Gen 2 Prius toe adjustment diy?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BatteryBob, Apr 4, 2026 at 4:53 PM.
  1. BatteryBob
    BatteryBob Junior Member
    Is it possible to adjust Prius toe at home? What about caster/camber?
    My 2009 Prius was on the alignment rack and diagnosed with needing a toe adjustment. Between our Prius and friends that like to work on their cars I thought it would be fun to be able to do my own toe adjustments. Are there any how tos/links?
    Thanks!
  2. Tombukt2
    13,472
    2,420
    Yes and there's a gazillion videos about it online. You have to know what toe is and how to. Measure it on car with tape. Pita.. but Otay. It is doable. Once set on your car count threads exposed on each side tie rod .
  3. Mendel Leisk
    41,925
    Info:
  4. BatteryBob
    Ive seen a lot of videos online but nothing specific for a gen 2 prius
  5. Tombukt2
    13,472
    2,420
    It doesn't matter what kind of car it is it's same as Corolla or yaris exactly. Any fwd vehicle will be almost exact same . So find those videos you'll be adjusting the same tie rods.
