Adding Second Set Of Wheels With Snows (TPMS)
Discussion in 'Gen 5 Prius Technical Discussion' started by VelvetFoot, Feb 5, 2026.
  1. Gokhan
    Gokhan Senior Member
    6,556
    2,613
    Paramount CA
    Yep, it is standard operating procedure for garages to lose your beautiful, top-quality OEM tire valve caps.
    Do what I plan to do. Get some cheap ones from Amazon and replace the Japanese OEM Pacific Industrial Co., Ltd. tire valve caps with those whenever you take the car to a garage or service. Then, put the OEM tire valve caps back. You can get the OEM ones for cheap at the next Black Friday sale.
    VelvetFoot likes this.
  2. Mendel Leisk
    41,925
    Whenever I hand either the car, or loose wheels, over to a tire shop, the valve caps are in my pocket.
    What ARE you on about; those are stock, gen 3 Plug-In rims.
  3. VelvetFoot
    VelvetFoot Active Member
    1,236
    485
    New York State
    2026 Prius
    Can't find the spares now. Those things are easy to lose. :)
    Gokhan likes this.
  4. Gokhan
    6,556
    2,613
    Paramount CA
    I know, but that shouldn’t stop you from experimenting with aero wheel covers. For example, this: ;)
    Here is the detailed aerodynamics study by that guy who tried that cardboard aero wheel cover on his silver Gen 3 Prius:
    Wheel covers and base pressure on a silver Gen 3 Prius
    #24 Gokhan, Feb 15, 2026
    mingc likes this.
  5. Gokhan
    6,556
    2,613
    Paramount CA
    Gen 5 aero wheel covers look very good, in my opinion.
    #25 Gokhan, Feb 15, 2026
    vvillovv likes this.
  6. Gokhan
    6,556
    2,613
    Paramount CA
    This is actually a very bad idea. If they decide to wash your car (as a courtesy) or if it rains, etc., etc., your TPMS sensors could be ruined. Just replace the tire valve caps with sacrificial ones when you hand the car over, and replace them with the good caps, such as the Japanese Pacific Industrial, Co. Ltd. OEM caps, when you get it back.
  7. VelvetFoot
    1,236
    485
    New York State
    2026 Prius
    Found em! :)
    Gokhan likes this.
  8. VelvetFoot
    1,236
    485
    New York State
    2026 Prius
    55.1 mpg, actual, on a full tank with the X-Ice's. So, I think it did drop off a little bit. Still cold, but I do try somewhat. :)
    Gokhan likes this.
  9. SXP
    SXP Junior Member
    31
    Huntington Beach, Ca
    2025 Prius
  10. Mendel Leisk
    41,925
    In 2010 I got some Corolla steel rims from a Toyota Dealership for $70 CDN apiece. This was about 3 weeks after purchasing our 2010 from a different, nearby dealership. When I phoned the latter asking about rims, the only option they offered was stock 15" alloys, at something like $350 CDN apiece. They explained to me that the Prius was their "flagship" vehicle, no steel rims would be compatible.
    #30 Mendel Leisk, Mar 18, 2026
  11. VelvetFoot
    1,236
    485
    New York State
    2026 Prius
  12. notspam3
    notspam3 Member
    97
    53
    Toronto
    2024 Prius Prime
    XSE Premium
    LOL Sounds like total stealership BS to me. When I bought our new XSE Prime last year they quoted something like $3500 for snow tires on steel wheels. I ended up getting the same rubber on 16" aluminum alloy wheels for $1800 installed with TPMS at a local tire shop. Steel wheels at costco and tire shops around here go for around $50/ea and alloys can be had for $70/ea. The dealer sells OEMs at $350/ea so they can rape suckers at lease trade in time.
  13. vvillovv
    vvillovv Senior Member
    4,332
    1,516
    NY
    One of those was the first thing to be missing after dealer first 5k service. Last year another three were gone and a metal one that I had put on a stem a year before wouldn't come off by hand.
    At the car wash too? oui
    Just for laughs (if laughing while reading) I think the only thing done at the first service was a wash.
    Gokhan likes this.
  14. Gokhan
    6,556
    2,613
    Paramount CA
    Yep, they will lose your tire valve caps and then put your car through a car wash without them to see if your TPMS sensors will survive. LOL
  15. dicknose
    dicknose New Member
    Toronto
    2024 Prius Prime
    XSE Premium
    Both sets of tires on my '24 are sans TPMS (I swapped the stock 19s for 16s). Covered the warning light on the dash with a piece of electrical tape and I check the tire pressure every 2-3 weeks. Shelf-life of a TPMS sensor is somewhere between 5-10 years (depending on how much you drive). Once the battery dies, they're garbage.
