Seafoam full can in the tank, now runs bad. Can this be fixed. how?
Discussion in 'Gen 2 Prius Main Forum' started by monoshock, Mar 24, 2026 at 8:14 PM.
  1. rjparker
    10,508
    6,596
    Seafoam's webpage says you can use up to 50/50 seafoam/gas and not cause a problem.
    Seafoam is not going to knock carbon off the combustion chamber and clog the cat. Oil burning over a period of time can cause cat issues.
    I had a guy put in diesel in his reg gas car. That was a problem!
  2. monoshock
    monoshock Member
    65
    26
    Rocky Top TN
    Okay thanks I'll just run out the fuel and hope I don't get the triangle of death and it shuts down.
  3. pasadena_commut
    pasadena_commut Senior Member
    2,849
    850
    Southern California
    The only thing I would worry about with too much seafoam in the gas on a Gen2 prius is that it might damage the rubber bladder. Would seafoam be worse than straight gasoline, I have no idea. Actually it is kind of amazing that Toyota is able to use rubber this way at all.
    "gas" is gasoline plus ethanol
    Seafoam's msds shows >=75% "hydrocarbon blend" and <=25% isopropanol
    Looking at a chemical resistance table for rubbers:
    Rubber Chemical Resistance, Rubber Chemical Compatibility, Page 3 - Mykin Inc
    LEGEND: 1 = Satisfactory, 2 = Fair, 3 = Doubtful, 4 = Unsatisfactory, X = Insufficient Data
    solvent Nitrile EPDM Neoprene SBR Silicone Butyl Polyacrylate Hypalon Viton Polyurethane Fluorosilicone Aflas Kalrez
    Ethanol____3 1 1 1 2 1 4 1 3 4 1 X 1 (in gas)
    Gasoline___1 4 4 4 4 4 4 4 1 2 1 X 1 (in gas)
    Isopropanol _2 1 2 2 1 1 4 1 1 4 2 X 1 (in seafoam)
    other______ 1 4 2 4 4 4 1 3 1 2 1 X 1 (saturated hydrocarbons, probably in seafoam)
    one observes that most rubbers are unhappy in gasoline, and of the few that are OK with it, roughly half of those don't like ethanol. Since "gas" contains both of those, that suggests the bladder is made of either fluorosilicone or kalrez. That would be a slight problem if the bladder is fluorosilicone because of the isopropanol in seafoam, but OK if the bladder is Kalrez. The "hydrocarbon blend" is most likely chemically similar to gasoline. I could not find a link to anything definitively stating which material Toyota used in the bladder, just lots like this one making guesses. The AI's are all pushing nitrile, as if ethanol wouldn't be an issue. Since Toyota seems not to have ever revealed which rubber they used, the AI's can only just guess.
    PriusCamper likes this.
  4. PriusCamper
    PriusCamper Senior Member
    13,063
    5,305
    Pacific Northwest, USA
    Thanks for these details... I'm now even more convinced that OP bought bad gas and the Sea Foam part was not the cause of problem, just a coincidence.
