Clean and Reinstall PCV Valve?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by brick, Jul 22, 2012.
  1. brick
    brick Active Member
    1,083
    79
    Upstate NY
    When I did the PCV valve on my wife's car it looked like nothing more than a metal housing with a ball bearing rattling around inside. That left me wondering, why not just clean and reinstall the original valve? Is there a reason why that wouldn't be nearly as good? I realize it's a $10 part but I have to ask the question before I go buy another for my own car.
  2. jdenenberg
    jdenenberg EE Professor
    3,953
    1,950
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The Gen2 Prius PCV is a pain to get at. If I were going to make that effort, I would use a new PCV.
    JeffD
    PrimeDan and Ryanpl like this.
  3. Patrick Wong
    18,210
    6,514
    I recall paying ~$6 when I bought the PCV valve a few years ago for my 2004.
    You could immerse the valve in gasoline or similar solvent to clean it, but why bother.
    Ryanpl likes this.
  4. darknd666
    darknd666 Junior Member
    72
    Jacksonville, NC
    Sorry to revive an old thread, but is it advisable to take this cover off to clean the PCV? What is behind it?
  5. pasadena_commut
    pasadena_commut Senior Member
    2,862
    852
    Southern California
    That doesn't look like the PCV valve on a 2nd generation Prius. Let me rephrase that, that doesn't look like the area on a Gen2 Prius where the PCV valve is mounted. Is that perhaps a picture from the Prius V listed on the left in your post?
  6. darknd666
    72
    Jacksonville, NC
    Sorry I thought I posted this in the correct section.
  7. Mendel Leisk
    41,925
    As long as we’re here: I’d leave it be, it has form-in-place gasket, will be a fight to remove. There’s a labyrinth passage, presumably to condense oil mist and drain it back into crankcase (not very effective though, judging from intake manifold oil accumulations). I don’t think it’s prone to clog, best left alone.
    darknd666 likes this.
  8. Mendel Leisk
    41,925
    Info attached:
    (Note, that extract is from last link in my signature, pages 21, 23 and 26. On a phone, turn it landscape to see signatures.)
  9. darknd666
    72
    Jacksonville, NC
    I will start a new thread later to continue this so we do not continue off subject in the wrong section.
