Michelin Defender T + H Tires Discontinued.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by T.S. Elliot, Apr 6, 2026 at 9:29 PM.
  1. T.S. Elliot
    T.S. Elliot Member
    Desolation Row (MN)
    I'm wondering what everyone is going to do for tires now that the T + H is being discontinued by Michelin and the Defender 2's don't come in 15" sizes? My set of Defender T + H's are nearing the end of their life. I have snow tires for the winter, so I only really care about treadwear mileage longevity. CR consistently ranked the Defender T + H as tops for "advertised" tread life. The Defender 2 has an even higher tread life advertised at 100k, but sadly it's not available for the stock Gen 2 15" wheels. What's the best option? Try to find a touring set in good condition? Aftermarket? Possible to ever recoup the money buying a touring set via the Defender 2's 100k tread life? Keep in mind the labor costs associated with any tire problem. I've had some bead seal problems on old high mileage stockers over the years. Is there a new aftermarket option as reliable and solid as Toyota OEM?
    Try to find a set of new old stock Defender T + H ASAP and kick the can down the road for a few years? Do you take an MPG hit when upgrading to the 16" wheels? If so that would pretty much be a no go then. It would maybe be worth it spending money on the 16" touring wheels to get the Defender 2's, BUT if there was also an associated MPG hit then I think it would be a bad idea.
    #1 T.S. Elliot, Apr 6, 2026 at 9:29 PM
  2. Tombukt2
    13,480
    2,424
    You can always get a set of whatever ya need for defenders in steelies. The lighter weight. Had a set on a gen3. 46 bux a wheel fore pandemic
    T.S. Elliot likes this.
  3. Brian1954
    Brian1954 Senior Member
    2,416
    970
    South Central PA, USA
    I purchased a set of Continental TrueContact Tour 54 tires in October of last year for my Gen 3 Prius. I liked them very much. I hit a deer in January of this year, and the car was totaled by my insurance company. The tires and wheels are now on my wife niece's Gen 3 Prius. The tires are rated very well on the TireRack website.
  4. T.S. Elliot
    T.S. Elliot Member
    Desolation Row (MN)
    Hmm interesting, I never considered steelies due to the concerns of long term reliability related to corrosion (rust belt resident), but since I won't use them in the winter maybe it's an option? Are they really lighter than the OEM aluminum?
    Nice I guess this is an OK option. According to CR this has a tread life of 75k with price of $166, while the Defender 2's have 100k for $200. Manufacturer advertised the difference is only 80k and 70k. If we take CR tread life as accurate that means the Defender 2's have 33% more of the tread life for 20% of the cost. I feel like that is leaving money on the table.
  5. Merkey
    Merkey Active Member
    321
    292
    Birmingham, Michigan
    Costco still has the Defender T+H listed for sale.
  6. T.S. Elliot
    T.S. Elliot Member
    Desolation Row (MN)
    Yeah but only at the 195/65 size. Can those be used reliably and without leaks on a stock gen 2? How much fuel economy would one lose with the wider tires?
    Energy savers are also still avail but at 175/65. Could those be used instead?
  7. Mendel Leisk
    41,928
    Have you looked on tire rack, enter your car stats, see what’s available, check on reviews?
  8. Tombukt2
    13,480
    2,424
    What 195 is the alt size Wth is gonna happen? Man y'all ain't living right or sunthin. Daum
  9. T.S. Elliot
    T.S. Elliot Member
    Desolation Row (MN)
    Yes. Nothing has advertised or observed tread life as high as Michelin.
    Sorry for checking on a sub forum before i drop $600+. We can most definitely experiment with alt size tire sets on my car if you want to foot the bill. Good to know 195 is doable. What about 175? Energy savers are avail at 175 and defenders avail at 195.
    Tombukt2 and Mendel Leisk like this.
  10. xw20_driver
    xw20_driver Member
    106
    53
    PNW
    I have a set of Bridgestone Weatherpeak on 16s on my Touring. Got them last year and 13K miles ago and they are at 40%. Just terrible wear but decent traction on wet roads in the rainy pacifiic northwest.
    I just picked up a used set of 15" Prius wheels and I'm shopping for 185/65R15 tires. Looking at a set of Hankook Kinergy PT H737 90K 860 A A and 11/32 new tread depth.
  11. Mendel Leisk
    41,928
    I remember tire hunting for our grandson's Civic from another century ('92?), 14" dia IIRC. It was one or two very obscure brands, presumably made in China. 2nd gen Prius shouldn't be that hard, but you need to be flexible.
  12. T.S. Elliot
    T.S. Elliot Member
    Desolation Row (MN)
    I’m thinking I’ve narrowed it down to Defender T+H 195/65 15 vs Energy savers 175/65 15. Both seem available yet. I have not seen a comprehensive cost benefit analysis performed comparing the two though so I’m not sure. Consensus is the ES give better mileage and the defenders last longer. Well yeah…. But what about the bottom line? Which is going to be cheaper in the long run? Only thing I care about is minimizing cost.
  13. Tombukt2
    13,480
    2,424
    Just look at the tire size sites .. you see the diameter of orig tyre size usually you can go up and down 1 size comfortably much more than that . And . Down isn't really an issue. just looks funny in wheel wells.running 195 rt now on pretty stock gen2
  14. Tombukt2
    13,480
    2,424
    I think this is pretty much been hashed out here and beat to death over the years. But maybe not enough
  15. xw20_driver
    xw20_driver Member
    106
    53
    PNW
    On a gen 2 is it better to get 195/65R15 or stick to the original 185/65R15 tire?
  16. Tombukt2
    13,480
    2,424
    I run both sizes on two different cars the taller make it easier to climb in n out
    xw20_driver likes this.
  17. Mendel Leisk
    41,928
    I don't know, seems a big adjustment, to stray from stock size, when there are decent tires available in the correct size. Reducing the OD (which you do going to 175/65R15), will mean more revolutions per mile, a bit less ground clearance too.
  18. pasadena_commut
    pasadena_commut Senior Member
    2,872
    861
    Southern California
    Did Michelin release some new tire variant to replace the ones it was discontinuing? That happens with car lines too. For instance, the Mazda 323 was replaced by the Protege which was replaced by the 3. Basically just different generations of the same car with different names.
  19. T.S. Elliot
    T.S. Elliot Member
    Desolation Row (MN)
    Sure, the Defender 2s... which are conveniently not available in 15 inch varieties.
  20. dolj
    dolj Senior Member
    8,565
    4,350
    Wellington, New Zealand
    Here, 195/60 R15 is the stock size. The ride is better than the 185/65 R15 that is stock in the US, from what I read. The equivalent size in the 175 width is 175/70 R15. The diameter and the circumference are 0.4% less on the 175s. Personally, I would expect the handling of those narrow tires to be poor. If you are going to change the width, go up in size, not down. Some have even fitted 205s (205/60 R15).
    Good luck with your decisions.
    I agree with your assessment of tire life. I was so impressed with how they wore (after much angst and procrastination with spending the extra per tire), that I got them for the second Prius. Price per km, they work out cheaper. It is likely irrelevant in the US market, but just for your information, I run the Michelin Energy XM2 195/60 R15.
    I've tried Firestone, Bridgestone, and Hankook, to name just three, and the Michelins are by far and away the best I've run in a long while—for longevity, ride comfort, braking (they have never let go), and wet weather grip.
    That is just my opinion.
