Replaced LE light gray cloth with Limited black leather
Discussion in 'Gen 5 Prius Accessories and Modifications' started by soft_r, Mar 20, 2026.
  1. soft_r
    soft_r Active Member
    188
    155
    Beverly Hills
    2024 Prius
    4 bolts, 2 clips, very easy. Vacuumed up what little debris and dust there was and wiped down anywhere that looked like it needed it. Couldn't find a listed torque spec so I went with 27ft/lb as per the front seat rail bolt spec. This is a 10 minute job.
    Really wanted the black leather interior but it wasn't happening as far as what dealerships near me were being allotted at the time I was looking to buy so I settled with the light cloth interior. And after my first oil change where the tech smudged oil or something on the rear seat cushion and then cleaning it left this weird water stain, I've been pretty locked into the idea of replacing the cloth seats.
    Picked up a full rear set from a wrecked one off ebay for cheap and they fit just fine.
    Ignore the wire runs, redoing some things in the coming weeks. Replacing with 16awg and running it all left side, away from HV line (not that it's currently picking up interference but might as well run it correctly since I'm replacing it).
    otatrant and PhoS like this.
  2. VelvetFoot
    VelvetFoot Active Member
    1,226
    480
    New York State
    2026 Prius
    Nice!
    So, you replaced just the rear so far, or the fronts too? You had some seat covers on the front as I recall.
    I just didn't like the oem gray cloth. I put some nice pleather covers, front and back and like them. They clean up well, and that's been my experience in MINI and BMW-their oem pleather is nice too. Wasn't a 10 minute job though.
    There was a little thing I had to figure out to get the middle belt off, as I recall.
    A plus about the covers versus oem, is that the cushions seem thin. The covers MAY add a little body to it, but who knows.
    Anyway, if you don't have the fronts, get looking! :)
  3. soft_r
    188
    155
    Beverly Hills
    2024 Prius
    Fronts I'm leaving as is. I haven't even looked but I'm assuming most coming from wrecks will have the airbags blown. And even if not, with the airbag tech in the seat and everything else I just expect that the cost will be prohibitive. I can just slap some new covers on the fronts and be fine with that.
  4. VelvetFoot
    1,226
    480
    New York State
    2026 Prius
    I didn't think there were airbags in the seats; sensors I thought were under the seat. Of course, seat heat would be nice....here anyway.
    I really like the covers I put on.
    Upholstery/Seat Covers ? | PriusChat
  5. LRO
    LRO Junior Member
    62
    United States
    2024 Prius Prime
    XSE Premium
    I'm not doing any deep dive or commentary here but there are SRS side airbags that are installed inside the front driver and passenger seats that run along the outer perimeter of the seats that I believe deploy through breakaway seams in the stitching. So, perhaps, seat covers need to accommodate for that? (rear seat side airbags are not in the seats). Page 35 onward of your 2026 owner's manual describes/shows it and Page 41 has a warning about seat covers. Be safe.
    #5 LRO, Mar 20, 2026
    mingc likes this.
  6. VelvetFoot
    1,226
    480
    New York State
    2026 Prius
    Thanks. The diagram confused me. They're apparently towards the bottom of the front seat backs. I recall the cover maker saying something about 'special' stitching and panels. Hopefully I won't have to test that out.
    #6 VelvetFoot, Mar 21, 2026
  7. Hammersmith
    Hammersmith Senior Member
    2,325
    2,374
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Your bigger problem about finding front seats to convert your car is that any you find will be power(XLE) or power with memory(LTD). And you don't have the wiring for either. You could probably wire in a powered drivers seat from an XLE fairly easily as all it needs is adding a power feed. But the seat from a LTD would be pretty tough as the seat is actually controlled by the Main Body ECU. Doable as your ECU is can do the job once it's plugged into the seat, but it's a lot more wiring work(plus you should also install the memory buttons on the driver door at the same time to make it fully functional).
    Now you could always try just swapping the seat covers, and I bet the upper cover would swap just fine, but it's possible the lower cover might be cut differently on the driver side because of the power seat controls and a different seat structure. Since all passenger seats are manual no matter the trim, there's no issue on that side.
    But on the bright side, black XLE seats are very easy to find in salvage yards. The seat airbags only go off during an impact on that side or maybe a rollover, so finding seats without blown bags is pretty easy(trust me, I searched gen5 junkyard seats for almost two years). Most front and rear collisions don't set them off, and that's a big share of cars in salvage yards. Just be thankful you'd only be searching for the relatively common XLE driver and XLE/LTD passenger seats instead of trying to find a rare XSE/XSE+ set out of a Prime like I was doing. Two years of searching and I eventually finally found a set I had to have shipped to ND from Fresno($ouch$). And they turned out to be from a smoker's car, so it took even more work(and an ozone machine) to finish the job(I still get the faintest whiff of cig on a hot day when I first get in).
    Good luck if you plan to finish the job. It's really nice to get your car exactly the way you want it if you plan to keep it for a long time.
    VelvetFoot likes this.
  8. dicknose
    dicknose New Member
    Toronto
    2024 Prius Prime
    XSE Premium
