How to prevent scrunching the front end up over a curb?
Discussion in 'Gen 4 Prius Main Forum' started by Kenatsun, Mar 21, 2026.
  1. Kenatsun
    Kenatsun New Member
    Ann Arbor, MI
    Twice now, while parking my 2016 Prius nose-in to a curb, I have overridden the curb and damaged the low-riding front lip enough to require a $1500 replacement. What devices (low-tech and high-tech) are available to let me know exactly how close my nose is to a curb?
  2. AzWxGuy
    AzWxGuy Weather Guy
    1,068
    548
    Tucson, AZ
    2021 Prius
    You have probably already searched the internet unsuccessfully for some sort of device. Most of what you can find is reinforcement for what is already there. Some years back I recall there was a luxury line of vehicle that made use of ultrasonic distance detection and hydraulic vehicle leveling with the suspension system to avoid road hazards dynamically while driving. Might have also worked on the lowly parking lot bumper. Best I can come up with is a trained eye and a slow, careful creep into the parking spot or a passenger spotting for you.
  3. rjparker
    10,513
    6,598
    Camera used with dash cam
    Prodigyplace and Brian1954 like this.
  4. BiomedO1
    4,143
    2,170
    SacTown, Ca
    Install a 1.5 inch body lift kit.
    It isn't those parking curbs that's damaging you lower air dam; it's those rebars sticking out of the top of them - meant to hold those curb in place. If they protrude up a bit, they hook your air-dam as your backing out. I carry a 3# sledge hammer, on the rear floor board for that. Of course you need to see that protrusion before driving over it.
    Prodigyplace likes this.
  5. Mendel Leisk
    41,905
    I just stop sooner, never use wheel stops. Our frontmost underpanel is is miracle, held together with fiberglass mesh and two-part epoxy, due to years of "experience".
    There are spring-feeler things, make the front end look even more like a catfish. :)
    Doug McC and BiomedO1 like this.
  6. BiomedO1
    4,143
    2,170
    SacTown, Ca
    If you stop short; just make sure your butt isn't hanging out too far into traffic. The person parked next to you, may hit or scrape your rear quarter panel or corner; while they're backing out and swinging around.
    LoL; I haven't seen those things in ages !!!! Don't know how well they would work with all the plastic on modern cars. They won't be able to transmit the scrapping vibrations throughout the plastic as opposed to the old metal of those land yachts.:(
    #6 BiomedO1, Mar 23, 2026 at 12:43 PM
    Prodigyplace and Mendel Leisk like this.
  7. rjparker
    10,513
    6,598
    Curb feelers were for parallel parking in cities.
    #7 rjparker, Mar 23, 2026 at 4:02 PM
    Prodigyplace and Tande like this.
  8. VelvetFoot
    VelvetFoot Active Member
    1,225
    477
    New York State
    2026 Prius
    Tomorrow I'm going to see if the front sensors on my Gen5 will actually do some good on a simulated (low) curb of firewood. I'm thinking not.
  9. VelvetFoot
    1,225
    477
    New York State
    2026 Prius
    Nope. Didn't work.
  10. Doug McC
    Doug McC Senior Member
    1,082
    420
    Midwest
    2022 Prius
    Shortly after taking delivery of our’22 I did the same thing (except it was basically a large scratch). To prevent doing it again after the repair, I learned to stop sooner and to judge the distances around the car (just like we had to do way back in drivers training). Problem solved.
  11. VelvetFoot
    1,225
    477
    New York State
    2026 Prius
    I have yet to figure out where the front of the car is, visually.
    I'm actually thinking of setting up a fiberglass driveway marker and practice.
    I'm usually way far away from an abundance of caution.
  12. Mendel Leisk
    41,905
    Funny thing is, those wheel stops used to be useful. Maybe they’re not a thing in Japan?
