Removing Gen 5 rear seat base?
Discussion in 'Gen 5 Prius Main Forum' started by Rich Fife, Mar 26, 2026.
  1. Rich Fife
    Rich Fife Junior Member
    Just yank on it or is there somewhere I should use a tool?
    Thanks!
  2. Hammersmith
    Hammersmith Senior Member
    2,406
    2,453
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yank up sharply on each side towards the front. You may or may not break the white retainers the seat clips into. Replace if necessary; they're considered non-reusable. The rear half of the seat bottom has loops that hook under metal hooks bolted to the floor. You need to pull the seat bottom forward a bit to see the connections, then push the loop down while pulling that side of the seat forward a bit. Repeat on the other side. I've only pulled the seat bottom out after first removing the seat backs, so I don't know how easy/hard it is to get the loops under the hooks with the seat backs still in place.
    Toyota hasn't changed the basic design in decades, so videos of gen3/4/5 all show what you need to do.
    Retainers: 72693-12080 - about $0.70 each at your local dealership
    I keep a couple handy in the center console. The recall kit for the fuel tank came with a couple, so I asked the dealership to leave them in the car if they didn't use them. They didn't, so now I have spares.
    soft_r likes this.
  3. VelvetFoot
    VelvetFoot Senior Member
    1,380
    531
    New York State
    2026 Prius
    I used a strong screwdriver and also pulled. The screwdriver made it easier and no damaged clip. There's a video in below seat cover thread for an older car.
    Also, I figured out how to unlatch middle seatbelt, also in thread.
    Upholstery/Seat Covers ? | PriusChat
