12V battery died again
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by IABoy987, Mar 27, 2026.
  1. IABoy987
    IABoy987 Member
    216
    86
    Iowa
    2018 Prius Prime
    Months ago I posted about my Prime 12V battery dying, and the knowledgeable people here explained the Prime battery facts of life to me. What I should have done instead of using the accessory position, was to turn the car "fully on" ready to drive in order that the big battery keeps little 12V happy.
    So today while wife ran some errand I waited in the car. I turn the car "fully on" and verified that in fact car would actually move in F or R gear. I then pushed the park button and started reading a book. About 30 minutes later the radio went off and the dash indicator said "12V battery low, see owners manual." :( I turned off car and when wife returned much later, luckily the car started and we drove home.:)
    Obviously having car ready to drive, but not actually driving, does not "connect" big battery to keep little battery charged up.
    Am I missing something as in a work around would be to put on parking brake, keep foot brake pedal depressed and car in F position so big battery actually keeps 12V alive?
  2. VelvetFoot
    VelvetFoot Active Member
    1,236
    485
    New York State
    2026 Prius
    Your profile says 2018. Is this a Gen5?
    Anyway, I have an '26 HEV, but I just went out, started the car, put it in Park with the radio on and went inside the house for a while. The battery monitor shows it was charging when in Park. Only for a few minutes though, I didn't let it go for a long time.
    The only time I got that message was when I was fooling around with my dashcam on Accessory. It wasn't too long either, so it's pretty sensitive.
    I cut and pasted a couple of things from my manual.
    This is probably a PHEV specific thing, I bet.
    IABoy987 likes this.
  3. IABoy987
    IABoy987 Member
    216
    86
    Iowa
    2018 Prius Prime
    Thank you VelvetFoot for the information. ;) A lot of good stuff, but not sure how much is applicable to my "older" Prime.
    Yes, my Prime is a 2018 so what generation category should I be looking in? I saw plug in and troubleshooting and went here thinking where my Prime is.
  4. VelvetFoot
    1,236
    485
    New York State
    2026 Prius
  5. BiomedO1
    4,184
    2,186
    SacTown, Ca
    Have you checked your battery voltage with a meter or ever replaced your 12V battery? Using a volt meter will tell you, if your system is working properly. Car OFF should read 12.xV, car ON at least 13.8V+. If your car isn't doing that; there's a problem with your DC-DC converter or your not in "READY" mode. If you was actually in "READY" mode, there's NO way the battery could've slid under 12V. Even if your traction battery ran low; the car's ECU would've turned-ON the ICE, same as it would while your driving. Have you ever replaced the OEM battery from 2018, it's 8 years old and probably on it's last legs. Get a free check at any auto parts store.
    There's also a misconception that there is a 12V maintenance charge while the car is plugged-in. That is WRONG; the 12V maintenance charge is ONLY ON while the traction battery is ACTIVELY charging. If your read your OM; it states to unplug your car after the traction battery is fully charge; otherwise the car will actually drain your 12V battery by doing more internal readiness testing.
    FWIW; the car will start with the battery all the way down to around 10.75V; but it may start throwing phantom error codes due to lack of power.
    IMHO; testing is the only way to nail-down an issue. Guessing usually doesn't solve anything. Good Luck....
    #5 BiomedO1, Mar 28, 2026
  6. bisco
    52,404
    was there something about gen 4 that wouldn't let you camp in it because it shuts down after a certain time?
  7. IABoy987
    IABoy987 Member
    216
    86
    Iowa
    2018 Prius Prime
    Thanks for the battery information.:)
    I checked my records and the 12V was replaced with a genuine Toyota battery April 2023, when I had car towed in due to dead battery. Dealers said battery load tested showed was bad and replaced. Did not say if they investigated further or just replaced battery and done.
    I will check the 12V with my good Fluke multimeter and see what kind of voltages are happening in plugged in/ unplugged, Off, Accessory, and Drive positions.
    BiomedO1 likes this.
  8. IABoy987
    IABoy987 Member
    216
    86
    Iowa
    2018 Prius Prime
  9. BiomedO1
    4,184
    2,186
    SacTown, Ca
    Since I've retired; I've noticed my battery hovering around 12V or just below - now that it isn't a daily driver. It's never stranded me or failed to start; but I do keep an eye on it's level and place it on a 6A charge for a few hours a couple times a year. This gets the battery back up to 12.5+V - where it should always reside. I do unplug after the traction battery fully charges; though sometimes the next morning.
    Hope this helps......
