedO1
    4,281
    2,253
    Left Coast
    The gen4 is still an air cooled traction pack with air intakes from the passenger compartment. ONLY the gen4 PHEV has a heat pump, whereas the rest of the Prius line doesn't, here in the states. That's where the confusion is; non-PHEV people are chiming in and confusing the matter. The gen5 PHEV pack is mounted below the car w/o interaction with the passenger compartment and is freon cooled. Non-PHEV still has the standard air cooled traction pack architecture - with passenger compartment air circulation - I believe.
    Those that try to run w/o heater activation will have to deal with internal glass fogging, creating a dangerous situation to save a few pennies. IMHO...
    Just my two cents.....
  18. PriusCamper
    PriusCamper Senior Member
    13,139
    5,321
    Pacific Northwest, USA
    Wish we gave out a prize to the most thoroughly detailed reply to everyone who commented. Best I've ever seen compacted into one easy to read post! Excellent work!
  19. hill
    8,943
    Just another ½¢ - if it's not raining - but the air is freezing (like yesterday morn here, it was ~20°f) - and the drive to the coffee/donut shop was just 8 or 9min away - windshield won't fog 'till maybe ½way there. So you can crack the front windows ~2". Most can stand that coolness for a few minutes or so. Plus - that way the motor doesn't have to kick on for just a few minutes.
  20. BiomedO1
    4,281
    2,253
    Left Coast
    At or below freezing; humility is zero. A sealed car will start fogging, depending on how many people are breathing in it. Just like the mirror in your bathroom fogging up, the cold glass will attract the water molecules. Cracking the window will allow humility to escape; slowing the fogging process. Just like your bathroom mirror, opening a window and/or door will defog your mirror after a while.:love:
    #40 BiomedO1, Mar 31, 2026
