Resurface head and replace valve seals etc at time of headgasket replacement or not?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cdherman, Mar 31, 2026 at 11:40 AM.
  1. cdherman
    cdherman Junior Member
    43
    Kansas City
    OK, I blew my HG with a leaking EGR cooler that I put on to a flawlessly running vehicle. It was burning no oil and having no problems, but the fluid popped the HG.
    It never over heated, in fact never even threw error codes, but I could see steam in the exhaust. Putting a good EGR cooler on did not stop the coolant loss.
    I have the Felpro HG already and a Toyota kit coming with all the seals. Kit comes with new valve seals as well.
    Local place wants $195 to clean head, regrind valves as needed and replace seals. Another $60 to resurface head. Seems fair and they have an excellent reputation.
    But they take 10-14 days and I'd like to keep moving. This vehicle has 150k miles and needs to last another 3 years and perhaps 50k miles. The car was sideswiped so its no beauty anymore but its been reliable and in 3 years my daughter plans to buy a new car.
    I have read lots of threads, but cannot decide whether to re-work the heads or not. I have a good straight edge (accurate to .0001") and feeler gauges, so I will check the head (and the block) for true and check the valves with the brake cleaner trick..... If I find a problem, I'll definitely have the heads worked on.
    But it would be really nice to have my garage back...... What the consensus? I don't need perfect, just running for 3yrs/40 k miles or so........
  2. Mendel Leisk
    41,912
    Check against flatness spec's with a machinist's straight edge? Just for giggles you check it first with the "straightest edge you've got on hand", trying several. You basically press the straight edge against the face, and try slipping a feeler gauge under at various points.
    Never mind, see you've got straight edge and feeler gauges.
    The flatness specs are in the bottom link in my signature. (on a phone turn it landscape to see signatures)
  3. frodoz737
    frodoz737 Top Wrench
    4,722
    2,517
    33
    If it was my car...yes...get it done right. It's a GEN III with 150K miles...and the head gasket blew.
  4. PriusTech
    PriusTech Active Member
    261
    120
    Reno
    Just take a paint and body sanding block with 220 grit Wet-o-dry with WD-40 and go over the gasket surface. Do not use a roll-loc disc, it will gouge in and cause low spots. Then check with the straight edge. Machining is not necessary if it's within flatness specs. But machine shops will always do it anyway. While you have it apart it doesn't hurt to do the valve seals although I would use OEM seals. Fel-pro won't last as long.
  5. cdherman
    43
    Kansas City
    Guess I should check and see how much trouble putting in the valve stem seals is. Good point. I'll have toyota seals.
    Aside -- I once had a subaru boxer engine that some idiot had cleaned off the block with a "wiz-wheel" (like a roll-loc disc) and has rounded the aluminum edges. Which resulted in repeated HG failures. Proper way to fix that is to split the boxer block, deck the half blocks and reassemble. What I did: Get a piece of true plate glass big enough for 2 sheets of wet/dry fastened to glass with spray contact cement. Then using wd-40 as lube, I honed that block 180>220>320>400>600. First pass you could instantly see the rounded edges of the cylinders. It was going strong 6 years and 50k miles later, when I sold it.
  6. ASRDogman
    ASRDogman Senior Member
    7,830
    3,987
    Use a razor blade to clean off the head. Maybe a brass brush to clean it up. Then check the head.
    You shouldn't do any sanding. If it's not warped, no need for the machine shop.
    The block is cast iron and it's not going to warp, if it did, you would've known it because the engine wouldn't have worked
    Valve guide seals are easy. You just need the spring compressor and a strong magnet to grab the retaining clips.
    If the valves are leaking, use valve grinding compound with an electric drill and popping the valve, to seat them in.
    You can do that in an afternoon.
  7. BiomedO1
    4,159
    2,179
    SacTown, Ca
    NEVER sand an aluminum head!!!! Use a green plastic brillo pad and elbow grease.
    You can usually borrow a valve compression tool at your local parts store. They will charge your credit card and refund it when you return it. Make sure it's in good working order BEFORE you leave. I've run into a lot of broken/nonfunctional tools. They are usually pretty good about that, but you don't want to get blamed for breaking something that you didn't break.
    I personally wouldn't use a drill with grinding compound on the valves. If they're leaking and it isn't carbon deposits - it needs to be measured and machined; but at 150K - it's probably OK.
    Good Luck...
  8. cdherman
    43
    Kansas City
    I found a video about doing valve seals and lapping pitted valves on youtube. Guy seemed competent, and it seems pretty easy. I ordered a $20 spring compressor from Amazon! As for not lapping and needing proper measurements, my understanding is that the hydrauliic lifters will compensate for any changes.
  9. Brian1954
    Brian1954 Senior Member
    2,410
    968
    South Central PA, USA
    I do not know where you got your Gen 3 engine from, but the Toyota OEM engine has an aluminum block.
