Leaking Brake Fluid
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by andreimontreal, Apr 6, 2026.
  1. andreimontreal
    andreimontreal Active Member
    390
    118
    40
    Montreal
    Early this winter, traction control, abs, parking brake ( red exclamation with circle and parantheses), and brake warning light ( yellow exclamation with circle and parantheses) turned on. Those came and went then they stayed on for good. I knew this rear wheel sensor was acting up, and I had the same lights, and I thought it was that again because I got the same lights last year.
    One time, the parking brake sign/light turned on for a min or so when I put the car in ready, then the other lights came on. That's when I realized I was losing brake fluid. My cup under low.
    I topped it; it takes 1-2 months on average for it to empty (hard to tell, I guess it depends on usage); I could swear I heard recently drops fall inside the bay on metal as I was stationary and depressing the brake. Recently, I heard the booster motor whirl for like 30-60 seconds or so. I topped it then it started doing its normal thing, short bursts. When I top it the lights go away btw and everything works fine.
    This makes me think the leak is at the brake booster or bellow it since it was so empty that the engine was running without compressing anything.
    I can't confirm 100%, but at least when the lights are on, the ABS (and of course the cruise control) are not working. Not sure if the ABS is working when topped off - but off the top of my memory I think it did the last time snow fell; I wasn't trying to actively slide. Early in the winter I did a few rounds in the parking lot and ABS was engaging.
    Of course I will address this asap. I am aware that if that tiny gap suddenly bursts I'm SOL right away. Pulling codes tomorrow. Some early questions:
    1) Are there any known regular failures that I should start with/ look for?
    2) Is there a possiblity that one of the pipes burst and that the booster/abs control are fine? Given that the brakes work normally once I top it off. Or when this happens the brake booster needs to be replaced.
    I'm not 100% sure yet how to troubleshoot this to pin point the issue. Once I open it I guess it will be more clear.
  2. rjparker
    10,938
    6,861
    If you are losing fluid you have a leak. It is leaking. There are no paths into the engine like a vacuum operated system might have.. Find the leak.
    andreimontreal likes this.
  3. Andy Pants
    Andy Pants Member
    37
    29
    WIsconsin
    There is a well know issue with our brake booster/accumulator pump on 3rd gens, however when this is the issue you typically don't lose fluid as it is leaking into itself and can't maintain pressure basically. I'm thinking you need to trace all the lines and find the leak.
  4. ChapmanF
    18,918
    I had an old Ford once where a brake line to the rear had rusted and developed a split. It would only ever leak when braking so hard that the fluid pressure pushed the split open and fluid sprayed out. The rest of the time, no leak.
    There was no sign of leaking near that brake tube at all. There was just a spot wet with brake fluid clear on the other side of the underbody where the spray would hit when it sprayed out of the split line.
    I could confirm it by wrapping shop towels around the line and then stomping the brakes hard. The split was where the shop towel got wet.
    (Don't just go under the car and watch for something like that while somebody stomps the brakes; a jet of high-pressure fluid like that can get through skin and be a surgical emergency.)
    #4 ChapmanF, Apr 6, 2026
  5. andreimontreal
    390
    118
    40
    Montreal
    Yeah, that's what I'm afraid of. I'm in for some real fun apparently. I got your warning loud and clear thanks.
  6. ChapmanF
    18,918
    Well, don't make it out to be more daunting than it is; there really aren't all that many brake lines or connections to look at, and a place wet with brake fluid usually isn't too hard to spot.
  7. andreimontreal
    390
    118
    40
    Montreal
  8. ChapmanF
    18,918
    C1202. C1256 (reservoir level, accumulator low pressure)
    C1238, C1466 (about right rear speed sensor signal)
    C1239, C1467 (about left rear speed sensor signal)
    P1578
    P1578
    I transcribed the trouble codes from your attachments for you—I recommend doing that, for a couple of reasons: (1) if you do it yourself (once), you save everyone reading your post having to make extra clicks just to see what codes you're talking about, and (2) it allows your thread to come up when people search by those codes.
    The speed sensor codes could reflect bearing wear, or something else could be going on like wire damage or bad connections. The troubleshooting steps in the manual might help narrow down the possibilities.
  9. andreimontreal
    390
    118
    40
    Montreal
    Agreed, my bad.
  10. rjparker
    10,938
    6,861
    The foreign object on sensor codes are not good.
  11. ChapmanF
    18,918
    At the same time, it's good not to take trouble code fortune cookies too literally. The ECU doesn't have a camera there to see if there's an object on the sensor tip. It's making a guess based on characteristics of the sensor signal coming back, which is why the "trouble area" column in the DTC description has, like, seven possibilities, including wire damage or connections, as well as foreign objects.
    The two DTC detection conditions are that the signal is noisy for at least 5 seconds at 20 km/h or more, or that it's noisy once per wheel revolution (which might suggest something stuck to the rotor more than to the sensor tip) for at least 15 seconds at 10 km/h or more.
  12. rjparker
    10,938
    6,861
    I had a foreign object code once and it required a new hub bearing assembly.
  13. ChapmanF
    18,918
    That's definitely one of the ways that code can be triggered.
  14. andreimontreal
    390
    118
    40
    Montreal
    Did you have any noise? Or play in the wheel when you lifted it? I'll deal with this down the road.
    I found the leak. The L main line is cracked. Like yChap said, I lifted, and asked someone to depress the brake. I thought it was the flexible line at first. But then I looked above and noticed the flow was coming along the hard line.
    It's part 47322 . The purple line crossing along the car.
    I'm thinking of making it my self. The daunting part is that bolts look so rusted. I guess a lot of penetrating oil and heat.
    PS: or at least to mend it.
  15. rjparker
    10,938
    6,861
    No noise or play. The bearing itself is fine. But the speed sensor is not and that creates codes and degrades your braking.
  16. ChapmanF
    18,918
    Yeah, $101.62 is enough to make you think of doing that ... certainly if you already have a roll of nice CuNiFe on hand and a flaring set that you're comfortable using.
    On the other hand, the $101.62 gets you a nice line already just the right shape and ready to go in.
  17. andreimontreal
    390
    118
    40
    Montreal
    I don't but I've been wanting to have the tools and now it's a good time. Next car I buy I'll change my line to copper so I don't have to deal with this when it rusts out.
    Can that affect the mpg? I've noticed for a few months it went up unreasonably. I was about to investigate when I discovered the leak and I thought it was just that - somehow.
  18. rjparker
    10,938
    6,861
    Mileage went up? Usually it goes down.
  19. andreimontreal
    390
    118
    40
    Montreal
    My bad, it went down. I was thinking l/100km in my head.
  20. rjparker
    10,938
    6,861
    Yes you are coding for two speed sensor problems. That can impact regen and mileage. In addition you can lose traction control and abs. To say nothing of all the dash warnings.
