Resurface head and replace valve seals etc at time of headgasket replacement or not?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by cdherman, Mar 31, 2026.
  1. BiomedO1
    4,473
    2,351
    Left Coast
    Did you find any signs of a leak in the head gasket? There should've been a rupture between coolant pathway to cylinder on either side of the gasket. If you can't find that. You can find the EGHE hoses. Plug one end and do a pressure or vacuum test on the other end to see if it holds pressure or vacuum. Keep the pressure low so you don't stress the seams of the heat exchanger. That would give you a definitive answer. Do the same for the EGR coolant tubes too.
    Good Luck...
    #21 BiomedO1, Apr 2, 2026
  2. cdherman
    cdherman Member
    67
    26
    Kansas City
    well, I finished the tear down.
    Points to ponder:
    -- there was some coolant in cyllinder 1 and 4, but not much. However, I had rotated the engine to TDC, which puts 1 and 4 at the top and thus any more coolant might have been forced out, at least of cylinder 1, which is compression cycle, right? The other is exhaust cycle, so a valve would have been open...... Coolant might have just drained into the cylinder from residual coolant in the head somewhere that leaked into the cylinder when I cracked the head loose.
    -- My heads look a lot different than all the videos. All 4 piston tops are pretty clean, and the heads are nice looking too. Engine was not burning oil, had no issues. EGR cooler was not plugged.
    -- I pulled one exhaust valve. It looked quite nice. I learned that I am not steady enough and my mits are too large to put valve keepers back together. To do 16 of them would drive me hysterical bonkers. I called the local head shop -- they are busy and would take 14 days to do my own heads. I am not interested in swapping to some other head, as my heads are near perfect. The owner of the shop was saying that in his experience, valve seals are not much of problem with Prius these days.
    -- I did not see a clear point of leakage in my HG. But I did not run the engine much at all after the event.
    I am contemplating just putting it back together with the Felpro HG and all the new seals from Toyota and see how it goes.....
  3. BiomedO1
    4,473
    2,351
    Left Coast
    LoL; "a local head shop" means something totally different out here in "wacky tobacco land". LoL
    Axle grease will hold those keepers in place, so you can release that spring.
    Good Luck.....
  4. Mendel Leisk
    42,223
    Post a picture?
  5. rjparker
    10,950
    6,869
    At this point it does not matter much. The challenge now is to reassemble properly with new gaskets and sealants. Plus get the timing and valve train parts back in their original positions.
  6. cdherman
    cdherman Member
    67
    26
    Kansas City
    My sentiments precisely. Honestly, the Prius timing chain looks like I could do it with one hand compared to a timing belt on a Subaru boxer. I used the "shop towel" trick that several of the videos demonstrate online to fasten the cam lobes in place. Worked nice AFAICT -- so getting the camshafts in should be easy enough. I used two egg cartons labeled for the lifters, rockers and caps, so they will go back to their respective original locations.
    Now, I managed to damage one of the dowel pins that decided to stay with the head. Tried to remove it and just buggered it up. $1.71 from the local dealer, so no problem. And it made my wife happy that I cannot do anymore wrenching on the Prius until Easter is over. To the dealer Monday for that and the timing cover seal for the timing pully that is not included in the Toyota kit, per NutzandBolts video......
    If it turns out that the exhaust heat recovery thing is the culprit, then so be it. How a leaking EGR cooler could trigger the exhaust heat recovery thing to fail is beyond my comprehension, but this whole sequence has an negative karma overtone to say the least, so anything is possible I guess.....
  7. cdherman
    cdherman Member
    67
    26
    Kansas City
    Well, decision to have heads checked by a good shop got made for me in a different way -- saw my eye doctor this AM and getting semi-urgent cataract surgery in AM. Soooo, I won't be able to wrench on the Prius for a week or so. Might as well take the heads to the shop. They say 4 days to surface and do leak down test. More if they have to do the valves.
    But if I cannot work on the Prius, may as well spend the time and get it done right.
    Shop owner noted that Prius valves do not "rotate" like some vehicles used to and still do in some instances. This means that in his opinion, you must do a complete regrind if you take the valves out to replace the seals, because they will have "seated" in to a particular position and in his opinion, even if they were not leaking, they will leak sooner or right away after just replacing the valve seals. He was of the opinion that if the leak test was OK, then leave the old valve stem seals alone.
    frodoz737 likes this.
  8. frodoz737
    frodoz737 Top Wrench
    4,790
    2,553
    33
    Sorry to hear about your sudden medical, but I think that's the best decision for the head. (y)
  9. rjparker
    10,950
    6,869
    You don't want the head surfaced if it does not need it. Too much can impact timing.
    Generally you want a machine shop to inspect and advise. This is an area where diy instructing a shop can cause issues because most shops will do what you say.
  10. frodoz737
    4,790
    2,553
    33
    If it required that amount of material to be removed...might as well pull the block. He'll be fine. ;)
  11. cdherman
    cdherman Member
    67
    26
    Kansas City
    Head was cleaned up, they took minimal material off. Vacuum tested the valves and left the seals alone.
    Re-installed with FelPro headgasket. Followed various videos. Re-used headbolts after checking per specs.
    "Tricky" bolts down under the inverter as NAB alluded to are indeed a PITA.
    But for me the timing chain cover, while covered with sticky uncured RTV was perhaps the "low point of my day". Personally if doing again, I'd get a couple of sacrificial bolts, cut the heads off, and use them as guide studs to ease the timing cover on squarely. It has guide pins but by the time you are on those pins, seemed to me, I had smeared RTV all over. No leaks thus far however.
    Coolant consumption is gone (I have driven through multiple heat/cool cycles). First few cycles there is still air making its way out of the system, so there was some worry, but in other vehicles its been a similar experience. I decided to post up the "success" declaration once the coolant level was thoroughly stable!
    In closing, I will re-iterate. Never ever, EVER put an EGR cooler back on after cleaning, without some form of testing for integrity. It can be as simple as a good blow with your lungs, but I learned the hard way what happens if the EGR cooler leaks coolant.
    CR94 likes this.
