Charging a Plug in Prime in the rain
Discussion in 'Prime Plug-in Charging' started by Prime_Rib, Apr 6, 2026 at 5:08 AM.
  1. Prime_Rib
    Prime_Rib New Member
    Virginia
    2020 Prius Prime
    Razz me all you want folks. In the end, though, I need to know the answer. I have to plug in my car outside. It gets rained on. The entire cord is dry except where it plugs into the car. Are there short and long term consequences to this. If it matters, I've been doing this for 4 years and haven't had an issue, but that doesn't mean those consequences don't exist. TIA.
    52,405
    from experience, you can charge in the rain, sleet, snow, cold, heat, you name it. it's never been an issue, and I did it for 11 years
    Prime_Rib and BiomedO1 like this.
  3. BiomedO1
    4,185
    2,187
    SacTown, Ca
    You just need to keep that safety cut-off brick dry and out of the water puddle. That will shut EVERYTHING down, if it senses an issue. Inspect the handle, pins and cable every once in an while. Repair or replace; when necessary.
    I've read that some company has made a rain/snow sock for the plug-in area; that shields it. Perhaps you can find it on an internet search. It's been 5 years on mine; but I'm partially covered by my houses' roof line.
    Prime_Rib likes this.
  4. Prime_Rib
    Virginia
    2020 Prius Prime
    Yes, that stays out of the rain. Thanks. I looked up and quickly found a cover. Doesn't sound like it's needed, but $20 for some assurance might be worth it. Much more expensive to replace the system.
    BiomedO1 likes this.
  5. Prime_Rib
    Virginia
    2020 Prius Prime
    Just what I needed to hear. Thanks.
