Techron fuel system cleaner
Discussion in 'Gen 2 Prius Technical Discussion' started by bluecrazymonkey, Mar 26, 2026.
  1. bluecrazymonkey
    bluecrazymonkey New Member
    26
    Earth
    I got a 2nd gen prius about 128k miles so far, and I use a techron fuel system cleaner like a few months ago and when i did it it made the transition between hybrid battery and engine more rough. I was wondering if this was a good thing? It smoothed out after like a couple of weeks and Ive been thinking about doing it again soon.
    Just wondering if this is good and i should keep doing it and if anyone else also had similar cases like mine as well?
    Thanks
  2. AzWxGuy
    AzWxGuy Weather Guy
    1,078
    558
    Tucson, AZ
    2021 Prius
    How much oil does the ICE burn between oil changes? My Gen 2 increased oil consumption just before 100K. Never noticed any roughness though, in transition or otherwise. Were sparkplugs replaced at 100K? You might want to disassemble the intake air piping to get down to the throttle body and check the throttle plate for any buildup around the throttle shaft and edges of the plate. While you're down there, take a look at the inside bottom of the intake manifold for accumulated oil/fuel. It's a difficult clean to mop that stuff out, but can be done if you're careful. Rough transition could be an EGR or PCV problem, or maybe the mass airflow sensor needs a cleaning. There is a special cleaning spray to use that leaves no residue.
    PrimeDan likes this.
  3. dolj
    dolj Senior Member
    8,634
    4,388
    Wellington, New Zealand
    Well, it won't be an EGR problem as the Gen 2 does not have an EGR system.
    Brian1954 likes this.
  4. Tombukt2
    13,826
    2,510
    You can vacumn that stuff out of throttle plate area .
  5. AzWxGuy
    AzWxGuy Weather Guy
    1,078
    558
    Tucson, AZ
    2021 Prius
    Affirmative. My Gen 2 was so long ago...
  6. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,569
    2,602
    Taylors, SC
    PEA in Techron cleans carbon, but it will not repair damaged or worn out parts.
  7. BiomedO1
    4,547
    2,392
    Left Coast
    This may have been a concentration/mixture issue. Most of these bottles will cover 15+ gallons and you've only got a ~10 gallon tank - dry. I don't think it did any damage, since it "smoothed out", a couple of weeks later and your not putting a lot of mile on it.
    Lower the concentration; perhaps a half bottle this time - a couple of tanks apart. This is also a symptom of contaminated fuel, which could've just been a coincidence.
    Good Luck....
  8. bluecrazymonkey
    26
    Earth
    prius doesnt burn oil, spark plugs been replaced, pcv have changed, no build up around throttle body and mass air flow sensor has been cleaned as well, there was like tiny amount of fluid on the bottom of the manifold while i did throttle body cleaning but not like a puddle i wouldnt say
  9. bluecrazymonkey
    26
    Earth
    good idea ill give this a try and what do you mean a symptom of contaminated fuel?
  10. BiomedO1
    4,547
    2,392
    Left Coast
    Water or other liquid contaminates in your gas. This usually happens in rarely used, remote gas stations. If you fill up at a busy gas station, (ie. Costco, Sam's Club, or a busy station next to a major highway) the large supply tank is refilled on a weekly or sooner basis. Fuel doesn't get a chance to stagnate, so minimal contamination.
  11. pasadena_commut
    pasadena_commut Senior Member
    3,032
    942
    Southern California
    Maybe avoid Sam's Club gas, last time I checked it wasn't top tier gas. Costco's is. This could be a regional thing though. In theory if the car never sees anything but top tier gas it shouldn't actually ever need Techron. If it never sees top tier gas it probably will need Techron.
  12. bluecrazymonkey
    26
    Earth
    Thanks will keep this in mind, never tried sams club gas, i always stick with exxon or shell
  13. RRxing
    RRxing Senior Member
    2,562
    1,840
    NEPA