    I don't believe the 20 minute auto-shut-off limitation applies to the gen4 Prime - don't know for sure, never tested that. If it does apply, the simple work-around would be to set your parking brakes and throw the car into N. This serves two purposes, If the car isn't in "ready" mode - the car won't go into N. You KNOW your in ACC mode and NOT Ready. You need to be careful though, because you can easily bump the car into D. This shouldn't be an issue, if your parking brakes is set and your not on the "gas pedal".:cool:
    #9 BiomedO1, Mar 29, 2026
  10. vvillovv
    vvillovv Senior Member
    4,332
    1,516
    NY
    my experience with the Gen4 Prime in READY mode for around 30 minutes, CD playing, ( in HV mode, so the engine can switch on if the system calls for it to) is that the (hybrid - big- battery) looses charge slowly 1/10 mile worth at a time on the dash gauge. I never looked at the 12 volt reading on any of the apps I have on my phone that show it during those times.
    My cars 12 volt system typically shows the 12 volt readings of around 12.2 - 12.3 after the first push of the ( READY button ) and 14.1 volts after the second push of the READY button. YMMV
    There are modes and/or settings combinations that will drain the 12 volt system !
    @ChapmanF can explain the technical details of why the Toyota Hybrid Synergy Drive system behaves that way.
    If I recall correctly - A/C On, in HV mode and neutral gear- is the Big one ! 10 volts in less than 1 minute..
    or @hobbit 's deep dive into everything Gen2 one person could possibly do, if they are still up, are good reads if you can convert between GENs.
    #10 vvillovv, Mar 29, 2026
  11. IABoy987
    IABoy987 Member
    216
    86
    Iowa
    2018 Prius Prime
    For a rainy night entertainment, I slogged through the Prime owners 700+ page manual, but did not find anything specific how to listen to radio without instantly killing the 12V battery.
    However I did find the DRIVE Mode, EV/HV and EV mode switches which I forgot about after our car was in for bodywork and all batteries were off, so after re-connection, these multi-information display respective indicators were off (out of sight out of mind).
    If I read the material right, for us as around the town with infrequent highway driving, the best fuel and driving combination would be ECO mode and EV auto illuminated. Would this be the most efficient battery/fuel drive setup?
  12. BiomedO1
    4,184
    2,186
    SacTown, Ca
    Yes, both ECO and EV auto (green icons) should be lit in your dash. When I jump on the highway, I'll normally force HV mode by toggling OFF the EV button. The electric motors are most efficient up to around 45 miles per hour; once you get past 50-55 mph - the gas engine is more efficient. Obviously if your only on the highway for a few exits, you should leave it in EV mode. I do this to conserve EV mode for surface streets in city traffic. The car is more responsive in EV mode; though you can also toggle over to sports mode - but your mpg will suffer.
    Hope this helps....
  13. IABoy987
    IABoy987 Member
    216
    86
    Iowa
    2018 Prius Prime
    Yes thank you for verifying what I read.
  14. Fenichel
    Fenichel Junior Member
    31
    West Vancouver, BC
    2023 Prius Prime
    XSE Premium
    Can you be more explicit about what measure of efficiency you are using? One could compute it as (a) miles per erg of energy put into the car or as (b) miles per dollar's worth of energy put into the car. When electricity is cheap enough, EV mode might be more efficient in the (b) sense even when it is less efficient in the (a) sense.
  15. KH111
    KH111 Member
    82
    43
    Travelers Rest, SC
    2024 Prius Prime
    XSE
    I have a 2024 Prius Prime XSE. There is a CHG function available via a console switch that allows the engine to charge the traction battery. Does that mean the 12v battery is also receiving a charge while in that mode? Is the 12v battery also receiving a charge when running in the HV mode when the traction battery is depleted?
    KH
  16. BiomedO1
    4,184
    2,186
    SacTown, Ca
    There's a fair amount of guessimate in those calculations since the Toyota systems co-mingle the data points. Based on my driving style and the system telling me I'm averaging around 4.0 mile/Kwh; I've calculated that gas vs electrical breakeven is around $0.38/Kwh @ ~$4.00 a gallon. Just for reference, the same system has told me I was getting 25 mile/Kwh too; on occasions.
    You'll need to do your own calculations based on your own driving style and data. EPA calculations isn't "real world" results and doesn't take into account your driving style, terrain, and atmospheric conditions.
    I can't get more explicit than that, because we aren't lab rats......
  17. BiomedO1
    4,184
    2,186
    SacTown, Ca
    Your 12V battery should be receiving a charge, as long as the car is in "Ready" mode. The car's systems is designed to prioritize energy going into your traction battery; to enhance mpg numbers.
