AVAS location, aka "space noise"
Discussion in 'Gen 4 Prius Technical Discussion' started by Eastcoate, Mar 31, 2026 at 10:54 PM.
  1. Eastcoate
    Eastcoate New Member
    Tuesday
    United States
    2019 Prius
    I don't believe I've ever heard my used Prius make the noise.
    I found the AVAS emitter under the plastic trim cover at the front of the engine compartment.
    I removed the 5 trim cover clips (they all broke) and removed the cover.
    The AVAS (Approaching Vehicle Audible System) is on the driver's side.
    It is behind the grill but in front of the radiator.
    The release tab for the electrical harness plug, as I recall, is facing the grill.
    Press it with one hand while wiggling the plug with the other hand to release it.
    Mine looked unremarkable, so I don't know why the volume is so low.
    (I may have heard it once, but was barely audible.)
    Anyone have any ideas?
    52,396
    might be adjustable, idk, but there's a federal minimum. many have never heard it, you need to be near asomething to reflect the sound with the window down.
    and some of us have hearing loss :cool:
    cicAEHML4Hk
    #2 bisco, Apr 1, 2026 at 3:47 PM
  3. AzWxGuy
    AzWxGuy Weather Guy
    1,069
    548
    Tucson, AZ
    2021 Prius
    The device is plenty loud if operating properly. Loudest is when in reverse with ICE off. When shifted back to forward, the volume will decrease with speed until off around 22-23 mph. If your vehicle had a previous owner, it might have been modified. There is at least one other thread here on PC that discusses owners' attempts at silencing the space ship noise. Might require removal to properly inspect.
  4. VelvetFoot
    VelvetFoot Active Member
    1,232
    482
    New York State
    2026 Prius
    Complaining it's not loud enough, lol.
    Even before I got the car I rigged up a harness with a resistor as detailed in other threads to eliminate the noise.
    Haven't implemented it....yet.
    Summer's coming. We'll see how obnoxious it is with the windows down.
