Uncomfortable Seats, Again
Discussion in 'Gen 3 Prius Main Forum' started by stokesey, Apr 6, 2026 at 5:49 PM.
  1. stokesey
    stokesey Junior Member
    69
    Southern Cal
    Hello I see a lot of threads about the uncomfortable seats in the Gen 3 Prius, but haven't found a thread that is decisive regarding fitment. I have 2015 Prius Two with mechanical adjustments. I believe all seats have airbags? I don't care about cloth/vinyl and am looking for OEM or aftermarket seats that will improve comfort. I don't mind using brackets or transferring my airbag but would prefer to avoid setting codes or having my airbag light on.
    Has anyone had success with aftermarkets or is there a bolt-in seat from other Toyota models? I see that Lexus CT200H seats would fit, but they're all powered. Adding wiring seems like a headache. Thanks!
    Tombukt2 likes this.
  2. CR94
    CR94 Senior Member
    2,756
    1,208
    Northwestern S.C.
    My sympathies! Seats of the Prius Two have the same fault as did those of my earlier, cheaper, smaller Japanese cars----the saggy middle of the backrest provides insufficient lumbar support. I fixed that deficiency in the older, pre-airbag seats by taking the backrest apart and adding steel reinforcing straps and hardboard between the straps and the existing zig-zag springs. .I haven't done the same to the Prius because I'm intimidated by the air bags.
    Let us know what you work out.
  3. stokesey
    69
    Southern Cal
    That's a great idea! I wouldn't have thought of modifying the existing seat to be more comfortable. I thought my springs were sagging after 200k+ miles, but the more I read, I realize it was probably bad just coming off the assembly line.
    I have reupholstered a couple of seats, and the foam was available in junkyards. Also pulled the airbag from an old seat and installed into a newer one. Usually it's just 2x 10mm bolts after you undo some Velcro on the seat cover (possibly this is federally mandated as they all seem similar?) Obviously disconnect all voltage to the airbag.
    I've got a lead on some newer Camry seats that may bolt up. Will update the thread as I know more.
  4. Tombukt2
    13,480
    2,424
    200H they should be the way to go if you can find them in good shape . Wiring would be minimal pick up a hot in the ground for each seat powered
  5. stokesey
    69
    Southern Cal
    OK but shouldn't those wires run to the fuse panel? Or maybe I can get away with an inline fuse? Also there are two electric motors I believe. Guessing they can draw up to 10A if my fat nice person is in the chair? Thanks
  6. Tombukt2
    13,480
    2,424
    Lotsa Gen 3vhad power seat options maybe power wiring is they're taped up in harness
    stokesey likes this.
  7. stokesey
    69
    Southern Cal
    Did not think of it. Will check ASAP. In this case its plug and play? As long as there is no ECU communication for something like seat memory or whatever. Toyota doesn't seem to do coding for most parts, so that's no worry. Maybe I will look around in Techstream for seat options.