  10. ASRDogman
    7,830
    3,987
    You could have rented one from autozone for free. But $20 is a good price.
    the lifters have nothing to do with the valve and seat. "Lapping" in the valves
    removes a little material from both surfaces so there is an exact fit and the combustion
    gasses do not leak and you lose no power.
    If they are not leaking, you don't have to do it. Just replace the guide seals.
  11. rjparker
    10,528
    6,609
    The car was wrecked and the head gasket failure never threw codes? Did you ever get the severe metal to metal rattling and shaking caused by coolant induced misfires?
    Did you look in the cylinders with a borescope?
    It would a bad day in Kansas City if a hg repair did not solve the problem and it was a cracked exhaust heat recirc system.
    #11 rjparker, Mar 31, 2026 at 9:16 PM
  12. cdherman
    43
    Kansas City
    Ok, old school here, but before we had hydraulic lifters, which maintain the tension between the rockers, the cam lobes and the top of the valves, we had to adjust valve lash as things wore down, or were filed down during a lapping process. To say that the hydraulic lifters have nothing to do with the valve and the seat is not really correct unless I have been missing something for say 50 years or so..
    When you lap a valve and its seat down , the top of the valve stem will protrude a tiny bit more, and in the old world of non-hydraulic lifters, you had to adjust the valve lash accordingly.
    Just saying... Appreciate the otherwise useful advice......
  13. cdherman
    43
    Kansas City
    I don't think the 3rd gen Prius has an exhaust heat recirc system. That was gen 4 IIRC.
    It was never badly wrecked -- a slight sideswipe in 2015 as a new vehicle that rendered it a bit unsightly, but not even any exposed metal, so no rust even. So daughter in question (who was responsible for the minor damage) got to drive the newish car for now ongoing 11 years as punishment (not really, but sounds good) No codes, ever.
    Never had rattling, never misfires. But its now drinking coolant like a bowery bum drinks booze and the only explanation is the head gaskets are toast.... And I see a haze of steam during any load like a hill or acceleration.....
  14. rjparker
    10,528
    6,609
    Gen3 does have an exhaust heat recirc system - they just don't leak as much as the early gen4 systems. However some do leak and will cause billows of steam.
    CR94, Brian1954 and Mendel Leisk like this.
  15. Mendel Leisk
    41,912
    The exhaust heat recirculation system is not inherently prone to coolant leakage; there was a bad batch, for whatever reason (poor crimp or weld), earlier year gen 4’s were failing.
    And yeah, gen 3 have the system as well.
    I “think” gen 5 has the EHRS too. It’d be interesting to know if Toyota’s separated with a flange, from the catalytic converter. With 3rd/4th gen they’re a single unit, a lot of eggs in one basket.
  16. ASRDogman
    7,830
    3,987
    First, the more I thought about it, I realized the block itself is aluminum. So in theory, it could
    possibly warp, though it's extremely unlikely because of the steal sleeves for the pistons.
    The only time I've heard of any block being warps is when the engine was severely over heated.
    Which yours was not, correct?
    Unless you have a LOT of damage on the valve and/or seat, the material you'll be removing
    will be very minute. You top of the valve is not getting hit like ones without hydraulic lifters, so again,
    you won't have the damage like non hydraulic lifters.
    You can inspect them, note there are "cap" on top of the valve. And if you gong to lap them in,
    only do a second or two then check for an even like around the seat and valve. If it looks even,
    clean off the grinding compound with carb clean making sure ALL of it is removed!
    If you a larger leak, or several leaking, perhaps the machine shop would be the best idea.
    They can only remove 1 or 2 thousands of the head if it's warped. Toyota say cannot resurface it.
    That valve will be very close to that piston! Though it has been done, as some of reported.
    Non of mine showed any wear, at 300,00 miles. (I'm at 385,500 miles).
    Only 1 intake valved was barely leaking. It was showing just barely enough WD40 after 15-20 minutes of sitting.
    I wasn't even sure if it was leaking or not.
    Hopefully, the head is not warped and no valves are leaking. And the rebuild goes easily.
  17. cdherman
    43
    Kansas City
    I don't see how the exhaust heat recirculation system would have spontaneously failed, exactly the same time as my EGR cooler leaked tons of coolant into the cylinders. But I have a small borescope (actually for rifle bore examination) that should at least allow me to peer down into the cylinders. If I see any coolant, its the HG for sure. I never ran it long enough to "steam clean" a piston so that will not help.
    Thanks for all the input.
  18. rjparker
    10,528
    6,609
    With no misfires or rattling I would diagnose first and teardown second.
    Car Care Nut HG Borescope at 7:40
    Bypassing the exhaust recirc is easy if needed and could be a diagnostic step.
    Remove coolant hoses here and connect hoses together.
    Gen3 Egr Cooler Flows
    Exhaust Heat Recirc Basic Concept
    #18 rjparker, Apr 1, 2026 at 10:35 AM
