Is cabin heat "free" if a Prime is in HV mode?
Discussion in 'Gen 5 Prius Main Forum' started by Will B, Mar 24, 2026.
  1. Gokhan
    Gokhan Senior Member
    6,542
    2,613
    Paramount CA
    In the Gen 4 PHEV in HEV mode, you can turn off the heat pump by using the A/C button and keep only the fan running, which will utilize the engine-coolant heater core to warm the cabin. In fact, even with the fan off, you can still feel heat coming from the vents.
    I don’t see why this should be impossible in the Gen 5 PHEV, but then they added refrigerant battery cooling, which could lead many Gen 5 PHEVs to the junkyard once the battery warranty expires, since repairs would be very costly. The Gen 6 RAV4 PHEV already uses engine coolant to cool the battery, so this refrigerant cooling system will remain unique to the Gen 5 Prius PHEV.
    #21 Gokhan, Mar 26, 2026 at 3:07 AM
  2. Trollbait
    12,688
    The current Rav4 plug ins also use refrigerant cooling. Other Toyota EVs might also use it, or use the AC to chill the blown air.
  3. Gokhan
    6,542
    2,613
    Paramount CA
    You mean the outgoing RAV4 PHEV. Well, Toyota is done with it. It will never use it again. When there is a leak, and it leaks easily, it costs $20,000 to fix it.
    In my Gen 4 Prius Prime PHEV, the A/C didn’t even turn on once to cool the cabin for the battery.
  4. Hammersmith
    Hammersmith Senior Member
    2,325
    2,374
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The outgoing RAV4 PHEVs used refrigerant cooling for the HV batt, but the new gen RAV4 PHEV uses water cooling. (RAV4 HEV uses air cooling like always.) The Prius PHEV continues to use refrigerant cooling. It looks like the current BEVs(bZ/RZ) use water cooling. I don't know what the new BEVs(C-HR/Highlander/ES) are going to use, but I'm guessing water.
  5. hill
    8,926
    Don't most EVSls simply use coolant loops? And wouldn't a refrigerant loop be more expensive? If so it's hard to follow the logic.
    BiomedO1 likes this.
  6. BiomedO1
    4,149
    2,173
    SacTown, Ca
    the gen1 nissan leaf used air cooling. that's why their range went down quickly after a few years - batteries overheating.
  7. hill
    8,926
    Irony the very most loyal EV Enthusiasts were completely soured by Nissan's complete failure - to the point where they had to file
    suit - because Nissan 'said' the Gen 1 was good for a ~100 miles when you're lucky to get 75 Mi under great conditions at freeway speed - only to find out a couple years later your battery had lost Maybe 20% plus of its capacity. What a Fiasco that was.
    BiomedO1 and PrimeDan like this.
  8. Trollbait
    12,688
    It costs so much to fix because Toyota didn't allow for leak repair in the design, so the entire battery would need to be replaced.
    Since they didn't want to design for use of a readily available aqueous coolant, the bZ4X uses a dielectric coolant that costs more to replace for regular maintenance.
    And you live in a mild climate, so why mention this? Leaf owners in California weren't seeing the degradation seen by those in Arizona.
    Part of the reason the gen4 PHEV pack took up so much space is because bigger channels for moving air through the battery than if a liquid is used.
    Refrigerant means narrower pipes. Makes it easier to route them. These first showed up in hybrids. I think going back to the OG Insight.
    Then the coolant loops available in the car might be too warm for a battery. Plumbing could also be a factor with the different components being cooled by the system. The Mach-E has a mess of connectors and tubes. Tesla developed the octovalve.
    hill and BiomedO1 like this.
  9. BiomedO1
    4,149
    2,173
    SacTown, Ca
    I did like the little turtle that popped up in the gauge cluster when it went into limp mode; low battery.:rolleyes::LOL::ROFLMAO::whistle::cool::p:D
  10. hill
    8,926
    sounds like someone's never lived in Imperial County, Inyo County (home of world famous Furnace Creek's hot temps) Riverside County, or San Bernardino County California.
    but yea - both States had record number of battery failures. Coastal state of Washington? Their traction packs lasted longer than most others
    Gokhan and BiomedO1 like this.
  11. Gokhan
    6,542
    2,613
    Paramount CA
    Hybrid system Malfunction (Visit Your Dealership) | Page 4 | PriusChat
    Of course the traction battery coolant is different than the engine coolant, called Toyota Genuine Traction Battery Coolant. It probably does not take much coolant, perhaps only a few quarts? I am guessing it also does not require replacement. The engine and inverter use the pink Toyota Super Long Life Coolant in separate coolant circuits, as usual.
    The traction battery coolant not only cools the battery but also heats the battery as needed. There is a heat exchanger that couples to the engine coolant to accomplish that, and the latter has a high-voltage coolant heater.
    Yes, it is not the desert here, but we have hot days over 100 ℉. Just the last couple of weeks, it has been close to that in a heat wave.
  12. Will B
    Will B Active Member
    444
    408
    Denver
    2023 Prius Prime
    XSE Premium
    Wow, thanks for the ton of responses!
    @Paul Gregory : Yes, if I want some comfort I assume the heated seats and steering wheel use less power than cabin heat.
    @Gokhan and @BiomedO1 : Yes too, for AC I do the fancy sequencing to disable the compressor for cooling during mild summer temps--or as you point out foggy windows, though in CO we have local ordinances against humidity so that is rare.
    @PriusCamper : Normally my car is in a garage, so leads a cushy life. We've moved recently so it is being left outside temporarily and I am noticing that the engine kicks in more often, well before a depleted battery. I'm assuming that is due to a cold battery.
    @Paul Gregory : Yea, owning a Prius is the 90% solution, but tinkering is fun for me, not stressful. If I have a passenger, there's heat, this is just me playing.
    @ChapmanF : Those are the conditions I worry about, if the car is being "really smart" and when I'm thinking the heat is free it may not be. The main times I run out of battery power is out-of-town trips on highways, so if in HV mode it is going to be running the gas engine pretty frequently so hoping the engine will be mostly warm while driving.
    @Trollbait and @hill : Thanks, aware of things that force the engine on and they make sense
    @KMO and @BiomedO1 : I do do the AC button sequence and setting to LO to force just outside air in mild summer temps, but I've never seen that light for heating even in EV mode where it would have to be using it.
    @VelvetFoot : That is the generic language that isn't quite answering the question, hence coming here.
    @Paul Gregory : Not quite sure on your comment. I get heat with the engine not running at all if I request it in EV mode. Hopefully you do too. My question is if the car is smart enough to just switch over to engine waste heat once the engine is warm enough.
  13. Paul Gregory
    Paul Gregory Senior Member
    2,235
    593
    Alberta
    2024 Prius Prime
    XSE
    I live in a cold climate. I can't guarantee that my car performs as it does in a warmer one.
