How to disable beeping when in reverse
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jbean, Jun 23, 2020.
  1. jbean
    jbean Junior Member
    78
    Please tell me the steps to disable the beeping when car is in reverse.
  2. MickyMatter
    MickyMatter Active Member
    260
    168
    Germany
    • Remove the left side of the dashboard
    • Locate the black, cylindrical beeper at the very left side
    • cut its wire
    (• insert an on/off switch)
    Sorry, but as far as I know, there's no other solution.
    If you cut off the beeper, then other warnings will disappear, too. (E.g. seat belt, low voltage, low fuel, whatever)
    [​IMG] [​IMG] [​IMG]
  3. Mendel Leisk
    41,925
    There is a software method. Dr Prius for one (Phone App, works with a bluetooth dongle on obd port) will do it, IIRC). Various other phone apps too, and of course Techstream.
    Personally, I can't get too excited about it, don't want to disable it. I kinda wish instead of a beep, it was a little voice that kept saying "you're in reverse, you're in reverse, you're...". The beep doesn't work for me.
  4. jbean
    jbean Junior Member
    78
    This is my third battery and twice I disabled it, but don’t remember the steps, it was a software change. I don’t understand your software suggestions. Can you please say a little more?
  5. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    This is the way I remember Gen 2
    Mase likes this.
  6. ColoradoBoo
    ColoradoBoo Senior Member
    1,271
    880
    Monument, Colorado USA
    I know!! I hated ours so much I asked the service department at the dealership to turn it off when I brought her in for her first service. The service dude tried to tell me it can't be done but I told him other dealerships said they can do it so he talked to the head service guy and had someone turn it off for me. (I doubt they would've cut any wires at the dealership....must be a setting somewhere in the computer.)
  7. ColoradoBoo
    1,271
    880
    Smathew87 likes this.
  8. AzusaPrius
    AzusaPrius Senior Member
    2,243
    931
    Just download the app.
    Other apps can do it too like Carista.
  9. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Gen 2 does not use an App, Gen 3 and Gen 4 do.
    Gen 2 has a chicken dance that owners do with the controls.
    2Fats likes this.
  10. MickyMatter
    260
    168
    Germany
    Okay, I'm out – maybe due to my European Prius. Sorry for irritating.
  11. dolj
    dolj Senior Member
    8,559
    4,349
    Wellington, New Zealand
    As far as I am aware, you can use Techstream and other apps (like Carista) to do those various customizations. But if you know the other method, I can be easier/quicker and the bonus of no special equipment required.
  12. 2Fats
    2Fats Member
    101
    61
    Missouri
    When you plug in using those apps it says that the function of the (removing beep etc.) isn't available on that model year. I know, I paid the money for them, and they don't work for that as I thought they would. :(
    There is a chicken dance. It's not bad to do.
    Disabling the Reverse beep
    Turn your car either on or to ON mode (IG-ON is pressing the power button twice while your
    foot isn't on the brake)
    Next cycle through the ODO button (if your car is already displaying ODO you just have to hit it 3
    times TripA,TripB,ODO)
    Turn off the car
    Now while applying pressure to the brake hit the power button (aka start your car)
    Within 6 seconds after starting push and hold ODO button for 15 seconds
    After 15 seconds have passed while still holding the ODO button shift from P to R, then back to P.
    Let go of ODO button
    On trip display, you'll see either b-on or b-off we want b-off.
    Press the ODO button until you see the display reading b-off
    Power off the car
    Note** If you disconnect your 12v battery anytime after doing this procedure the car may reset itself
    and turn the reverse beep back on. Simply go through the steps again.
    Disable the Seatbelt Beep
    The procedure to disable the seatbelt beep is the same as the reverse beep except for one step.
    When you get to the step where you would start the shifting process substitute that with the
    buckling/unbuckling of the appropriate seat. Also, you must have someone or yourself seated in the
    passenger seat while disabling the passenger seat.
    Following these simple steps should result in successfully disabling those annoying beeps that your
    Prius has.
    Minima Domum likes this.
  13. Smathew87
    Smathew87 New Member
    Lucerne Valley, CA
    You are the G.O.A.T. !!!!!!!! Your link has saved my sanity! Thank you so very much. My beep has gone away.
    #13 Smathew87, Apr 6, 2026 at 4:42 PM
