Front lighter charger stopped working, how to troubleshoot
Discussion in 'Gen 4 Prius Main Forum' started by Victorio Mo, Apr 4, 2026 at 1:52 PM.
Tags:
  1. Victorio Mo
    Victorio Mo Member
    131
    33
    Folsom, California
    Hi all,
    in 2016 Prius Lighter Charger located in front stop working. The other on the rear is working OK.
    Is this could be some fuse problem ?
    Anybody tried to fix it?
    Thanks to all
    Dai
  2. ChapmanF
    18,569
    They're on separate fuses, so the fuse for the front one would be a reasonable thing to check.
    Keep in mind that if you find a blown fuse, you haven't found the problem, you've found a clue to the problem, and when you find why the fuse blew, then you've found the problem.
    Victorio Mo likes this.
  3. Victorio Mo
    Victorio Mo Member
    131
    33
    Folsom, California
    Thanks Chapman! I will try to find which one,
  4. ChapmanF
    18,569
    The owners' manual has a drawing to show which fuses are which, also shown on the lids of the fuse boxes.
