Spark Plug Gap... let's think about this.
Discussion in 'Gen 3 Prius Technical Discussion' started by Nor'easter, Jan 3, 2020.
  1. ASRDogman
    ASRDogman Senior Member
    7,833
    3,990
    Mine didn't look bad at 110,000. But in any case, 100,000 miles is a lot of miles for any plug.
    Ed Beaty likes this.
  2. Classic Car Guy
    Classic Car Guy Active Member
    466
    127
    Northwest, USA
    Newer cars have higher ignition voltage set on different timing using different kind of plug like the iridium for longer life. not like the older cars with plugs they don't last. I tried using the early accel (the one that's made in USA with a higher voltage 1980's) on a tricked out 18rg motor with a higher compression. it was running better but I notice I was wearing out the tip of the plug faster than the usual. with all the different plugs and changes, I ended up using a 3 caret platinum setting the gap from 32 to 42.
    This is a pulled out stock Prius plugs with 120k miles.
    #22 Classic Car Guy, Jan 6, 2020
  3. Classic Car Guy
    466
    127
    Northwest, USA
  4. Mendel Leisk
    41,925
    Is the horse dead?
    Grit likes this.
  5. bisco
    52,399
    at least until someone is willing to do some testing. pretty conservative group here
  6. elementnomore
    elementnomore Member
    136
    44
    Los Angeles
    I didn’t adjust the gap
  7. bisco
    52,399
    well you're no fun :cool:
    Grit, Mendel Leisk, SFO and 1 other person like this.
  8. Classic Car Guy
    466
    127
    Northwest, USA
    I blew up so many plugs in my life. Don't do this at home..:p
    RMB likes this.
  9. PersonaXIII
    PersonaXIII Junior Member
    Sacramento
    I just got a set of OEM for my 110k mile four. (Persona has 16k). Only one had the correct .040 " (1mm) gap. One had .055 gap and slightly tweaked ground electrode. Japan made, Toyota / Lexus packaging. Could the batch be 'seconds'? Since they came from Ebay, and substantially less expensive, I examined closely for the usual identifiers as found on Denso's page. All check out.
  10. ASRDogman
    7,833
    3,990
    :eek::whistle:
