Another EGR thread
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by darknd666, Apr 1, 2026 at 12:01 AM.
  1. rjparker
    10,545
    6,620
    The pressure is to force drops on a borescope test. It can look fine and should either way.
  2. darknd666
    darknd666 Junior Member
    77
    Jacksonville, NC
    Im confused by your statement? What do you mean? Are you saying it can still be the head gasket even if no drops form?
  3. rjparker
    10,545
    6,620
    The pressure can hold either way
  4. darknd666
    77
    Jacksonville, NC
    So is my test good?
  5. darknd666
    77
    Jacksonville, NC
    Ok so Ive added a ziptie and it seems to hold at 16PSI which is from what ive tead the test pressure. Ill just keep monitoring and add pressure as it drops.
  6. darknd666
    77
    Jacksonville, NC
    Spark plug conditions for those curious. Left to right 1-4
  7. darknd666
    77
    Jacksonville, NC
    This is looking more like an EGR problem and less a blown head gasket, unless the leak is only present under heat soak cycles.
  8. darknd666
    77
    Jacksonville, NC
    Sorry I forgot to mention if removing the EGR cooler caused enough coolant to be removed to hinder the coolant pressure test?
  9. ChapmanF
    18,567
    I think what rjparker is getting at is that you can use that pressurization kit to accelerate a borescope test—by pumping up a good pressure in the system, you can make drops form faster so you have a better chance of seeing them on your borescope—but that it wouldn't be a very sensitive test to just rely on watching for a pressure drop. Tiny drops slowly leaking just might not make enough difference in the gauge pressure to notice, or to tease out from the effect of, say, ambient temperature changes during the time that you're watching.
  10. darknd666
    77
    Jacksonville, NC
    I left it pressurized and started installing parts. New manifold is in, sensor was cleaned, new gaskets, EGR. I am not seeing a drop of anything in thise cylinders at 20 psi. I will leave it pressurized overnight, there will be some pressure loss at the coolant reservoir because I dont think the seal for the tester is on very well but i made adjustments to ensure it will not come off.
    The spark plugs were pretty much done for, there are pictures of them. Ill install them when they come in the mail. Burp the cooling system. Pump and thermostat are being replaced. I just got the offer accepted on ebay for an OEM new pump $115 is a good deal. OEM thermostat as well. There is evidence that pump or thermostat (maybe both) is going to fail soon...no leaks but there appears to be some evidence of a leak a long time ago. Maybe . But its pretty decrepit looking and its only going to help prevent a head gasket failure.
    My only concern next will be oil consumption, ill do a compression test in the coming days to rule out the piston rings. After reviewing the maintenance history reports i can see that early on its oil was changed every 5k ish. Then the next owner decided 10k oil changes were cool...
  11. darknd666
    77
    Jacksonville, NC
    Installed new spark plugs (Rhutheniums), catch can, intake manifold, i drove off with no cowl or undercarriage and it behaved like it never had a problem to begin with. It obviously stuttered on the first start but smoothed out almost immediately. Power band is much stronger and responsive.
    When I go to do the water pump and thermostat ill post what the intake looks like and if there is a pool of oil under the throttle body.
