2010 Prius mileage has dropped by 5 mpg
Discussion in 'Gen 3 Prius Fuel Economy' started by Jim7812, Mar 13, 2026.
  1. Jim7812
    Jim7812 New Member
    I have read the gas mileage pdf. I'm wondering why my 2010 Prius has dropped about 5 mph over the past 2-3 years. Some of this may be due to more short trips however long highway trips are also about 5mpg lower than in the past when I got over 50 mpg (currently getting about 45 mpg on the highway, 40 in town). These mpg numbers are taken from the read out on the dash.
    Here's more info:
    2010 Prius 3 with 122,000 miles. Bought it 10 years ago when it had 40k miles.
    I have changed the oil with 0w-20 full synthetic every 5k miles.
    Changed trans fluid at 97,000 mi.
    Last replaced air filter at 120,000mi.
    All other fluids are original (I plan to change them this Spring).
    Spark plugs are original (need changed).
    Replaced brake pads and rotors and bled brake lines several times; there are no dragging brakes.
    Replaced a rear wheel hub 4 months ago.
    I run Costco top tier gas 90 percent of the time (87 octane).
    I did a DrPrius test of the traction battery today and it came out as 'good' at 83.5%. I replaced the 12v battery 2 years ago.
    It has never had a check engine light or error code.
    Car seems to run perfectly as it always has. Acceleration is strong, no bogging or hesitation.
    Since the traction battery is okay, I'm wondering the the most likely culprit is the EGR valve, which has never been cleaned. Please let me know what you think. Thanks.
  2. Mendel Leisk
    41,922
    Not sure that it'd be the "culprit" for mpg drop, but definitely get on cleaning EGR ASAP.
    Any recent tire replacement?
    PrimeDan likes this.
  3. Jim7812
    Jim7812 New Member
    Tires are Michelins with about 3/4 tread left. Pressures are 37 front 35 rear.
  4. bisco
    52,397
    Clean the throttle body and get the 12v load tested for free at an auto parts store
  5. RRxing
    RRxing Senior Member
    2,554
    1,828
    NEPA
    Lower Winter temps?
    Brian1954 likes this.
  6. VelvetFoot
    VelvetFoot Active Member
    1,232
    482
    New York State
    2026 Prius
    I feel it's good to monitor mpgs; could be the canary in the coal mine.
    Unfortunately, hard to isolate factors that affect it, especially going back 3 years, without super detailed records.
    Sounds like something changed in the way you drove it though, with the 'shorter trips', unless it was external. Mpg is highly dependent on speed.
    Something changed.
    I wouldn't trust the computer for an accurate measure. I don't know how it calculates-perhaps integrating instantaneous usage? I wonder if the computer readouts remain constant over time, as in, say, 'always 2 mpg optimistic', or does that change over time?
    How about tires?
    Trying to think of something that might not be in the .pdf...
  7. Mendel Leisk
    41,922
    That’s about right, the “optimism” being around 7%.
  8. VelvetFoot
    1,232
    482
    New York State
    2026 Prius
    does it change over time?
  9. Mendel Leisk
    41,922
    It dances around some, I would think mostly due to vagaries of gas station pump shut-off, but stays about the same on average. My take, it’s almost certainly an intentional “tweak” by Toyota.
  10. VelvetFoot
    1,232
    482
    New York State
    2026 Prius
    I realize that. I just wondered if any changes could be attributed to sensor deterioration over time.
  11. Detrist
    Detrist New Member
    Michigan
    I have a 2013 with 155k. My EGR cooler was almost all the way blocked. I used oven cleaner soak and power washed like new. EGR valve carefully cleaned. Cleaned the pipe between the EGR and Intake. I took off the intake manifold and soaked in purple cleaner, got little brushes for the 4 holes that plug up. Can give uneven temperature to the cylinders if one or more blocked. YouTube has videos on this. Get new gaskets for everything or just the rubber ones at least. There is a bolt on the EGR cooler that’s the hardest part of the job. My LTFT went from 6 down to 2. Use the car scanner app w Veepeek or whatever it’s called to check your Long Term Fuel trim. It’s a lot but worth it. Also did the plugs they were pretty bad. Gained 6 MPG to 50. I got a spare Intake and Cooler from a junkyard for cheap and they cleaned up really well. Hope that helps.
    Also carefully clean the throttle body and MAP sensor (use the right Mass airflow sensor cleaner though). I put a rag in the intake and lightly cleaned the intake ports also. YouTube type in Gen 3 Prius EGR and a bunch of helpful videos showed up. If not DIY then find a shop that specializes in Priuses for a better quote. I highly recommend the EGR Cooler as some people overlook that. Hope that helps.
    #11 Detrist, Apr 2, 2026 at 7:28 PM
