Main Hybrid wire removal
Discussion in 'Gen 2 Prius Main Forum' started by Will Eng, Mar 26, 2026 at 11:16 PM.
  1. Will Eng
    Will Eng New Member
    Thursday
    Chicago
    Does any one have experience removing the main hybrid cable connecting the hybrid battery and the inverter under the hood? I know the cable runs under the car and up to the engine compartment. Is it hard to remove?
    I see that there are some bolts and clips to unhook but are they all reachable without taking out the brake actuator or inverter?
    Unfortunately, I installed a new hybrid battery and didnt torque the nuts down enough and it became loose. The arcing burned through the wires at the relays next to the ECU near the hybrid battery. I was thinking of splicing the wires back onto the connectors but I thought its safer to just replace the entore wiring harness. Any help is appreciated.
  2. Tombukt2
    13,437
    2,418
    They're really easy to take out probably why no videos. 9 hoot two here ready got this removal 8 thought not needed no one would ever need . In plug orange plugs at back of inverter of course safety plug removed from battery. roll car on ramps. You see the two plugs you've undone from inverter they run in a plastic tray that bolted and screwed to under chassis as you drove the screws n bolts out of tray it'll start hanging down .. you make it back to tear of car and pull thru the eyelets that bolt to HV battery . And the whole mess is on you're grass or driveway . Reverse the process . Not hard you just have to participate . Be able to lay under car . Move arms etc .
  3. Will Eng
    Will Eng New Member
    Thursday
    Chicago
    Hey thanks for the reply. I'm stuck halfway with taking it off. I cannot get the 2 rectangular clips off. Any chance you know how without breaking the clips? I am enclosing pictures of the clips which I have never seen before in a car. Thanks.
