Is cabin heat "free" if a Prime is in HV mode?
Discussion in 'Gen 5 Prius Main Forum' started by Will B, Mar 24, 2026.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,318
    607
    Alberta
    2024 Prius Prime
    XSE
    Does anyone work for free?
    If so, they are paying the cost themselves.
  2. DOHCtor
    DOHCtor Active Member
    170
    102
    Levis (Quebec city's south shore)
    2024 Prius Prime
    SE
    @Will B I was pulling your leg a little. ;) Once the engine runs, the heat is mostly from the engine coolant. In that case it would be "free" except if it's cold enough outside so the engine will perpetually run to produce it. In that case it's not. On cold-ish temps, the best way to heat is with the seats heater and the steering wheel heater. Goes to you own cold resistance of course. Mine is quite high.
    When it's very cold outside, i will try to run the engine on charge mode (23-25 it's doable, feature removed in 26 models..) so the engine oil gets fully warmed up and humidity/raw fuel gets out of it. In that time, heat is mostly free as the engine produces loads of it. When in hybrid mode, heat will be produced by a mix of heatpump and engine but if cold enough, it will force the engine to run. Not if it's hot enough outside however. Depends on loads of different conditions i can't enumerate right now..
    Prodigyplace likes this.
  3. KCWhitney
    KCWhitney Active Member
    143
    118
    Connecticut
    2025 Prius Plug-in
    will this thread ever end?
  4. ChapmanF
    18,894
    Like most threads, it'll probably quiesce for a while eventually, then somebody with the same question will find it five or ten years later, and post on it, and somebody else will post "hey, do you know you just posted on a ten-year-old thread?!" and the person will post "sure, but it's about my question" and it'll go on from there.
  5. Paul Gregory
    2,318
    607
    Alberta
    2024 Prius Prime
    XSE
    Not until someone admits that nothing is truly free.
  6. mingc
    mingc Member
    102
    70
    Portland, OR
    2023 Prius
    XLE AWD-e
    Sure it is. You've just got to find someone else to pay for it. It's the best kind of free.
  7. hill
    9,003
    If you love what you're doing - you'll never work a day in your life
    says most of the loafers on welfare for life - other people's money. Why work & get oneself some dignity & self-respect
  8. mingc
    mingc Member
    102
    70
    Portland, OR
    2023 Prius
    XLE AWD-e
    You must not be a capitalist. Externalize your risks and costs. You don't get rich by spending your own money.
  9. Paul Gregory
    2,318
    607
    Alberta
    2024 Prius Prime
    XSE
    It's fun to eliminate money from the equation, but it always counts.
  10. Paul Gregory
    2,318
    607
    Alberta
    2024 Prius Prime
    XSE
    How is it free, if someone had to pay for it?
